[ROM][GB] Tornado ROM XXJVR edition - ODEX - GOLD
  • 358 Antworten
reimundko
Stamm-User
27
- Basepack even smaller
- Changed to Non wipe
- Tornado app added in system/data (this way it stays after a factory reset)
- Updated market app
- Removed phonewizard entirely
- Removed samsung facebook stuff
- Removed protips
- Removed gmail
- Removed google search
- Odex based (based on official JVR)
- Phone app that does not crash (XXJVO)
- Phone app landscape mode enabled
- No theme's added (stock JVR)
- Tornado addon 0.2 (minor fixes) (add/remove system stuff)
- Basic installation of the ROM (minimal workset, removed apps installable via Tornado addon)
- Wipe edition
- Changed sounds (ringtones, ui, etc)
- SIP activated for 3G and Wifi
- Small base package (100mb)
- Added bigger APN list
- GPS change to europe.pool.org (instead of usa)
- Wifi scan changed from 15 to 45 seconds
- Zipaligned
Dazu den passenden Kernel
GTO Tornado Release Candidate 4 Version 2.3 Gingerbread 2.3.4
- Optimized kernel tweaks.
- Low memory killer minfree settings (60MB).
- Noop schedueler (Optimized).
- Touchscreen sensitivity.
- CWM 2.5.
- Root (Busybox and Superuser).
- Ext 4 support and Optimized.
- Ext 2 support and Optimized.
- Ext 2 file system conversion.
- Ext 4 file system conversion.
- RTS file system conversion.
- Memory card Speed tweak.
- 341MB Ram.
- Removed debug code (Android logging and kernel debug).
- Voodoo Sound v10 (Optimized.Removed 383 lines of useless code).
- OverClocking to 1440MHz.
- 1000MHz as default frequency.
- UnderClocking.
- UnderVolting.
- Color fix(my own).
- Sharpness fix(my own).
- Conservative governor (++)
- Custom Boot logo(my own).
- CPU steeping ( 150MHz).
- screen frequency (62Hz).
- JVR drivers from the JVR firmware/kernel.
- I/O tweak (less overhead).
- Cleanup script ( Auto remove bad script in init.d ).
- Kernel use 340Hz.
- Auto brightness ( Delay 1 seconds)
- Total wipe option
- 2 cache system option
Verdammt schnell, flüssig, absturzsicher.
Sehr lange Akkulaufzeit.
Downloadlink ROM
http://forumadds.emc2production.org/files/DamianGTO/TornadoJVR/ROM/TornadoJVRRGold.zip
Diskussionsforum: http://damiangto.emc2production.org/viewtopic.php?f=74&t=450
Downloadlink Kernel
http://www.damiangto.emc2production.org/download/file.php?id=441
Meine Einstellungen:
System auf Ext4 und Rest auf Ext4.
Neues Cache Sytem on,1000MHZ,45UV,StageFright on und Touchscreen auf Superhigh
Reaktionen: Grown, ärschärsam und 53157
Liest sich gut...Und wo ist der passende Download Link ??
Ich nutze die Kombi seit Beta-Status und bin restlos zufrieden, endliche eine Custom-ROM, die nicht mit xxx Apps zugemüllt ist und nur auf Blinki-Blinki aus ist.
Apps kann man mit dem Tornado Addon nachinstallieren, imho besser als umgekehrt.
Vorsicht bei der neuen Funktion im Recovery, "Wipe"
Das macht das Handy komplett(!) nackig...
Ansonsten recht einfach zu installieren, erst den Kernel und dann die ROM über CWM.
Dateisystem lässt sich in Ext2 umwandeln, dadurch wird das SGS richtig flott, Unterschied zu Ext4 soll wohl darin bestehen, dass Ext2 besser mit kleinen Dateien klar kommt als Ext4.
Und weil im Handy eher kleine Dateien vorkommen, also besser.
Keinerlei FC oder Lags seit der Installation, Batterieverbrauch absolut sahnemäßig, auch im Standby kein merklicher Verbrauch, was ich schon bei anderen JVR-ROMs festellen musste, da hatte ich teilweise 30% über Nacht.
Die beiden Entwickler lassen sich schön viel Zeit, statt Bananaware auf die User loszulassen, nur damit die Versionsnummer täglich steigen und eigentlich die Features nur verschlimmbessern, ein Bug entfernt, dafür 5 neue eingeschleust.
Der Kernel allein bewirkt auch bei anderen ROMs einen ungeahnten Leistungsschub, die Goa zum Beispiel mit dem Kernel ohne OC weit über 3300 Punkte im Quadrant.
Mit OC auf 1400 knackt man die 4000er Marke
Ich habe mit der Tornado ROM und Kernel in Standardeinstellung 3870 Punkte.
Ein User hat im Damian-Forum ein Video, ein SGS mit 500 Apps :scared: selbst so voll läuft das wie aus einem Guss, keinerlei Ruckler oder sonst was.
Die "Autobrightness" läuft seit der RC auch sehr befriedigend, das war in den ersten Betas noch nicht ganz optimal gelöst.
Reaktionen: raXoN
Hört sich cool an, allerdings gibts noch keine schönen Themes dafür.
Hast Du mal einen Download Link für die ROM und eine deutsche Anleitung wie ich das Rom am besten installiere.
ja sehr intressant nutze den kernel auch schon mehrere tage und find den klasse ...akkuverbrauch und stabilität sind super ...ich persöhnlich brauche auch kein BLN
lasse den aber über Goatrip laufen für mich die beste rom...
mich würde aber trotzdem mal intressieren welche lockscreens die tornado rom bietet...
ist das nur der eine im iphone style ? "slide to unlock" oder gibts da noch mehr ??? den 6 tab lockscreen von goatrip möchte ich nur ungern missen ( siehe my avatar)
Hey.Hab mir das Rom mal installiert. Wie hast du die Icons in der Statusbar verändert?
Ich kann mal die Zip Datei für die Icons und das Tastenfeld mal hochladen
Ja- Bitte.
Wo hast Du das denn her? Auf Damian`s Seite hab ich das wohl übersehen?!
kingoftf schrieb:
Es gibt ein Theme von Paul Diddy, mal im Bereich "Themes" in dem Forum suchen
GTO'S ANDROID DEVELOPERS CAVE • Login
Ansonsten müssten eigentlich alle Themes von XDA funktionieren auf Basis odexed
Ja. Den habe ich gesehen. Ich weiß aber nicht, welcher der von reimundko ist. Ich habe tornado blue. Und ich kann mir nicht vorstellen, dass der Oben abgebildete der Tornado green ist. ;-)
Reaktionen: mendiculus
Bin noch n neuling und deswegen stell ich diese Frage .
Kann ich es einfach drauf packen mit Odin wie gewohnt ? Also muss ich nichts beachten ?
Und habe die Basisbandversion XXJVP so . Kann ich es jetzt einfach wie gewohnt drauf packen ? Also muss nicht um flashen . ? ( Am besten wäre , wenn ihr mir ne kurz Anleitung schreibt . )
Bedanke mich schon mal im Vorraus
Den Kernel kannst Du per Odin flashen, einfach die .tar unter PDA eintragen, kein Haken bei Partionierung und flashen, die ROM lässt sich nur per CWM flashen.
Reaktionen: pannes und Shoot
Also ein Root habe ihc schon . Wie installiere ich CWM ?
CWM kommt mit dem Kernel automatisch
Reaktionen: Shoot
Ja ok . Wie mach ich das mit dem CWM dann ? Ich habe gerade c.a 30% reicht das für den Kernel ? Also um den Kernel zu flashen ?
Das sind wirklich Anfänger Fragen, alles steht im FAQ usw. Du kommst ins CWM indem du dein SGS erstmal ausschaltest, dann musst du "Lautstärke nach oben" + "Home Button" drücken und halten, dann auf den Powerknopf, bis du ins CWM kommst.
@raXon Das weiß ich schon . Nein ich meinte wohin ich die Rom hin legen soll in welchen Ordner .
shit .. bei hängt es ... ich komme vom Cm7 ... kernel geflasht mit odin ... dan in den recovery ... alles platt gemacht ... und die zip datei installiert ... tornado bootlogo kommt und ... hängt .... oder muss ich vorher eine stock version installieren?
mfg
Reaktionen: theKingJan
kingoftf
kingoftf
kingoftf
Radagast
beicuxhaven
beicuxhaven
beicuxhaven
  • beicuxhaven
7 8 9
Bow_Wazoo
Bow_Wazoo
