Radagast
Ehrenmitglied
- 23.366
Post 1 und Thread-Titel aktualisiert ...
Mein Test steht noch aus
humiboy schrieb:kann man die Mods wie z.B JW8_SAUROM_MOD_DialerTabActivity_norota.zip (Dialer without rotation)
auch flashen wenn man schon z.B das PaulDiddy Remix GB 2.8 Theme aufgespielt hat?
Changes in Saurom JW8 V3
New lockscreen "lezo" with music widget, missed events, personal message and wallpaper.
New option to change DPI (Settings>Saurom Menu>General Options)
New option dialer rotation (Settings>Saurom menu>Misc Settings)
New option phone rotation (Settings>Saurom Menu>Misc Settings)
New option Home button double click (with option to enable / disable, choose the application that opens, enable on lockscreen and fast double click)
New option Back buttonlong press kill application. (With option to tenable /disable,timeout and show popup info)
New option take screenshot with Home+Power or Back+Home.
New option enable/disable show popup info in toggles..
Back option theme conecction icons only if connected.
Modified option autocollapse stausbar, now works on both QuickPanel systems.
Fixed bug did not show the number of calls and messages on the lockscreen Glass.
Fixed bug data toggle did not update their status when the wifi was enabled.
Fixed bug to restore and reset values ??in jkay deluxe, well not restore some value.
Fixed bug charge state on lockscreen Xperia.
Fixed bug brightness toggle in a manner not put the appropriate value.
Fixed bug lockscreen circle to reach 20% of battery displays correct 100% stable.
Fixed bug incomming call contact name when the name was J or y.
Fixed bug set lockscreen timeout, default 5 seconds.
Fixed bug busybox for apps needing a newer version.
Fixed bug color tabs in lockscreens
Translated menus and options 100% Spanish, German, Italian and new language Portuguese (Brazil)
On Saurom Menu to pick color, shows the correct color instead of #ffffffff
Updated applications (maps, youtube, google play ..)
Default modem JW1
New Apps VoiceToGo (from SGS2 only on deodex versions) and DownloadAllfiles (to download files with any extension of the browser)
Debugging the ROM code.
Multilanguage Samsung Keyboard jw8 with 14 languages ?? (en(UK),en(US),cs,el,hu,sk,de,nl,pl,fr,it,pt,es,tr ,ko,)
Renamed (Settings>Custom Menu to Settings>Saurom Menu)
Adjusted phone.apk incallscreen layout (hold button and text)
Added Default Wallpaper to wallpaper gallery.
mikr_galaxy_s schrieb:Habe diese ROM auch gerade geflasht. Gibts irgendwo eine Option, wo man die Farbe der Statusleiste auf Schwarz ändern kann?
