SGSPro87
Hier von Bezke ein anderes Projekt...
Hier der XDA-Link:
[ROM] InnOvaTioN v5.2 XXJVS 10 Lockscreen OnAir 2011.09.23. - xda-developers
Installation:
1. Zuerst die Stock JVS downloaden, hier der Link: Passwort für die Stock : samfirmware.com
Multiupload.com - upload your files to multiple file hosting sites! ( 2.3.5 XXJVS Rom mit repartition-512-pit)
2. Dann den Semaphore Kernel downloaden, hier der Link:
AdF.ly - shrink your URLs and get paid! (Semaphore Kernel 1.7 JVS , oben rechts Werbung überspringen)
Weitere Kernel weiter unten.!!!!!!!!!!!
Dann für die Interne SD-Karte der Link für die Rom:
Download V5.2 Link:Multiupload.com - upload your files to multiple file hosting sites!
Specification V5.2
- PDA: XXJVS 2.3.5
- Modem: JVS
- Csc: I9000OXAJVP Multy
- Kernel: Semaphore 1.7.0 kernel /bln, voodoo, oc/
- NOW DEODEXED
- Zipalign
- Busybox
- Symlinked
- Rooted
- Big APN's list added
- Crt animation
- Extended power menü
- 10 Lockscreen / You can Change it in Settins-TSM Parts/
- Percentage Battery, and animated charging
- Modded gingerbread keyboard
- Modded TW4.5,
- Greeny Swype,
- Hacked camera /shoot with power, low battery and autofocus video/
- Free chainfire plugins, free bln, free voodoo control, gps aids, Voltage control,
- Modded Apps: Settings, Browser, e-mail, 3D Galery, Google talk, google search, Contacts, Dialer, Clock package, myfiles, mms-sms, Video player, music player, etc...
- init.d in etc / Use some hack : S.A.S.6, .../
- Battery uptime hack
- Quadrant with lagfix: @2700- /oc: 3500 /
Credits to:
Juwe11
DAGr8
Whitehawkx
dhiru1602
birgertime and the team for EDT application
totallydubbed -for install video
bestnabil55 - for video
dsexton702 - For the tweak
Ipy - For the tweak
Lukiqq - for install script
CHANGELOGS:
V5
-The rom based on Stock XXJVR /so it is Odexed/
-Only 1 lockscreen AOSp
-FULL Lagfree browser
-S.A.S.6 Tweaks installed /so you must install it on ext4 lagfix/
V3
-Semaphore 1.6.0 kernel added
-remaked framework jar files
-modded Browser / more better/
-fixed gps animation
-gps ntp to europe.
-Touchwiz Launcher 4.5 added
- and more little changes...
Bilder von der Rom
Hier weitere Kernel:
[KERNEL] Semaphore JVS 1.7.0 (1.7.0bm) (CF-Root + Voodoo Sound v10 + OC/UV + BLN)
http://forum.xda-developers.com/show....php?t=1112908
Mit Root Explorer kann man den Skript einfügen
Zu beachten bei diesem Kernel:
Also, die Standard Cpu Freq. ist 1GHZ. Wenn Sie möchten, erstellen Sie eine Datei mit ausführbaren Berechtigungen in / system / etc / init.d mit diesem Skript zum übertakten.:
In order to load various modules of the kernel copy the respective script from /res/scripts to /system/etc/init.d directory and give the script executable permissions. This is optional. It is needed only if you want to use this functionality. The scripts:
- enable_conservative (load conservative governor module)
- enable_cifs (load cifs module)
- enable_netfilter (load netfilter modules for firewall or WiFi, USB tethering)
- enable_tun (load tun module)
- enable_deadline (load the deadline I/O scheduler module)
- enable_binfmt_misc
- S05_enable_oc replaces enable_ocuv since 1.6.0 (enable overclocking)
Other scripts:
- enable_sm_cold script for SpeedMod cold preset
- enable_sm_warm script for SpeedMod warm preset
- enable_sm_neutral script for SpeedMod neutral preset (please note that this is enabled by default)
[KERNEL]TalonDEV 0.4.3(0.5.1.2)[OC/UV][Voodoo Color & Sound v10][ZRAM][EXT4][BIGMEM]
[KERNEL]TalonDEV 0.4.3(0.5.1.2)[OC/UV][Voodoo Color & Sound v10][ZRAM][EXT4][BIGMEM] - xda-developers
[KERNEL] Galaxian - brings you power of the universe
[KERNEL] Galaxian - brings you power of the universe - xda-developers
[KERNEL] [26.09.2011] ***Blockbuster***Topas0.0.4***
[KERNEL] [26.09.2011] ***Blockbuster***Topas0.0.4*** - xda-developers
[KERNEL] MIDNIGHT-0.6.7/09-25/BLN/Voodoo10/UVOC/extendedCWM/...
[KERNEL] MIDNIGHT-0.6.7/09-25/BLN/Voodoo10/UVOC/extendedCWM/... - xda-developers
Hier der XDA-Link:
Installation:
Specification V5.2
- PDA: XXJVS 2.3.5
- Modem: JVS
- NOW DEODEXED
- Zipalign
- Busybox
- Symlinked
- Rooted
- Crt animation
- Modded TW4.5,
- Greeny Swype,
Credits to:
Juwe11
DAGr8
Whitehawkx
dhiru1602
Ipy - For the tweak
CHANGELOGS:
V5
V3
-gps ntp to europe.
Bilder von der Rom
Other scripts:
