[ROM] GingerCriskelo V 12
  • 37 Antworten
Markus4283
Markus4283
ROM CRISKELO GINGERBREAD
XDA: xda-developers
V77: Multiupload.com - upload your files to multiple file hosting sites!
How to install:
XXJVQ 2.3.4 mit pit und re-part via odin installieren
CF-Root xda-developers - View Single Post - [12.09.2011][CF-Root 4.1] JP*,JS*,JQ3,JV1/K/B/H/O,JVI/P/Q/R/S - su+bb+2e/CWM-rfs+ext4
v77 downloaden und auf interne sd spielen
in Recovery menü und wipen.
danach die rom auswählen und aufspielen
spaß haben :)
FullRom V77 No Wipe
*Fix text LockScreens 4Tab, Android and StasWars
*Added FIX Stock Browser
FullRom V76 No Wipe
* New features added to TW3 can select the default home from default.prop
* Fixed the text size when you start DialPad With Lirik
* Fixed text Rotary unlock full load
* Kernel Semaphore_kernel_JVQ_1.3.0 (BLN support etc.)
* Fixed LockScreen (When you unlock the phone in landscape and StarsWars 4tab the phone restarts)
* Updated talk
* Fixed loss of root in some kernels and other issues permits for the installation of the rom (rewritten scrpt installation)
* Animation of old TV off
* Transition animations
* Battery circular%
* Tweack in status bar (added the code necessary)
* Munu application and the original EDT Post creadorPara Tweaks more info
* Transparent in the shade of green and Android Notifications
* Quick menu without text
* Progress bar + volume tuned
* MMS transparent
* New transparent + author DialPad rotation
* Phone call contacts autorotation + larger photo
* Clear Contacts
* No Auto rotation mod TW3 + app + transparent + alphabetical order, without box on countless apps + pages + 5 icons in the dock
* Removed the need to activate roaming on Spanish MVNO (Yoigo, Pepephone, etc.). * Sip enabled 3G
* No incremental tone
* Google quick search Oscuto transparent
* Extended Energy Power Menu
* Backup of EFS in / sdcard / automatic EFS_BACKUP
* Rooted
* Deodexed
* Zipaligned
* Widgets grouped within the same program better organization
* Modem JVQ 2.3.4
* CF-Root 3.7 Kernel 2.3.4 JVQ
* Fixed permissions of the GPS
* Multi CSC (FOP default)
* New application to select 25 funds wallpapers interesting
* Fully compatible with CWM3
* Included My subject (and various tweaks)
* Wifi color signal
* Astronaut Boot animation
* Shortened the names of the apps in the Dock
* Email SGS 2 (with color changes in darker icons to be more visible)
* Sip translated into Spanish
* On startup sound
* 9 Lock Screen for now - Thanks to DAGr8 and Goa
* Active BLN (download BLN Pro control of Market)
* Updated list of APN
* Camera Base JVQ Hack - You can still use the camera (both stills and videos) with the battery below 15%
Camera: Just press a button, the camera and shoot!
Camcorder: one click start and then a recording click Stop following For Criskelo
* Autofocus Video
* On OVERGLOW
* New app YoyTube with optional Download videos
* Version of ROM and on about the phone theme
* Fix error in translation Forget old Samsung WIFI
* Some other things I can not remember
viel spaß beim flashen :)
Reaktionen: Xevon-Delta
Jemand schon getestet wie es läuft?:)
LG
Aussehen tuts ja schon mal schön. :)
Wow. You are so fast Criskelo. I am a fan of your rom. It is the best of about 15 rom i have used till now. I was looking if you prepared a gingerbread version and here it is. Thanks
Before flashing, is there any real, visible improvements over 2.2.1?
Hört sich auch vielversprechend an.
Also ich hab 2.3.2 drauf und hab den speedmod k13c geflasht, jetzt startet mein handy nicht mehr....wie installiert man die denn dann? da steht doch:If you have already installed the 2.3.2 stock rom
We will have to flash with ODIN, a kernel such SpeedMod 2e K13C
Once you flash this kernel enter and implement recovery
Normally as the previous step
aber ohne das handy zu starten kann ich die neue rom nicht aufs handy packen und somit auch nicht mit cwm flashen
Du sollst dann wieder in den recovery booten...
Sent from my GT-I9000
ja wenn du den kernel flasht musst du auto-reboot ausschalten und warten bis pass kommt dann die batterie raus..wieder rein und in den recovery modus booten dort mit cwm choose zip from sd und die rom installieren
hoffe ich konnte dir helfen
mfg :)
also ich habes es kurzzeitig getestet.
Läuft sehr flüssig :) nur tw stand mir persönlich im weg da mir der Gb Launcher persönlich viel mehr gefällt ansonsten ein super Rom :)
Hallo, habe mein SG erst paar Tage und noch original die JPO drauf. Kann ich einfach hierauf wechseln? Und root braucht man nicht?
was ist das für ein widget!? Kann man damit 3g und GSM umschalten!?
dialer ist nett
kann mir jemand die DialerTabActivity.apk aus der ROM hier reinstellen?
tut mir leid weiß ich wirklich nicht :( frag am besten bei den xda nach
extralife schrieb:
dialer ist nett
bitteschön hoffe ist das richtige :)
  • DialerTabActivity.apk
Reaktionen: fetteente
So - Ultibread entfernt und auf dieses ROM gewechselt.
Für mein Befinden ist DAS absolut zu empfehlen - läuft echt schnell und bis jetzt - 2 Std. gequält mit allen möglichen Sachen und nebenbei noch alles neu installiert - kein abkacken!!!
Bei Ultibread war gestern nach 2 Std. Sense.
Kann es absolut weiterempfehlen.
Kleiner Tip - zuerst Stock Ginger, Speedmodkernel und dann erst Criskelo. Hatte anfangs Probleme mit dem Display - Farbenwirrwarr.
Freu mich auf weitere Posts zum ROM.
Reaktionen: Markus4283
gibt jetzt die Versionen 13, 14 und seit gestern 15.
Hab mir die 14 eingebaut (nur update ohne wipe)
Die 15 ist wieder volles Programm.
Läuft problemlos, keine Abstürze und der Akku hält beeindruckend lang.
Kurzes Update:
V15 seit gestern oben und das Gerät wirklich heavy verwendet - Mails, Navi (CoPilot), SMS und nat. die Hauptfunktion telefonieren - der Akku ist auf 65%.
Muss sagen - passt.
Nur Darkys 9.2 oder 9.3 hielten glaub ich länger durch.
Trotzdem - ein sehr gutes GB - Rom.
Hi wollt mal Fragen wir es mit den Ram Speicher aus sieht, ich hatte bei ultibread dass Problem das der immer unter 30 mb gegangen ist und nichts mehr ging.
using tapatalk
habe immer zwischen 55 und 65 frei. Denke das erledigt der enthaltene autokiller, wenn er richti eingstellt ist.
hi , bin noch recht neu hier habe mir auch ma die rom installiert und bin auch voll zu frieden damit .
nun mein bekümmerliches prob ;)
ich steh bissel auf sehr laute musik und die voodoo soundconntrol geht ja nur mit bestimmten kernel frage ..
kann ich jetz nach dem ich denn rom drauf habe auch wieder via odin einen kernel flashen ?
danke , werde ich gleich ma flashen ;)
erster eindruck sehr fix und stabiel aber auch hier sicher weil (beda)
auch hier keine sound monifikation via voodooconfig.
