[ROM] Galnet Miui Weekly 2.3.7
  • 1.258 Antworten
@ quasi
Ich hab jetzt nochmal alles wipe Format.
Und neu geflasht.
Noch immer jvk
Sent from my GT-I9000
_____________________________________
Stock Changelog
Change Log
1.9.9
i9000 Change Log:
New 720p bitrates
New Ram Tweaks and Battery Tweaks
Camera ISO Tweaks
Updated miui base to 1.9.9
Removed TouchWiz Support
Cleaned up build.prop
Used Twooey Battery Fixes
Improved Default Theme and Icons
Increased Signal and Network Speeds
New Maxthon Browser (Galnet Build)
Removed Startup Wizard
and more fixes from pervious Chameleon Builds
CHANGE LOG:
Miui base updated to 1.9.2
Improvements to network issues
New camera calls within Framework
Samsung Power Management Added
New Custom Framework
Colour and UI Tweaks
New Kernel from Vorbeth
Loads of tweaks within system
And other stuff we can't remember
Removal of Samsung Apps (Seems to be an issue samsung side which needs fixed)
- 720p Recording Tweaks (some users reported skipping still, hopefully this will fix it)
- Video Playback Tweaks
- Bluetooth file transfer and audio tweaks
- More system tweaks, and UI improvements
- Updated MIUI base to 1.8.26
CHANGE LOG
- 720p Recording Across all SGS i9000 models should be resolved! (This was a high priority fix)
- Compass working correctly (Sensors now based on Samsung Stock)
- Video Playback of HD files now works correctly (Divx via Vplayer from Market)
- New Themes (Thanks to Tad, Cold_Fusion & RosieKins) from development.
- Improved OTA Updater and now loads into Recovery after download and install (Thanks Cold_Fusion)
- Auto Brightness working correctly
- Android OS Drain resolved
- Sensors Not Sleeping Resolved
- Improved ISO Settings within Camera
- Faster Lock-on to networks and Improved Signal Strength
- Improved Audio and DSP added
- Latest Android Market Included
- Brand new Kernel thanks to Vorbeth (Question on support please ask Vorbeth)
- Charge whilst off
- Updated to MIUI base 1.8.19
- Removed un-Required files from Stock MIUI (Updater.apk, CloudService.apk etc)
- 4 Way Reboot (and reboots into Recovery)
- Improved Build.prop thanks to Vorbeth
- Improved ram handling and amount available
- Improved SD Media Scanning and SD read and write speeds
Also note we know about the following:
- In Kernel Home button is Select after upgrade!
- Data does not connect on reboot!
Change Log:
Base Updated to Official MIUI 1.8.12
Improved Camera and Video Playback
Improved booting and reboot times
Fix on missing apps after reboot
Charge whilst off (I9000 ONLY for now)
Removal of MIUI Browser and Maxthon Added
Codename Chameleon (Framework partial scripts included)
New Galnet OTA updater (With thanks to Cold_Fusion)
Improvements to Network Names and Signal Issues
Other tweaks within system
Here's what's changed:
  • MIUI 1.8.5 compatibility
  • Rom Base: Gingerbread 2.3.5
  • Multi-Language Capability: We found the cause of the last version not working correctly,
but when the 1.85. multi language packs are released they WILL work with Twooey II without any issue!
  • Battery Life: Further work has been done to improve the battery life even more! (Yes, it CAN get better than it already is!)
  • Camera: Rotation fix - With thanks to pawito for this!
  • Introduction of the GalnetMIUI Twooey theme! Now the colour changes in Twooey will make sense!
  • SuperUser: The issue has now been fixed for all users
  • More tweaks to the UI to improve smoothness
  • Changes in line with CM Nightly #78
VERSION 6.0
DSP MANAGER ADDED
TW 4.5 LAUNCHER ADDED (Thanks Fr4gg0r)
RE-WROTE POWER MANAGEMENT (Services.jar)
NEW KERNEL THANKS TO VORBETH
NEW BOOT ANIMATION (Thanks Lttldvl)
HOME SWITCHER ADDED
REMOVED 3D GALLERY
REMOVED GOOGLE WIDGETS
REMOVED OTHER UNREQUIRED FILES
NEW CREDITS AND THANKS IN UPDATE SCRIPT
2G/3G SWITCHING NOW POSSIBLE WITHOUT TURNING OFF DATA (Thanks CM7)
WHOLE ROM HAS A CLEANER FREASHER FEEL, TOUCHWIZ LAUNCHER VERY SMOOTH..!
VERSION 5.2Kernel Switched to Glitch v11
Improvements to Bitrate and Memory usages in 720p recordings
Removed Maps and Street View from Package
New Bluetooth Drivers
New WIFI Drivers
FM Drivers Included (Not activated yet)
Battery Improvements
Light Sensor now more reponsive
Faster Bootup and Loading
Camera Quality Even Better
Cleaner Build.Prop file
Other small tweaks
VERSION 5.1
Force Close On MMS Fixed
Install Issues Fixed
Lost IMEI On Install Fixed
Google Plus Application Re Added
More Tweaks To Smooth Out UI
New SuperUser Application
Setup Wizard Fixed
Market Login Issue Fixed
V5 Change Log
Brand New UI & 1.7.15 Base - (Chinese Dev's)
Faster Wifi Lock and Better Signal Strengh
Better Battery Life
Better 3G Support and Network Signal
Smoother UI and Transactions
720p Recording Near Perfect (Samsung Quality?)
Camera ISO near Samsung Quality
New Android Market (Slightly Modified)
Kernel Changed to Neo 11
DSP Application Removed (Chinese Devs)
V4 Change Log
- New Galnet Mod Within Framework
- Galnet-Vorbeth-Zach Kernel Included
- Quicker SD Card Access
- Improved WIFI Lock and Signal
- New MIUI Android Boot Animation
- 3G / 2G Selection Fixed
- Other small issues and fixes on 1.7.8 release
v3.4
Nope no change log!
Unless you want it:
- Fixed Battery Stats
- Improved SD Card to USB Connection Speed (don't know if people who are on v3.4 have noticed this??!?)
- Cleaned Up A Lot Of Dirty Coding
- Other small fixes and tweaks
Basically v3.4 is the fastest, smoothest version of all the v3 releases!
V3
Improved 720p Recording
Improved ISO Settings in Camera
Brand New Kernel with Added Tools and Options (Vorbeth & Galnet)
Brand New Updater-Script (Identifies your install and wipes according to rom)
Battery Stats Backup and Restore (No more battery calibration required)
Google Apps Included (Navigation, Search, etc)
Development for FM Radio Addition Applied
Brand New Boot Animation
Brand New Theme (Thanks to Lippol)
System Speed Tweaks
Backlight Notifications
Vast Battery Improvements
Captive Version Now Available(not tested)
Quicker SD Scanning and Improved 3D Abilities
3D Chainfire Added
Removed WhatsApp
Improved Galnet Updater Application
Improved GalnetMiui Server
V3.1
Improved Install Process
Improved Ram Handling
Improved Video Playback
Fixed Bootloop Issues
Fixed Keyboard FC Issues
Fixed LED issues
Fixed SU Issues
v3.2
FIXED LOADING ISSUES (Due to Provision and SetupWizard)
RESTORED BOOT ANIMATION TO OLD ONE
IMPROVED FPS IN 720p RECORDING
ADITIONAL TWEAKS TO UI
SIGNAL ISSUES (Data dropping etc) FIXED
ENGLISH LANGUAGE PACK UPDATED
v3.3.
CUSTOM FRAMEWORK ADDED (MORE STABLE)
UI SCREEN NOTIFICATION (SCROLLER) RE-ADDED
SLIGHT ADJUSTMENTS TO CAMERA AND CAMCORDER
DISPLAY FIXES (BLACK IS BLACK, WHITE IS WHITE)
OTHER SMALL ISSUES FIXED
All V3 Versions Have been updated to MIUI 1.7.1 (Change Log at
http://www.miuiandroid.com)
v2.2
MASIVE BATTERY IMPROVEMENTS (DUE TO KERNEL & SYSTEM CHANGES)
Multi Language Pack Included (thanks el afortunado)
Neo 10 MIUI Kernel Added
Framework Patches
Removed 720p Recording Until Friday
Other Small Fixes and Clean Up's
v2.1
Sensor Adjustments
OTA Updater Included
New Clock Widgets
Re-Applied Reboot after Theme/Toggles Switch (to help prevent errors)
Other Small Fixes
V2.0+
720p Finally Fixed
Video Playback Improvements
Power and Reliability Improvements
Speed Improvements with UI
New YouTube Application
Display Improvements (Colour & Hue)
Other small tweaks and improvements.
Version 2.0
Framework Modified
Updater FC Issue Resolved
New Lockscreen (Activated via Theme Manager)
Light Sensor Adjustments
SU Issues Resolved
3D Fix Applied
Removed Unrequired Files and Frameworks
Updated to MIUI 1.6.24 (Change Log at http://www.miuiandroid.com)
Funktioniert nun eigentlich die Pin Abfrage bei bestimmten Lookscreens ?
wie bereits erwähnt:
meine Kernel-Skripte enthalten einen abgeänderte Variante von Juwe11's Skript schon länger
also nicht beides installieren, denn das beißt sich :thumbdn:
720p Aufnahme ist immer noch nicht vollständig gefixt. Ich hab zwar lange nicht mehr so viele Hänger und Ruckler drin wie vorher, aber von der Qualität eines Stock Roms ist das noch weit entfernt.
Komischerweise scheint das Problem nur bei der MIUI Cam aufzutreten, mit der AOSP Cam scheints zu funktionieren...
Neo9 Kernel funktioniert sehr gut. AKKU Verbrauch hat sich drastisch gesenkt bei mir.
sorry OL
aber nach 10 std kannst beim besten willen noch nix über den akku sagen ;)
Erstens ist der Kernel seit über 24 Stunden raus und ich finde schon dass man nach dieser Zeit schon was über den Akku sagen kann.
lazy ..... sorry aber .. woher weist du wann er geladen hat ;).. aber es ist allgemein bekannt das sich die akkulaufzeit erst in 2 bis 4 tage effektiv einpendelt .....
brauchst nur guggen ... am ersten tag hörst überall ...... akku so gut und dann kommt das gejammer das der akku nicht mehr hält .....
genaugenommen kannst sowieso erst nach einem 10 tagesschnitt wirklich sagen ob sich was veräbdert hat oder nicht .... es sei denn es ist eine imense veränderung
aber ich muss sagen ( bin glitch fan) neo 9 geht echt super und hat ein super akkuverhältnis
Naja ich habe das gerät heute gequält und den Kernel seit gestern drauf.
Galnet hat sich bezüglich MCGv Version noch mal zu Wort gemeldet!
KLICK Du xda
Originaltext: It will never be just M, Mambo has my full backing. I'm 100% dedicated to helping him, it's just that with his absence I decided it be best I started developing my own version to Keep the forum and (OP) up to date.
I'm more than happy to help Mambo or should Mambo wish to help me then that's fine also..!
Currydude will be back after his studies and then full speed development will once again return.!
If it means me doing 2 versions, one with my own mods, and one without so be it, I'm always going to be here to help...!
After all who got MIUI booting on our devices to start with, yep Mambo, so I have a heck of a lot of respect for the guy!
Regards,
Mat.
Edit: Post 1 und 2 ist Aktualisiert!
Archiv Roms
- Weekly BUILDS – 1.12.3
Samsung Galaxy S
File Size: 113MB
Languages Supported: English
- Weekly BUILDS – 1.12.2
Samsung Galaxy S
File Size: 113MB
My Multidownload
- Weekly BUILDS – 1.11.27
Our roms are packed so all you have to do is download and install via Recovery.
Samsung Galaxy S
File Size: 113MB
http://ota.miuiscotland.co.uk/ota/1.11.27/miuiscotland_I9000-1.11.27.zip
MODS 1.11.27:
  • Video playback fixes within Galnet MIUI Video Player
  • Improved GPU handling
  • I9000 Camera Fixes
  • I9000 720p recording improvemts
  • I9000 WIFI Improvements (signal)
  • I9000 Improved Contrast and Brightness
  • 4 way reboot removed (causing issues in latest builds)
Like China MIUI we are working hard on Android 4.0 Migration into MIUI, updates will be coming soon.
1.11.25
Samsung Galaxy S
File Size: 111MB
http://ota.miuiscotland.co.uk/ota/1.11.25/miuiscotland_I9000-1.11.25.zip
MODS:
CHINA 1.11.25 - Recommended updates:
1.11.18
Samsung Galaxy S
File Size: 110MB
http://31.31.36.191/ota/1.11.18/miuiscotland_I9000-1.11.18.zip
MODS:
1.11.11
Samsung Galaxy S
File Size: 110MB
http://31.31.36.191/ota/1.11.11/miuiscotland_I9000-1.11.11.zip
1.11.04
File Size: 112MB
MD5: fdc04a5ef5e81b3cecf4754815c85139
http://rommaster.miuiscotland.co.uk/ota/1.11.4/miuiscotland_I9000-1.11.4.zip
Spachpakete von flo2075
- weekly 1.10.28 http://dl.dropbox.com/u/2872702/I900....28-DE-flo.zip
- stable 2.10.21 http://dl.dropbox.com/u/2872702/I900....21-DE-flo.zip
1.10.28
Samsung Galaxy S
File Size: 117MB
MD5: 1fc9e4daacee382d04360f16ba3c54f2
http://rommaster.miuiscotland.co.uk/ota/1.10.28/miuiscotland_I9000-1.10.28.zip
Stable Builds
– 2.10.21 – Based on 1.10.14
Our stable roms are based on older versions of MIUI,
the reason behind this is that these builds have been developed to run smoothly on the given framework.
If you are after a newer framework then please look at our weekly builds,
these are based on the latest releases from China.
Our roms are packed so all you have to do is copy them across to your Internal SD Card, enter Recovery and Flash.
Please check our forums for detailed guides on how to prepare your phone should you be on your Mobiles Stock Firmware.
File Size: 123MB
MD5: 612258feffcf5d5849e2b50d009758ad
Upload von drigg0r Danke!
2.10.21 in Deutsch (sprich die aktuelle stable Version in Deutsch)
Multiupload.com - upload your files to multiple file hosting sites!
1.10.22
File Size: 119MB
MD5: d882b2d5c9c17f0a0eddaac56f8da1f7
1.10.14V2
File Size: 117MB
MD5: 76ed851d13efa6e636f8cc0e0a7cb023
1.10.14
File Size: 114MB
MD5: ba09ba602584dd80f1d4658fe4ae44bf
Based on 1.10.8
File Size: 108MB
MD5: fe1774091592301ed7cba61ff1a6f099
Galnet MIUI Scotland Change Log:
  • Divx and HD video support now supported across all devices.
  • Improvements in signal issues on i9100
  • Sound improvements on i9100
  • Camera improvements on i9100
  • Power saving (Samsung) now support on i9100, i9000, i897
  • Defy issues with time stopping repaired
  • 4 Way Reboot Added
MultiLang 1.10.8 Weekly for i9000
Es, It, Vi, Tr, Sl, Ru, Pt, Hu, Fr, Da, De.
_________________________________________________________________________
Based on 1.9.30
Samsung Galaxy S
File Size: 103MB
MD5: 7ce430362d5e99986d90a9b5930b0e7c
Languages Supported: English/Multi
– Based on 1.9.23
i9000
Samsung Galaxy S
File Size: 104MB
MD5: 934cdf7eebe0f2431903766e358c760e
Die vom Handy aus Downloaden wollen
habe Ich einen weiteren Upload gemacht
mmmuuhh`s Spachpaket LP-EnDe-1.9.23.zip
Based on 1.9.16
Our stable roms are based on older versions of MIUI, the reason behind this is that these builds have been developed to run smoothly on the given framework.
If you are after a newer framework then please look at our weekly builds, these are based on the latest releases from China.
http://www.galnetmiui.co.uk/OTA/23-09-2011/STABLE/Stable-2-9-23-i9000.zip
Mit EN/DE Sprachpaket von Andy25 kommt noch von mmuuhh. Danke!
Chameleon-Final-i9000_EN.DE
vollversion, lp von miui germany
Chameleon Final Version - 13-09-2011
Basiert auf 1.9.9
i9000
http://www.galnetmiui.co.uk/chameleon/final/Chameleon-Final-i9000.zip
MD5: f7912ba49e6554aa5eab4cbb44ab5b7e
__________________
Sein für MIUI.us gemachtes wurde schon getestet.
Neu
Chameleon RC3
Download Here
_________________________________________________________________________________________________
Alt
Mit EN/DE Sprachpaket von Andy25 integriert zum Testen von mmuuhh. Danke!
Chameleon-RC2-i9000-EN-DE - Galnet Version
enthält alle apps der Galnet originalversion
Chameleon-RC2-i9000-EN-DE - Slim Version
3dGallery, Gmail, Samsungapps, Talk entfernt
Chameleon-RC2
Download Here
Chameleon-RC1-i9000-EN-DE
Galnet Version
Chameleon-RC1-i9000-EN-DE-slim
Slim Version
Chameleon RC1
Download Here
Sprachpaket von mmuuhh steht zum Testen unter Sprachpakete schon zur Verfügung
Chameleon V11 Public Beta
Chameleon-V11-BETA-EN-DE
http://dl.dropbox.com/u/31685625/Miu...BETA-EN-DE.zip
Chameleon-V11-BETA-EN-DE (slim version)
lp andy25
maxton browser, gmail, talk, samsungapps, setupwizard, updater, 3dgallery und telocationprovider entfernt
miui browser hinzugefügt
Originalversion von Galnet
Downlod Here
GalnetMIUI Twooey: Twooey III gefixt
Download Here
MD5: N/A
http://bit.ly/ofeve4
MD5: f3a0e2fcab3f9e2c7a2323e8c1dc318c
Alt
GalnetMIUI Twooey
DOWNLOAD NOW
For more information including download links and help please visit the official GALNET MIUI website at:
Regards,
Mat.
v6.0
  • integriert - aktualiesierter (vom 22.07.2011) Vorbeth Kernel
  • Neu mit zur Wahl - integriertem TW 4.5 Launcher
Mirror 1 - http://www.galnetmiui.co.uk/v6/galnet-miui-v6.zip
Mirror 2 - http://www.chameleonwebhosting.com/galnetmiui/galnet-miui-v6.zip
Mirror 3 - http://dara.pingtimeout.net/galnet/galnet-miui-v6.zip
v5.2
DOWNLOAD HERE
MD5: aed81ad7aea11cf67c19dfbdbc4d15f4
v5
.1
Download Here
MD5: 298dc5c977d5a42adb36b6c01f34ec20
v5
Download Here
https://www.android-hilfe.de/forum/...behoer-uebergreifend.124700.html#post-1715291
Alt
GalnetMIUI - Version 4.1 Online
What's Changed?
There has been a massive number of improvements made since the last version of GalnetMIUI
  • New Boot Animation
  • New About Phone Screen
  • 720p Encoding File Updated
  • Kernel Change Vorbeth v1 CM7-MIUI-i9000 - No Voodoo
  • Google+ Application for users who can't find it on the market!
  • Other Small tweaks to framework (More Stable)
v4
DOWNLOAD HERE
PLEASE NOTE
MCG or Other MIUI Types can be updated by Wiping Cache & System Only.
Other users will have to follow the install guide in the manual above!
hm.. ist leider keien VC version des glitch kernels. habe einen hässlichen grünstich.
bei mir werden auch irgendwie app einstellungen nicht wiederhergestellt von 1.6.17...
das schlimmste ist: die kamera hat eine grausame qualität in dunkler umgebung. was ist denn da los... das geht gar nicht!
Und mit dem Sprachpaket geht Tethering wieder mal nicht.
Ist bekannt und ich bin echt intensiv auf der Fehlersuche :-(
@ Boogie
Bei galnet ist ja schon deutsch drin. Da geht auch kein tetering.
Kanns sein das da zwischen dem Paketen irgendwie einem Konflikt gibt? Auf englisch zurück geht nämlich wieder alles.
In galnets multilanguage pack ist mein sprachpaket drin ;-) daher der gleiche Fehler. Aber ich hoffe heute noch ne Lösung zu finden.
Wäre toll :) Dann wäre es perfekt...:D
Also so gestochen scharf Bilder beim ablichten aussehen mögen. So unscharf sind sie nachher in der Galerie und am pc :-(
kingoftf
kingoftf
kingoftf
Donald Nice
DrMole
DrMole
wemsinho
Lion13
Lion13
