[ROM] SenseStyle [2.3.5][JVS]
  • 19 Antworten
reflex
reflex
Stamm-User
201
Original XDA Thread: [ROM] SenseStyle [2.3.5][JVS][Beatiful][23/09/11] - xda-developers
Screen:
ROM Features:
- Basad on official Android 2.3.5 XXJVS
- Deodexed
- Zipaligned
- Root + Superuser
- Busibox
- Wipe version: If you want Non-Wipe, Download this file Download and follow the instructions contained in the archive.
- Modem JVS
- CSC JVS Multi
- Kernel Semaphore 1.7.0
- Theme Sense made by me
- 10 lockscreen (settings, lockscreen menu, stile lockscreen, stile lockscreen)
- Status bar style sense
- NOT LAGGING STOCK BROWSER
- % battery
- CRT 'screen off animation'
- Extended power menu; Set it with Theme Settings
- Fully enabled SIP Wifi/3g
- Phone hack: autorotating dialer and call screen / non increasing ringtone
- Call Log Tweak making it display only Log of Calls (In/Out) and excluding SMS/MMS from list
- Mms hacks: no conversion to mms after 3 smses / 100 recivers / send time
- Camera hacks: 'Low Battery' Hack + 'Shutter' Hack + Audio Hack
- Sense Launcher (free)(super customizable)
- Sense icon
- Sense Wallpaper
- Sense Live Wallpaper
- Sense ClockWeather
- Sense Widget
- Gps Works
- Juwe11 Script Ram Optimization [ +free ram = +battery ]
- Removed many apk in system/app except those that allow the proper functioning, for more free ram and + battery life.
- New Market
- AK notepad
- CWM app
- Tweaks app
- Theme Settings
- App Forum SconcauTEAM The Best Android Community
THIS ROM IS FAST, STABLE, HAVEN'T PROBLEM AND NO BUG!
IF YOU HAVE PROBLEMS, YOU HAVE DONE SOMETHING WRONG IN THE INSTALLATION!
Installation from FROYO or ECLAIR:
* Flash Stock firmware XXJVS must contain bootloader (with Odin)
* Flash some kernel with CWM support with Odin
* Download my ROM and put it in your Galaxy S
* Go To Recovery Mode
* Wipe Data/Factory reset, Wipe Cache
* Advance: Wipe Dalvick cache, Wipe Battery stats
* Installa zip from sdcard
* Chose zip from sdcard
* Select my rom and ENJOY
Installation from GINGERBREAD:
I offer support and help
DOWNLOAD
SenseStyle V 2.0 Download
Apps Package [CWM](Google Talk Audio/Video, Flash Player, Task Manager, Data Enabler/Disabler Widget, Google Maps, Steets for maps, Gmail, YouTube, Google Earth, BarCode Scanner, SoundHound, Music Download)Download
CREDITS:
DAGr8 (10 lockscreen )
OUT kitchen ( Theme )
stratosk ( Kernel )
Juwe11 ( Ram Script )
Reaktionen: xtoph
Downloading and testing
Feedback #1
Geil :D :thumbup:
Pro:
Smooth & Schnell
WLAN / 3G Top schnell
GPS schnell
Tolles Aussehen
2100 Quadrant points bei Standart
2900 Quadrant points @1200Mhz
Akkuanzeige in %
Kontra: ( ist aber warscheinlich nur ne persöhnliche Sache )
Google Earth geht nicht. ( Prozess wird beendet. Brauch ich aber eh nicht )
Das durchgehende Vertikal scrolling im Apps Menü find ich auch nicht gut
Was aber richtig dumm ist: Wenn ich das Tel im Anwendungsbereich auf die Seite Kippe sammeln sich alle Apps auf einer stelle :sad: --> xda-developers - View Single Post - [ROM] SenseStyle [2.3.5][JVS][Beatiful][23/09/11]
uTrack funzt nicht
Mehr dazu morgen oder so
Und der Wlan Bug ist auch noch da !!!!
Die Wlan Verbindung bricht bei der JVS im minutentakt kurzfristig ab! Es sei denn du vergibst eine Statische IP.
Da haben die Entwickler ein faules Ei richtig gut Versteckt. Denn dieses Problem ist weder mit irgendeinem Kernel noch mit einem anderen Modem zu beheben :confused2:
Kann ich nicht bestätigen.
Habe vollen Empfang und dynamischer IP Vergabe.
Dann schau mal ne Zeit lang auf dein Wlan Symbol in der Statusleiste
Bei mir nicht! :confused2:
Alles ohne Probs. Downloads müssten ja dann auch abbrechen
Aha. Wie kommts? Ich habs von Anfang an seit Stock JVS
Hast du schon mal ein GB Rom drauf gehabt bei dem es gefunzt hat?
Ich hatte vorher das drauf : https://www.android-hilfe.de/forum/...-f1-innovation-v13-jvt-19-11-2011.116099.html
Ansonsten einfach noch mal flashen.
Ich mache immer 2x alles wipen im CWM
Wipe Cache
Wipe Dalvick cache
Wipe Battery Stats
Bin langsam der Meinung das manche Fehler daher kommen, das es an den verschiedenen Produktionsreihen der Galaxys liegt
Ich kam von der JVR! Alles gewipt und trotzdem Mist
Also ich kann das WLAN Problem mit dem Semaphore 1.7 nicht bestätigen. Alles Super trotz DHCP
Ist das ganze auch auf Deutsch,oder nur Italienisch?
Das ist Multilanguage .... also auch auf deutsch :)
Danke,dann werde ich mich mal ranstürzen.
Ist ganz cool die Rom..
DA kommt hoffe ich noch einiges besseres...
Guter Ersatz zur anderen Sense Rom die ja nicht weiter gemacht wird..:sad:
Da freue ich mich echt das es was Neues gibt...macht weiter so mit der Rom kann nur besser werden...!!!!!!!
mfg
mfg
Man darf die beiden aber nicht miteinander vergleichen, da sie vollkommen anders konzeptioniert sind, GalaxySense ist eine richtige Portierung aufs SGS, SenseStyle ist, wie der Name schon verrät, "lediglich" eine mehr oder weniger kosmetischer Veränderung mit Theme usw.
Das ist ja richtig das man die nicht vergleichen kann oder sollte. Da es ja mit der portierten wohl nichts Ganzes mehr wird ist das doch ganz cool. Für die die das Design gut finden und keine Lust haben das alles selber zu machen. Themen und so weiter. Gruß
Q
  • quasimodo
quasimodo
Q
kingoftf
kingoftf
kingoftf
philippsp
  • philippsp
ilovemysgs
ilovemysgs
