galaxyS-rookie
Stamm-User
- 237
ich möchte euch hier ein ROM vorstellen.
Continuum v6.1 [JVQ]
Feature List
Built on I9000XXJVQ
Talon kernel TalonDEV-0.3.2-T3-1000
Modem I9000TJJJV5
Rooted, deodexed, zipaligned
Tweaked Touchwiz 3 with landscape support.
Extended power menu
9 lockscreens - Lockscreen Wallpaper and sound can be set for all of them.
MMS/SMS removed from logs
Hacked camera: taking pictures/videos with power button and on low battery - you do not need to long press the power button to focus, just press once and it focuses automatically before shooting.
Home haptic feedback
Option to enable/disable GPS tagging in Camera
Phone without ascending ringtone.
Link voice call volume with notification volume option in Settings
Killed battery full notification.
Dolphin Mini Browser
Separate tones for Volume setting (each volume intensity has a different sound when pressing the volume keys)
Removed several useless fields in Settings.
Added back keep the screen on in Development settings.
Wifi scan interval increased to 30 sec
Samsung Keyboard with 30 dictionaries for XT9
Bash shell
Simple scripts for fast mounting /system as ro and rw (just type ro or rw in the terminal emulator -requires su- or in a adb shell session)
3D rendering fixed
Tegra 2 Games capability
Perfect keyboard (replacing GB kb) thanks to for.digit @ xda
SIP configuration in Call settings
Landscape Dialer
Landscape Phone
Landscape GB Launcher with option to drop to uninstall
Sony ARC Launcher
Fixed auto brightness
Working BLN
Fixed market fingerprint
Updated system apps
Important notes on lockscreens:
MIUI and 4Tab lockscreens have a custom button that needs an application assigned to it before using - this is done in the TSM/lockscreen menu in Settings. On MIUI is the right button, on 4Tab is the right corner up button. Using this button without an application assigned will generate a hot reboot
SGS2 lockscreen wallpaper (if you set one) can be unset by deleting the following file: /data/data/com.cooliris.media/files/zzzzzz_lockscreen_wallpaper.jpg
All AOSP lockscreens now have music controls
Music controls work with any other player than the samsung one.
Double tapping the little lock on the MIUI lockscreen brings up music controls.
Toggle permanent music controls visibility from the TSM menu in Settings.
Screens
Download - non WIPE
Download - WIPE
Installation
Originallink
Feature List
Built on I9000XXJVQ
Modem I9000TJJJV5
Extended power menu
Bash shell
3D rendering fixed
Landscape Dialer
Landscape Phone
Sony ARC Launcher
Working BLN
Updated system apps
Screens
Download - non WIPE
Download - WIPE
Installation
- auf die interne Speicherkarte kopieren
- Recovery Modus starten (Vol up + Home + Power)
- install zip from sd card
- chose zip from sdcard
- zip Datei suchen und auswählen
- YES
- kurz warten
- reboot
- der erste Boot dauert
- fertig
Originallink
