Kinghariii
Kann mir jemand ein Modem für Österreich empfehlen?
LG1. Locate the 90screenstate_scaling using Root Explorer (Etc > init.d > 90screenstate_scaling)
2. Open the 90screenstate_scaling with text editor (Make sure Mout r/w is on -- Hold on to the file, a pop up should ... well ... pop up hahaand press on "Open in Text Editor)
3. Scroll down and under "One governor to rule them all" change AWAKE_GOVERNOR to "ondemand" or whatever governor - except smartass/interactive
4. Scroll down even more and in the "Smartass settings" add a "#" before to all the echo -> Like this "#echo"
5. Scroll down and look for the governor you choose i.e. ondemand and remove the "#" before each echo
