dawkon13
- 21
Hallo
If you like this ROM you can donate to me:
Das ist mein ROMs4 ICS versionen (besser akku vitalität )
kernel- SpeedMod K3-32
Quick-Info:
v1.2 LITE:
INSTALLATION:
EXTRA !
Du kannst ändern boot screen
zum beispiel:
Wie?
Download dieses app:
https://play.google.com/store/apps/details?id=net.hellcat.droiddev.sgs2bootlogo
ODER
Download diese Datei und öffnen !Read Me.txt :
http://www.mediafire.com/?yugq9am2kts1kqq
DOWNLOAD:
v1.2 LITE:
https://sites.google.com/site/roms4s2/home/roms4-v1-2-lite-ics-by-dawkon13
v1.1:
https://sites.google.com/site/roms4s2/home/roms4-v1-0-v1-1-by-dawkon13
Bilder:
dawkon13 schrieb:ONLY V1.0 AND V1.1
you can:
-enable/disable ICS lockscreen
-enable/disable quick song skip
-enable/disable short home delay
-enable/disable short power delay
How?
-open folder sdcard/tweak and rename:
example:
quick_song_skip_off->rename: quick_song_skip_on
Quick-Info:
v1.2 LITE:
v1.1:dawkon13 schrieb:-based on XWLQ2
-15 toogles
-4ways to reboot
-crt off
-call recording
-other little changes
-great battery life
-fast and stable
v1.0:dawkon13 schrieb:-Added function "GSM only" in network mode (not available in stock XWLPY)
dawkon13 schrieb:-kernel SpeedMod K3-32
-TouchWiz UX Launcher,
-Touchwiz UX System Style
-Toggles from SIV
-SIV wallpapers
-Music player and some apps- SIII,SIV style
-Call keyboard JB Style
-Torch on lockscreen
-4 way to reboot
-volume rocker
-i forgot...
INSTALLATION:
dawkon13 schrieb:-Download ROM, copy ROM on SD
-Flash good recovery (some have status7)
-Flash ROM
-wipe cache/dalvik cache
-If you have other Android version (example CM10,ICS) or have you bootloop make wipe
EXTRA !
zum beispiel:
Wie?
ODER
DOWNLOAD:
v1.2 LITE:
v1.1:
Bilder:
