[ICS] *22.02.13* MIUI V4 3.2.22 - Offizielle Versionen
  • 1.961 Antworten
Gibts jetzt eigentlich schon neuigkeiten von Miui Germany?
Hi everyone,
This weeks recommended updates:
1. Camera interface optimisation
2. New Stopwatch function
3. Number attribution bug with contacts and dialer fixed
4. Quicksearch FC problem fixed
5. Music support for FLAC file format
Full release wie immer morgen (freitag)
eddy197 schrieb:
MIUI GERMANY | MIUI
Bist immer auf dem neusten stand :D
Danke, aber ich meinde wann die Miui Germany Jungs es schaffen das ICS Miui rauszubringen, und ob es da schon neue Infos gibt.
Nein es gibt keine Infos und wenn dann wirst du es hier bestimmt sehr schnell erfahren.
Sent from SGS2 using Tapatalk
Changelog von 2.3.30 ist draußen :)
[System]
  • Optimise password-protected applications do not appear in the recent Task list
  • Optimisation of the recent task pane click-able area to resolve a mistaken click problem
  • Repair to clear the "Settings" no lock screen data leads to abnormal operation
  • Repair in some cases cannot ROOT
  • Repair screen vertex does not display rounded corners, the status bar interface displays the wrong information
  • Repair removing settings data leads to lock screen display issues, also launcher becomes unresponsive
  • Repair MoboPlayer playback FC issues
[Phone]
  • Optimise the efficiency of the T9 dial-up search
  • Optimise the display of dial-up record efficiency
  • Fix dial-up and click interface for contacts avatar causes rapid panel flashing problem
  • Fix dialling a number with 0 contacts with the prefix lead to unrecognised problems
[Contacts]
  • Add call record to deletion of single log entry
  • Add Merge Contacts
  • Optimise the contact import efficiency
  • Optimise the search results style
  • Optimise the group avatar style
  • Repair Exchange server contacts
[Lock screen, status bar, notification bar]
  • Added support for clicking on the notification bar switch away (See Settings -> All settings -> notification bar style, open the notification bar "switch" click away)
  • Optimise the status bar rendering efficiency
  • Optimise text input, left side of the status bar to display the input method icon
  • Fix the power icon to display the exception of the problem
  • Fix telecom version of the mi-one signal shows the wrong information
  • Fix in some cases, be mistaken for hidden notification bar icon problem
  • Fix in some cases, cannot enter the PUK code
  • Fix lock screen display of owner information is not displayed
  • Fix default lock screen, music title and message preview show overlapping
  • Repair the notification bar "simple" mode switch to respond to clicks.
  • Repair setting the status bar style may lead to FC
  • Repair Desktop button to light up the screen, may mistakenly open the flash light
  • Fix problem with default lock screen time is not updated
[Camera]
  • New shutter mute (when the system is muted you can also in the camera interface can press the volume keys to adjust the shutter volume)
  • Add panoramic mode support the use of the mi-button button to take pictures (MI-ONE only)
  • Repair third-party applications calling system camera, the results page shows the problem of camera operations
  • Fix password lock screen to activate the camera leads to FC
  • Fix flashing focus screen interface problem
[Gallery]
  • Add support to display pictures and albums from ROM
  • New! If no SD card installed, the Gallery can still be used
  • Optimisation of image editing or cropping, automatically saved in the same directory as the source file, the file name is automatically added to the new edited file
  • Repair SD card clear the cache, the cache remains unusable
  • Repair multiple choice mode selects zero files
  • Fix memory leak problems result in thumbnail not displaying and FC issues
  • Fix when the gravity sensor is turned off, the details of the photo will still rotate
  • Repair high DPI phone, pictures, and Album thumbnails are too small
  • Optimise multiple choice selection mode fonts and icons style
[File Explorer]
  • Fix applying system update via SD card, the install of the update package leads to FC
  • Fix problem switching to the SD card tab leads to FC
  • Fix in some cases double-click the back button leads to FC
  • Fix in some cases item classification cannot be selected
  • Fix problem when SD card is not installed, the category page information displays the wrong information
[Desktop]
  • Optimise dragging the icon to the edge of the screen to remain continuously across the screen
  • Optimise using the new rendering to improve efficiency and speed
  • Fix problem dragging folder icons
[Themes]
  • Fix in some cases applying a theme will lead to phone not responding, requiring a reboot
  • Fix some problems with lockscreen themes
[Music]
  • Add FLAC format support (03-27)
  • Fix in some cases downloading online music leads to FC
  • Fix problem with online music, adding currently playing song to 'current' playlist fails
[Settings]
  • Optimisation "flight mode" GPS satellite automatically rotate the screen operation to modify the commonly used settings for the switch operation
  • Optimisation of the complex operation commonly used settings pop modify to enter the lower-level page operations, such as "volume" "brightness”
  • Repair to enter the "notification bar style" and "access point name (APN) screen starts to flash the screen on and off
  • Repair in the settings screen password-protected process to cancel the return to the previous level, cause the screen password "feature is turned off
  • Repair opening the password protection screen, selecting the pattern password is visible does not display
  • Optimise settings stored in single USB storage
  • Fix problem where privacy mode cannot set password-protection
[Browser]
  • Add new night mode function for viewing web pages at night
  • Optimisation of default navigation page loading speed
  • Optimisation of the menu functions
  • Fix closing tab automatically switches to the first tab in the list
  • Fix problems with user interface visual details
  • Fix problem opening quick control menu in full screen mode does not hide the bottom of the toolbar
[Download Manager]
  • Add notification to remind of low SD card space, and display the corresponding information in the download list
[FM Radio]
  • Fix problem listening to the Radio when call is received, radio music is now resumed after the call is ended
[Access Controls]
  • Optimise application password protection in the recent tasks list does not show a preview when the application is marked protected
[Alarm Clock]
  • Added new timer stopwatch
  • Optimise the alarm clock switch style
  • Repair white on white labels in the interface
  • Fix screen is not correctly showing background of the clock interface
  • Fix setting silent mode for alarm brings back invalid response
Reaktionen: Bass-T.
Faszinierend. Der Changelog von der Fanseite Miuiandroid.com kam eine Stunde früher als der offizielle Changelog von Miui.com
An der Uploads arbeiten beide noch. Sollte innerhalb der nächsten Stunde verfügbar sein.
Ja das ist mir auch aufgefallen und da habe ich mich auch etwas gewundert :D
Die China Version gibt es auch immer als kleines Update. Mit Downloadmanager wesentlich schneller.
Jo link ist echt lahm. Hoffe es kommen bald Mirrors.
Kernel Version DXLP7... Was ist das denn? Von LP7 habe ich ja noch nie etwas gehört.
edit: Anrufbug und SMS Bug sind behoben.
Hi laut samfirmeware ist die DXLP7 eine FW für den Asiatischen Raum.
Denke mal das Miui V4 von der den kernel und das Modem genommen hat!!!
Lg
Edit: Kann schon wer sagen wie die Läut bin nähmlich am hin und her testen von ICS-Roms
Aktuell Goa ICS und die läuft sehr gut:)
Reaktionen: Bass-T.
Danke für denn Mirror. Mit dem ging sehr schnell. Gleich mal flaschen jetzt. Morgen wird dann die deutsche Version kommen oder?
Was dabei nicht gesagt wurde, dass es sich bei dem Link um die UK Version von miuiandroid.com handelt. Wer also die offizielle chinesische Version haben will, ist mit dem Link falsch. Und: Wer braucht Miui Germany?
Stimmt. Danke!
Also ich habe die UK grad ausprobiert. Irgendwie durchwachsen. Die Home-screens scrollen laggt ganz schön. Zum Vergleich eben noch mal die Miui Special Edition ICS 1.1 (2.3.20) drauf gemacht und die läuft flüssiger.
Weiß schon jemand ob es nen overbounce für ICS gibt? Bei overscroll werd' ich echt wahnsinnig. Ich bin durch WP7 oversqueeze verwöhnt...
Danke für die Info.
Ist das bei denn Mirror Link auch die 4.0 denn bei XDA steht auch eine 2.3.30 aber als GB Version?? Was ist bei der UK Version denn schlechter als bei der China Version?
Edit: So mal eben die Version installiert aber sagt mir nicht zu. Im Vergleich zu ICS LP3 ist dieser schon merklich langsamer. Außerdem ist vieles Chinesisch noch ob wohl ich dachte diese sei komplett Englisch.
beicuxhaven
beicuxhaven
beicuxhaven
Thoddü
Thoddü
Chris1996
Mirok80
