[ROM] SuperAosp 8.6-AW, Gingerbread 2.3.4
  • 11 Antworten
Q
quasimodo
Gast
Ein weiteres "AOSP ROM": SuperAosp von superatmel KLICK zu xda
_____________________________________
Anmerkung:
Ich oder Android-Hilfe.de übernehmen keine Haftung dafür! Ihr seid für euer Handeln selbst verantwortlich!!!
Ich bin kein Entwickler, sondern Anwender/Nutzer und habe kein Tiefer gehendes Wissen über dieses Rom.
Bei Fragen wendet Ihr Euch am besten an die Quellen!
Erläuterung in English
THIS ROM IS NOT WELCOME IN FORUM HTCMANIA.
Special thanks to the creator of the inexus theme from which I have been inspired to give a graphic touch to the rom.
This rom (it is not a mod) has been developed entirely from the source code from Google and a very small part of Cyanogen framework.
Thanks to Cyanogen and all its staff for the contributions.
This rom was installed on three terminals, one free from Poland, and two from orange, one with two months and another one with one day. The tree without problems
Before start anything take into account the following steps:
Before start you must have kies installed on your pc and that detect your terminal in a normal way, this is necessary because it needs the driver for odin that is the following that we must hace to install the two first steps.
Odin is attached:
http://cdn.movilzona.es/repos/supera...dinV3_1.85.zip
Also you must put your phone in download mode without problems, the phone must support the three buttons. Because depending on the buttons combination it will make different things.
With the phone totally turned off:
Home+volume up+power = Download mode
Home+volume down+power = Recovery mode
You must test these combinations before start because it is possible that your terminal does not support this buttons combination and you will have serious problems,
(Exakt so wie man es auch schon von CM7 & MIUI MCGv her kennt)
(vor der Installation sind wie immer eventuelle Lagfixes oder Tweaks zu deaktivieren und ein Nandroid natürlich ratsam)
Wichtig: Stellt sicher dass ihr von einer Froyo Firmware kommt und auch einen Froyo Bootloader habt
(also vorher auch keine Gingerbread Version drauf hattet). Falls ihr das nicht sicher wisst, flasht JPU
[[[ DOWNLOAD ]]]
mit Odin (mit 512er Pit und Re-Partition an). Wie das geht? Siehe hier ->[[[ KLICK ]]]
zunächst diese 4 Dateien herunterladen
Download & Installationshinweis
Diese 3 Dateien herunterladen
1. Rom Stock froyo http://cdn.movilzona.es/repos/supera..._FROYO_PDA.tar
2. Kernel with recovery ClockWork http://cdn.movilzona.es/repos/supera...KernelCMW2.tar
3. Rom SuperAosp http://cdn.movilzona.es/repos/supera...y-S-AW-8.6.zip
  1. [FONT=&quot]Kopiert dann beide Dateien auf die interne SD-Karte! Achtet dabei darauf, dass ihr die beiden Dateien in den selben Ordner kopiert habt![/FONT]
  2. [FONT=&quot]Geht in den ClockWorkMod und wählt "Choose .zip from SD-Card"[/FONT]
  3. [FONT=&quot]Geht zu der Datei "SGS MIUI INITIAL zip" und flasht sie![/FONT]
  4. [FONT=&quot]Kein Reboot machen, Akku raus, rein[/FONT]
  5. [FONT=&quot]wieder in den ClockWorkMod gehen und [/FONT][FONT=&quot]unter "mounts & storage" system, data und cache formatieren[/FONT]
  6. SuperAosp[FONT=&quot] Flashen – Reboot – Fertig[/FONT][FONT=&quot]![/FONT]
Update installieren von CM7/MIUI-MCGv aus:
zunächst SuperAosp Aktuelle Version herunterladen
dann wie folgt vorgehen
  1. Aktuelles Realise auf die interne SD kopieren
  2. Unter "mounts & storage" system, data, cache & datadata formatieren
  3. SuperAosp installieren
  4. Fertig
ATTENTION!!!
This rom is autoinstalled itself, i.e. it is totally reconfigured
I advice you to skip the configuration of the google account pressing skip and afterwards in the launcher you can configure the rom to your like. If you don't skip the settings of the google account, the phone will connecto to the market and start downloading all the aplications you had preciously installed and that might (it probably will do) saturate the phone because it is trying to do a lot of things at the same time, and it also restore the background image of your home to the one you had previously, and you ask me that how it is possible if you had installed the rom with wipe, to have the same image as before. In this way, you will have a clean instalation. Afterwards, you can log in to the marker and install any free application, so the market will resync and install again the previous applications you had on the phone.
Those of you who made backups of any kind or program, pay special attention, because you might have some problems. (I am speaking of backups, included the SupSetup but applications), specially pay attention to the configuration data restoration of any kind. If in doubt, better not do it.
New SupSetup V20 on all roms, it will not work any other previous SupSetup for this rom
The new SupSetup has integrated the activation of applications on demand in the applications extra section, you can activate the applications that you are interested on because the rom comes in "LITE" mode (without extra applications installed) so as anyone of you can choose their best configuration.
It is important to activate the applications from the SupSetup before setting up the google account, so as when the phone sync with the servers while setting up the google acount, this extra applications fall into the download section. After opening the market, and for the applications to show in the download section, just install any free application, so the market wil resync the downloads.
General
- “LITE” mode rom
- New graphical aspect different to SuperGinger's
Added
- Wake & Unlock
- Bluetooth always visible from Settings (tolemaC)
- Clock hide
- Battery percentage
- Part of CyanogenModsettings from Cyanogen
- etc...
Apps
- More apps could be installed from extra application on SupSetup
- Google Apps
- Flash Player 10.2
General
- “LITE” mode rom
Added
- Wake & Unlock
- Clock hide
- etc...
Apps
- Google Apps
- Flash Player 10.2
Support in Movilzona
http://www.movilzona.es/foro/superao...axy-t5544.html
Twitter @superatmel
Captures:
wie siehts da aus wenn man von cm7 kommt?
reicht da format system/data/cache oder muss man da auch von froyo weg?
und is der kernel zwingend notwendig der ist nähmlich auf spanisch was ich auf xda gelesen hab :S
edit: läuft wirklich gut fühlt sich um einiges schneller als cm7 bisher noch keine fc`s zum akku kann ich noch nicht viel sagen aber dürfte sich gut halten (:)
Ist das gleiche zu beachten, wie bei den anderen CM7 Roms!
Den Aktuellen Glitch- und Zachariaskernel kannst Du auch verwenden.
Welchen Aktuelle CM7 Stand das Rom hat konnte Ich nicht rauslesen.
Reaktionen: Markus4283
Ist bei dieser Rom die Kamera bei Aufnahmen ruckelig(also so wie bei MiUi oder CyanogenMod 7)
Läuft gut und schnell, grad probiert, allerdings bekommt ich zum Verrecken keine Verbindung zu Simyo-Spanien, wie bei CM7, immer nur Movistar, Orange und Vodafone, Simyo taucht in der Liste der Netzbetreiber nicht auf.
Egal, was ich versuche..
Bei anderen ROMS ne Sache von Sekunden, Simyo in der Liste, klick, verbunden...
Einige Elemente sind auch noch noch nicht "eingedeutscht", SUPsetup z.B.
Habe es Mir mal zum Spaß auch mal drauf gemacht. Eine schöne Alternative zu CM7 und ist wie dieses Flott dabei.
Bin zwar ein bekennender Mozilla Fan, begeistert Mich aber auch!
da müssen aber noch ein paar sachen eingedeutscht werden inkl. kernel weiß einer wann das kommt??
in welchem pfad ist denn die externe sd angegeben? /emmc wie bei cm7?
ja normalerweise schon
hallo leute :)
habe seit neuesten einen fc bezüglich des launchers hat das problem sonst noch wer?
evtl liegt es gar nicht am system sondern am launcher?
Versuch doch mal einen anderen ;)
