[JellyBean] *01.08.13* [4.1.2][LSW] OtimusROM v4
  • 11 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
OPTIMUS ROM
OptimusROM V4
original thread XDA
-Firmware: XWLSW OPTIMUS ROM V4.0
-Modem: XXMS2
-CSC: XEULS5 Multi
-Kernel: Philz XWLSW-5.08.5
-Available languages in Rom: Catala, Cestina, Dansk, Deutsch, Eesti, English (Australia), English (United Kingdom), English (United States), Espanol, Estonian, Euskera, Francais, Galego, Hrvatski, Icelandic, Irish, Italiano, Kazakh, Latviesu, Lietuviu, Macedonian, Magyar, Nederlands, Norsk bokmal, Polski, Portugues, Romana, Slovencina, Slovenscina, Suomi, Svenska, Turkce, Uzbek, Greek, Bulgarian, Russian, Ukrainian, Serbian, Korean
-Fully Deodexed
-Zipaligned
-Rooted
-BusyBox
-SuperSU
-Disabled boot sounds
-EFS Auto Backup
-Media Scanner Fix
-NO FULL WIPE
-No Call Ring Delay
-4 Way Reboot
-Enabled All Languages
-Enabled all languages in Keyboard
-Disabled Scrolling Cache
-Large Apn List
-Disabled Home Button Lag
-Added DropBox
-Removed Bloatware
-MultiWindow (Enabled all Apps)
-Init.d Support
-Black Status Bar
-Call Recording
-Stock Lockscreen
-Ripple Lockscreen
-Call Recording
-Enabled Usb Mass Storage
-Fixed USB Unmount Wakelock
-VIPER ADDED for BEST SOUND CLEARITY
-Galaxy S4 keyboard
-Popup browser
-Note2 gallery
-S4 wallpapers added
-S4 Multiwindow
-Camera with Mods-
~Added "Shutter Sound On/Off" in menu
~Flash can be used in low battery
~Hard keys as shutter
~Increased camcorder quality.
-S4 And XPERIA Z Font
-Default wallpaper and Lock Screen wallpapers changed
-S4 Contacts Images added Thanks To HighlanderZA
-New Optimus Bootanimation Thanks To momo.martinovic, Lifehacker7, PartimusPrime
-Smart Rotation enabled with toggle
-Lock screen rotation removed
-Back To Kill Mod
-S4 All apps icons added
-23 New AOKP Blue Toggles
-CRT Off Animation with Toggle
-Framed Recent Apps Thanks to majdinj
-Screenshot On Power Menu Thanks to tdunham
Changelog der V4 siehe bitte Post 4 https://www.android-hilfe.de/forum/...1-2-lsw-otimusrom-v4.454472.html#post-6177321
*Updated to v3.0 New Custom Bootanimation Rotation on Lockscreen Lock screen and Recent apps icon on Notification panel EFS Auto Backup Default wallpaper and Lock Screen changed S4 contacts images Google Maps updated to Latest Version 5 Shortcuts on Lockscreen Removed More Apps/Libs More Init.d Tweaks More Build.prop Tweaks MMS MOD: Disabled SMS, MMS log in call logs Enable Screen On/Off on receiving msg Add Vibration Toggle ADD Signature Toggle Group messaging Enable Save/Restore msgs Schedule Messaging 1000/Unlimited Recipient Limit Original Time Stamps Disable SMS to MMS Auto Conversion Increase SMS Hourly Limit CLOCK Mods: Remove time Center the clock in statusbar move the clock to stock location remove clock from statusbar remove am/pm change am/pm to small size change am/pm to large size add abbreviated day of week to status bar small size add abbreviated day of week to status bar large size remove abbreviated day of week from the status bar Now Rom is More Smother than previous versions. Enjoy
- Tweaks:
Increase touchscreen sensitivity
Less RAM usage through zipalign.
Reduced /dbdata, /data, /sdcard usage of *.db files and faster database access.
Faster disk access through remount script (noatime, disabled barrier etc) | World first smart remounting
Better network throughput from TCP tweaks and 3G tweaks
Tons of prop tweaks
Overall Better Performance and Battery Life
Less lags through LMK Tweak and Various VM Tweaks
Faster SDCARD Read/Write Speed
Transform your phone to Lamborghini. (joke , lol)
XWLSW OPTIMUS ROM V4.0 Link - HIER
XWLSW OPTIMUS ROM V3.0 Link - Here
BACKUP....BACKUP....BACKUP....!!
Installation ohne Wipe​
-Download Optimus Rom and save it to internal sdcard
-Go to recovery
-Select Wipe cache
-Go to Advanced and Select Wipe dalvik cache
-Select Install Rom SD card
Installation with Full Wipe
-Go to recovery
-Select Wipe data, Wipe cache
-Go to Mounts and storage, select Format system, Format preload
-Select Install Rom from SD card
-Reboot Device
Please Note first boot take 4-5 mins. Be patient..
Nach der Installation sollte dieser
Media Scanner fix geflasht werden HERE.
Entfernte Apps
Code:
AnalogClockSimple.apk
AnalogClockUnique.apk
ChatON_MARKET.apk
ChocoEUKor.apk
CoolEUKor.apk
Days.apk
DigitalClock.apk
SMLawmo.apk
DualClockAnalog.apk
DualClockDigital.apk
EdmSysScopeService.apk
FotaClient.apk
GameHub_2.0_ICS_WVGA_ngmoco.apk
GroupCast.apk
HelpHub.apk
Kies.apk kieswifi.apk
Kobo.apk Magazines.apk
Microbes.apk  MobilePrint.apk
MobileTrackerEngineTwo.apk Music2.apk
MusicHub_31.apk  OceanWeather.apk
PickUpTutorial.apk PlusOne.apk PolarisViewer.apk
PressReader.apk ReadersHub.apk
RoseEUKor.apk SamsungApps.apk
SamsungAppsUNA3.apk SamsungWidget_FavoriteApp.apk
SamsungWidget_ProgramMonitor.apk
sCloudBackupApp.apk  sCloudBackupProvider.apk sCloudDataRelay.apk sCloudDataSync.apk  sCloudSyncBrowser.apk sCloudSyncCalendar.apk sCloudSyncContacts.apk
SecMiniDiary.apk SimpleFavoritesWidget.apk
Swype.apk Swype.apk
talkback.apk TrimApp_phone.apk VideoHub.apk
WeatherWall.apk  wssyncmlnps.apk YahoonewsDaemon.apk YahoonewsWidget.apk  YahoostockDaemon.apk YahoostockWidget.apk Zinio.apk
-Disable auto sync for accounts
-Disable GPS (and wifi gps)
-Disable Autobackup of gmail Account
-Dail *#9900# and disable Fast dormacy
-Set brightness level to automatic
-Set wifi sleep policy to "Never"
-Disable motion
-Check and Disable The apps for background sync
-Use Greenify app from play store
-Disable transition animations
~_Sale_
~dsixda
~pankaj88
~neroyoung
~slaid480
~dheeraj (dhlalit11) )
~dsexton702
~lokeshsaini94
~zhuhang
~Phil3759
~majdinj
~MylifeRocks10
~Namoi
~HighlanderZA
~engloa
~electricsheepdreamer and ApriliaM3
~bombaybadboy for his awsome Thread
~ ICS_XD for Helping me alot
~ A BIG THANKS TO Lifehacker7 For ROM BANNER. THANK YOU SO MUCH BRO.
Änderungen und/oder Anregungen gerne per PN an mich, DANKE!
Sehr schade, dass sich kaum jemand bedanken kann. Natürlich ist es nicht meine ROM, aber das Vorstellen hier und Aktuell halten, ist auch Zeitintensiv und könnte zuminest durch ein Klick gewürdigt werden.
FullWipe und Wipe Script
Reaktionen: anime, Pr0TuRk38, Steveria und 6 andere
OPTIMUS ROM AROMA v2 Here
HTML:
7 Types of SystemUI
-23 Aokp
-23 s4 Toggles
-23 Stock green Toggles
-White Toggles
-Blue Ginger Toggles
-Fancy Toggles
-TRANSPMINIMAL toggles
6 Types Of Pulldown Background
-Ace One Piece
-Girl
-50% transparent
-Android
-Joker
-Superman
6 Types of framework
- Holo Black
- Wood
- Street
- Light Blue
- White
- Black
2 Types of Gmails
- Black Gmail
- Stock Gmail
2 Types of Kernels
- Jeboo 2.1
- Apolo Regular 4.8b
7 Types of Keyboards
- Black Note2 Keyboard
- White Note2 Keyboard
- Blue Note2 Keyboard
- Pink Note2 Keyboard
- Red Note2 Keyboard
- S4 Keyboard
-S4 White Keyboard
3 Types of weathers
- S4 Stock weather
- S4 Half Transparent Weather
- S4 Full Transparent Weather
USB MODS:
- MTP
- Mass Storage
3 Types of Launcher
-Disable Wallpaper Scrolling
-Enable Wallpaper Scrolling
-Enable Wallpaper Scroll + Rotation
4 Types Of MultiWindows
-Black MultiWindow
-Transparent MultiWindow
-Cyan MultiWindow
-S4 MultiWindow
Nicht AROMA Mods:
1-MEGA MOD:
-Torch on Lock Screen
-Skip Songs
-Ink Effect
-Back to Kill
-Blue toggels
-Black status bar
-4 way Reboot
-Blue Dialer
Download Here
-WallPaper Scrolling Mod
Download - Here
-23 Toggles + Transparent Status Bar + Back to Kill
Reaktionen: anime, Pr0TuRk38, andi2398 und eine weitere Person
V4 ist on :winki:!
ChangLogs to V4.0:
Media Scanner Fix
Back To Kill Mod
Screenshot On Power Menu Thnaks to tdunham
Battery Mods: Thanks to Didact74
-Stock Icon -Text Only
-Texy with Icon
-Android
-Blue
and Many more......
LockScreen Mods: Thanks to Didact74
-ACER
-Ripple Effect
-AOSP Lockscreen
-LG
-BlackBerry 10
Xposed Framwork Added Thanks to rovo89
1- Application Settings
-Per app DPI/TabletUI
-Invoke app permissions
2-TweakBox
-Skip Songs with Volume key
-Change Status bar color
-Change Clock Color
-Show input method switch
-No. of Signal bars ( for stock signal bars)
-Battery warning Toggle
-Battery full notification toggle
-Vibrate on call wait toggle
-Turn screen on/off when plug/unplug
-Long Home key behaiour
More Init.d Tweaks
Reaktionen: Pr0TuRk38
Link ??!!
Och nö... Ich habe die doch erst hier rein gestellt. Nun schon wieder ändern... :cool2:
Reaktionen: sourly
der homebutton funzt bei mir nicht ? Wenn ich ihn gedrückt halte kommen die letzten apps die ich offen hatte.. aber bei einem kurzen druck passiert nichts.. jemand eine idee ?
Nein, ich hatte sie vorhin auch kurz drauf und bei mir ging es gut.. Liegt manchmal am Kernel..
Reaktionen: rickydavid
Ok anderen kernel habe ich jetzt nicht getestet. Komisch aber ist das ich immer wieder bei der rush rom Lande:)
Reaktionen: beicuxhaven
Wo du im Endeffekt landest ist irrelevant. Hat es denn mit einem anderen Kernel funktioniert, ist ja die Frage?
Ist die rom zu empfehlen wenn man goa zum Vergleich hat?Dankeschön
Vergleichen wird da sehr schwierig, da GoA viel mehr Spielereien bezogen auf Theming integriert hat. Ich würde sagen Nein! Diese ROM läuft sehr rund und stabil, aber stellt halt einfach eine Plattform dar gerade in der abgespeckten Version (siehe entfernte Apps). Die GoA läd mehr zum Basteln, Testen etc. ein.
Reaktionen: Steveria
beicuxhaven
sourly
sourly
Pr0TuRk38
Widar
Widar
nightwatchdog
