[ROM] GALAXIAN <> NEW: v5 <> Supercharged Stock GB, Galaxian Kernel [18.01.]
  • 18 Antworten
Radagast
Radagast
Ehrenmitglied
23.366
********* NEW ----> V5 avaible <----*************
seit 18.01.2012
möchte Euch mal die Custom-Rom von Lukiqq vorstellen, welcher kein geringerer ist als auch der "Macher" des
Galaxian_logo.png - Kernels
ACHTUNG:
- Ich übernehme keine Haftung ... usw
WIPE! THIS ROM CONTAINS EXT4 AUTOCONVERT SCRIPT WHICH MEANS THAT IT WILL FORMAT YOUR PARTITIONS*! ---------> ABER:
- DON'T WANT TO WIPE? NOT A PROBLEM! Just replace META-INF\com\google\android\updater-script with the one from attached archive and you will get no-wipe version
- Vor dem Flashen: EFS sichern / Backup machen !!!
- Only WIPE-Version
- CSC unknown bei User Aceshigh --> kein Multi-CSC
Dies nur als Warnung, was passieren kann
Rom-Features:
  • Galaxian kernel based on most recent initramfs with CIFS module build in and 344MB RAM
  • automatically converting all RFS -> EXT4 partitions when apply (navenedrob) [never used in any other SGS ROM before]
  • deodexed by me
  • removed useless, battery eating debug infos from framework files
  • BLN support
  • no lag browser
  • photo editor ported from SGS2
  • stock VoiceRecorder app is now recording in .3ga format (3GPP) like SGS2, instead of old scratchy .amr - huge improvement in recording quality (44kHZ instead of 8kHZ and multiple times higher bitrate)
  • dock menu in Settings
  • added 45 seconds display timeout in Settings
  • completely removed Software Update from Settings menu and corresponding OTA files (no more useless OTA service in RAM)
  • CRT effect on display ON and OFF
  • no overscroll glow effect
  • mixed libs to better performance
  • XXJVT modem
  • new lights sensor library
  • adjusted light sensor steps for better accuracy
  • Epic 4G TouchWiz4 Launcher
  • KiesAir included
  • SGS2 keyboard with 20 T9 languages
  • slightly modified stock theme
  • battery icon with percentages with 1% step
  • replaced icons and graphics in some apps for better looking
  • AOSP lockscreen with custom wallpaper support
  • 18 Samsung livewallpapers from different phone models
  • notifications icons mixed with those from SGS2 & Nexus S
  • DTMF tones instead of Waterdrop when using keypad
  • extended power menu without title
  • SMS hack
  • hacked Camera app. with Camcoder shortcut enabled instead of separate app.
  • modern looking stock Gallery
  • updated GAPPS
  • removed some useless and ugly looking Samsung widgets
  • News & Weather widget from Nexus S
  • new boot and shutdown animation
  • tons of new ringtones and notification sounds (HTC + Samsung Droid Charge + Nexus S and others)
  • Talk2 with video support
Original-Post auf XDA:
Die Rom beinhaltet ... wer mag es glauben .. den Galaxian-Kernel.
Die Grund-Infos seht Ihr ja schon in der Titel-Zeile.
Weitere Rom-Features ...... siehe Post 2
Ich werde, soweit es mir möglich ist, diesen Thread auf dem Laufenden halten.
Habe mit Lukiqq, dem "Macher", Kontakt gehabt und seine Erlaubnis, die Rom hier einzustellen.
Den Link zu unserem Forum bzw. zu diesem Thread habe ich ihm zugesendet, vielleicht läßt er sich ja mal hier blicken.
Mein Erfahrung mit der Rom bisher, nur V3
- Stabil
- noch etwas langsam beim Starten von Apps und im Menü, was dem Quadrant-Benchmark etwas widerspricht .... (das ist einer der Gründe, warum ich von Benchmarks nichts halte !!!)
Allerdings berichten viele User, die Rom sei "unbelievible fast"
Dazu die Anmerkung von Lukiqq in seinem Thread:
Previous update:
- no more lags after few days of usage
- some minor fixes"
- Akku im ersten Durchlauf schon relativ ordentlich
- Weiteres siehe Schreenshot ... Bilder sagen mehr als tausend Worte :flapper:
Download-Link aktuellste, V5:
Hier die Screen-Shots:
Solltet Ihr Verbesserungs- oder Änderungsvorschläge für den Start-Post, immer gerne her damit ... (wie z.b. weitere Screenshots o. ä.) .... seit gnädig mit mir, biiiiiitte ;-)
Dennoch empfehle ich jedem, sich den Original-Thread mal durchzulesen ...
Vielen Dank, bvt-1
Reaktionen: raXoN
Changelog
V5 MAIN CHANGES
  • AOSP lockscreen with custom wallpaper support and removed vibrations on sliders touch
  • TouchWiz3 with semitransparent applications menu
  • keyboard sounds are now calmer
  • removed CRT-ON animation because of its lag
  • BT issue fixed
  • Galaxian kernel 1.2 with some minor changes
  • CWM installation script changed
V4 MAIN CHANGES
  • no more lag when using TouchWiz IndexScrollView (Contacts list, Music Player)
  • notification area is now looking better (i9001/Player appearance)
  • updated JVU_V1 kernel (battery charging, touchscreen adjustments, light sensor)
  • updated GAPS (Maps, GoogleSearch) and bundled software
  • auto brightness steps adjust (lower minimum value)
  • new Email app from different Samsung model
V3 MAIN CHANGES
  • fixed problems connected to the missing CSC
  • stock Android first startup wizard
  • XXJVU Modem
  • rebuilded Galaxian kernel JVU-V1 based on JVU initramfs (more stable, wifi buffer, tuned colors)
  • disabled scrolling cache at all
  • less debug infos when using TouchWiz scrolling modules (Contacts for ex.)
  • nicer transitions animation, fancy onscreen keypad animation
  • updated GAPS (Maps, Market) and bundled software
  • Nexus S volume panel behaviour (vibrates twice when muted)
V2 MAIN CHANGES
  • TouchWiz3 instead of 4 because of speed and no lag. There are 5 homescreens by default with third as home screen. Default number of available homescreens and default homescreen can be changed by editing default.prop file in /system.
  • possibility to choose phone language after first boot
  • sound effects are now calmer because of audio definition files taken from Captivate
  • new WeatherWidget version with default 4x2 size
  • Clock app is now able to manage up to 255 alarms instead of standard 10
  • replaced libsql.so library
Zum Kernel das Wichtigste hier:
Weiteres im Original-Thread auf XDA: [KERNEL] GALAXIAN [344MB][JW1][Voodoo Sound][EXT4][BLN][COLOR] - xda-developers
Most recent update (V3):
---> Flash per Odin, ohne pit / repart /bootloader ---> im Feld PDA, versteht sich
DOWNLOAD HERE!
- fixed video calls (bad front camera driver used)
- 344MB of RAM without loosing video calls and hd recording capability
- slightly brighter overall image
- reduced red tint on low brightness setting
- about 5% quieter built in internal speaker to prevent of distortions at max. power
V2:
DOWNLOAD HERE!
- fully working MDNIE profiles! Galaxian is the first kernel (of these well-known) that fully supports MDNIE profiles, both for Outdoor Mode as well as for Normal Mode (check it in Video Player for example)
- reduced green color for about 3%
- image sharpened for about 1%
V1:
DOWNLOAD HERE!
- based on XWJW1 initramfs
- 340MB of RAM without negative side effects like loosing 720p support
- impressive speed and responsiveness increase because of the new compilation flags
- adjusted SAMOLED gamma levels and MDNIE profiles for better colors, saturation and sharpness
- fine tuned camera driver for better captured images quality
- updated su binary and Superuser.apk
- some minor changes
Previous update:
- some minor fixes
- 338MB of RAM
Previous update:
GalaxianEE only
- /system is mounted as read only by default (if you are using SUPERSONIC ROM you can use "remount rw|ro" command to remount it to be rw or ro)
- root privileges turned on by default (you are now able to push something directly to the /system directory after remount as rw)
- uncapped charging current USB (96mA < 500mA) / AC (600mA < 800mA) [say whatever you want, this is SAFE and will not harm your device!]
habe mir mal die v2 geflasht....läuft bei mir nicht so smooth wie alle im xda behaupten...
hab ich denn was falsch gemacht beim flashen? habe zuerst jvt stock und dann die rom..
Bei mir bleibt sie total oft beim Taskmanager kleben, wenn ich manuell den RAM freigeben will ... Von daher bleibe ich doch lieber bei Resistance :)
hatte sie auch geflasht ... lief erst nicht so smooth, dann aber etwas besser.
Habe das aber aus dem XDA-Forum gezogen, hatte mit Deinem Beitrag, Bvt-1, nichts zu tun.
Fireworker und Ridgeback:
Habt Ihr einen CSC-Code?
meiner war nach Flash unknown ... ?!?
bvt-1: Hast Du CSC-Code?
@Fireworker:
Deine Vorgehensweise ist korrekt ... Sollte eigentlich laufen. Aber gib dem System noch einen Tag, dann sollte es besser alufen. bei mir auch erst recht langsam, mittlerweile besser
@Ridgeback:
Das tut mir leid ... Das Problem habe ich nicht .. Kann aber verstehen, wenn Du zurück flasht ...
@Aceshigh:
Habe im XDA-Forum mal an Lukiqq gefragt, wie das sein kann ....
Kannst mal die App "ProductCodeChecker" downloaden aus dem Market, was da dann steht.
Aber das übersteigt generell mein Wissen, d.h., das Wiederherstellen.
Efs gesichert?
Habe das im Erst-Post mal in die Warnung mit aufgenommen ...
Reaktionen: Aceshigh
bvt-1 schrieb:
@Aceshigh:
Efs gesichert?
Nee, nicht gesichert. Habe da aber mit Donald Nice schon was gemacht, weil ich das Problem "CSC-Unknown" im Forum erfragt hatte ...
Aber wenns da was Neues gibt, ruhig mal hier einstellen ...
Also braucht die rom zeit um zu laufen?hmmm oke werde sie nochmal flashen...aber warum läuft die rom erst mit der zeit besser?
ok ich habe sie jetzt was länger getestet und ich muss sagen das die rom jetzt besser läuft!
bleibe aber trotzdem lieber bei der f1 innovation hd....habe das gefühl die läuft besser :)
Ja, hatte mich auch etwas gewundert, daß die Rom später besser läuft. Vom Akku kennt man das, von einer Rom kannte ich das bisher auch noch nicht...
Im XDA-Thread wird Thunderbolt empfolhen .. habe ich selbst aber nicht drauf, kann also nichts darüber sagen. Werde ich leider erst Montag testen können ...
Kann jemand nachvollziehen, ob der Akku tatsächlich wie im ersten Post von Luciq beschrieben 5 Tage lang hält? Kann ich mir nicht vorstellen. Wenn, dann im Dauerstandby und ohne Daten- oder WLAN-Verbindung.
Lukiqq hatte gesagt beim minimal gebrauch...aber das schafft fasst jeder rom bei minimal gebrauch...
V3 ist raus. Wollte heute Nacht schon ändern, aber da konnte ich meine Beiträge nicht ändern.
DrMole kümmert sich ...
Wird dann heute Abend erledigt ...
Und hat schon wer die v3 drauf? Wie läuft die? Braucht die auch eingewöhnungszeit? ^^
kann ich leider erst heute Abend aufspielen... werde dann mal berichten, ob es von vornherein flüssiger läuft ...
Edit:
Muß leider auch zugeben, daß die Rom nicht so mein Ding ist ... auch mit Thunderbolt nicht.
Da gibt es einige Roms, die besser laufen.
Bei der nächsten Rom-Vorstellung werde ich vorher länger testen (mind. 4 Tage, als mein persönliches Ziel)
Werde in Kürze mal eine andere Rom testen, die auf XDA ist, aber hier noch nicht ...
FÜR VERBESSERUNGSVORSCHLÄGE bin ich immer noch zu haben !!!!
----- und werde den Thread bestmöglich pflegen und ab und an wieder diese Rom fllashen, um zu
wissen, wovon ich rede, wenn eine neue Version kommt ----------------
@Aceshigh:
Sorry für die Umstände, die Du hattest, aber Donald hat Dir geholfen, schriebst Du ..fürs nächste Mal weißt Du ja nun hoffentlich bescheid .. EFS-Sicherung usw. ...
Neuer Post, da mittlerweile v5 draußen ist ....
:blushing: hatte v3 als letzten Stand :blushing:
mal eben alles geändert .....
Viel Spaß :thumbsup:
So, hier wird es nicht weitergehen, denn:
Lukiqq schrieb:
All good things come to an end... Today I gave my Galaxy S to my father, because of his age he needs it more than me (relative big and easy to read display). Now I have Xperia Neo V which seems to be not that bad ;) Thank you guys for all your support!
Sent from my GT-I9000 using XDA App
Dieser Thread kann also geschlossen werden ... Schade drum! :(
Gesendet von meinem GT-I9000 mit der Android-Hilfe.de App
Schade er war ein sehr guter Dev... aber GB Roms sind eh kurz vorm Aussterben:)
Eeeeey, nee :thumbdn:
Will ich nicht :winki:
Habe noch keine wirklich gute ICS-Rom gefunden, alle ordentlich Battery-Drain oder Toggles fehlen oder oder oder ...
Ich stehe voll auf Stock :smile:
Nun, da hier ja in Kürze geschlossen wird, ist dieser OT ja egal :sneaky:
kingoftf
kingoftf
kingoftf
beicuxhaven
  • beicuxhaven
7 8 9
Bow_Wazoo
Bow_Wazoo
jodahush
