[ROM][16.04.11] c0llal0-rel0ad3d-2.0 [XXJVB]
  • 278 Antworten
elviroo
elviroo
Stamm-User
249
presenting
c0llal0-rel0ad3d
based on stock Gingerbread JVB
standards for both rom-devel-trees
deodexed, zipaligned, rooted, busybox 1.19, european gps config,
wipe for both only the updates (post2) are non wipe!,
no boot nor shutdown sound, no shutdown video, no boot animation,
bluetooth/audio.conf changed, ripped most sound files, adfree app,
appwidgetpicker, sgstools, custom build.prop, init.d folder with zipalign
and sdcard speedhack, jvk-modem
version 1.x devel-tree
csc files like in JVK-Rom (CPW, DBT, KOR, XEO & XEU), bloatware remains --> this is a full rom,
stock jvb-kernel, should be flashed on cwm2.x(kernel-flashing issue)
tek a look @ post 2 for updates
version 2.x devel-tree
only one csc file (XEU), removed a lot of stuff like samsung bloatware,
google apps and those debugging tools --> tek a look @ attachement 01,
supercurio hacked gingerbread(jvb)-kenel,
fully cwm3.x compatible(xtra credits to romkitchen devs for this)
on post 2 u get updates and additional stuff
framework for both roms
first step of customized framework, gives u 5-lockscreens
(fully workin), crt-off animation, extended power menu,
ginger glow effect, transparent statusbar and battery
with percentage shown. most icons still stock
get the framework files FileFactory Premium
ef u have the full rom 1.0 installed get update 1 from post 2 first!
when flashing is done wipe cache and wipe dalvik cache twice
installation
mek a backup before
this will wipe ur data
ef u have a froyo based rom
mek sure u get some fresh bootloaders ... u get dem
when flashing a stock gingerbread rom with odin!
DON´T FLASH BOOTLOADERS ALONE ... details
Gingerbread Roms and detailed flash info here
ef u have gingerbread already
just flash usin`cwm! this one is edify scripted!
kernel wont get flashed ef u use cwm 3.05 (issue on version 1.0 only)
... will be fixed later for sure!!!
credits
all the rom-cookers me learn from and copied from
specially Darkyy, Tricky, Doc and nitr8
coders that coded these nice tools me play wit
specially Daneshm90
credits to chainfire, supercurio, hardcore and nikademus
for the nice kernels dem promote
my mom and dad
Installation (deutsch)
wenn ihr gingerbread mit bootloadern habt: cf-root flashen und darüber die zip von der sd karte installieren.
wenn euch das alles nichts sagt: https://www.android-hilfe.de/forum/...dbt-root-cwm-tv-screenoff-overglow.95766.html
here me a go post u some addons, changes and fixes
version 1.0 stuff
Update to Version 1.1b
it will not wipe ur data
market update to 2.3.6
swype update to 2.29.71.20203.t100
gingerbread keyboard added
hacked browser v1.2 (tabs&useragent)
kernel changed too voodoo jvb hack
cwm3 flashable zip-file File Not Found - Filefactory.com
version 2.0 stuff
Google-Apps & TW Calender AddOn
this file will bring gmail, twcalender and
syncronize function back into version 2 rom ef u like
cwm3 flashable zip-file Google&Calender-StuffAddOn.zip - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
Google Maps AddOn
this file will bring google maps & navigation back into
cwm3 flashable zip-file GoogleMaps_AddOn.zip - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
Samsung Kies (MTP)
this file will bring mtp.apk and needed libs back into version 2 rom ef u like
cwm3 flashable zip-file 04_Samsung_Kies.zip - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
FM Radio
ef somebody is missing fm-radio on version 2 rom here u go
cwm3 flashable zip-file 01_FMRadio.zip - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
Speech Synthesis
for pico speech synthesis flash this one
cwm3 flashable zip-file 03_SpeechSynthesis.zip - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
AddOns
Sound Files
with this zip file u get a lot of sounds
cwm3 flashable zip-file ringtone_addon.zip - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
Reaktionen: firethorn, `werdinho, kon1 und 10 andere
Cool das werde ich mir heute mal drauf bauen!
Hast Du es schon laufen?
läuft spitze!
c0llal0 ist derzeit fleißig am arbeiten. heute nacht will er noch stock lockscreen overscroll und lock animation hinzufügen. dann ist es für mich das perfekte rom, denke ich ;)
würde dir raten vorher die jvb draufzuhauen, da es grad noch probleme mit dem kernel gibt. dann hast du den jvb kernel sicher mit drauf.
Reaktionen: Randall Flagg und boardmaster2009
Kannst du mir bitte kurz erklären, wie ich das drauf bekomme ? Blicke da nicht ganz durch. Es reichen kurze stichpunkte ;-) danke schon mal!
---Getaptalked von unterwegs---
Du bist der Mann Elviroo, 1000 dank ;-) danke gibts später vom pc aus!
Habe heute keinen Nerv mehr,mein Handy neu einzurichten.
Werde dann mal auf das angekündigte Update mit Screenoff und den ganzen Nettigkeiten warten.
Irgendwie juckt es mir in den Fingern aber jetzt 2-3 Stunden alles neu einrichten...Nö...:winki:
Außerdem laufen seit heute die NBA-Playoffs,da habe ich eh keine Zeit für sowas.
Morgen ist auch noch ein Tag!
Werde jetzt mal dieses Rom probieren. So lange das Doc Rom drauf gehabt,ist Zeit mal was neues zu probieren.
Reaktionen: boardmaster2009
Ja, morgen soll ein großes Update kommen mit Glow-Mod, Screen-off-Animation etc. !
Dann pack ich mir noch das neue Theme vom scheich drauf und dann ist das Ding geritzt :winki:
War wie Randall Flag auch Monate lang auf Docs Rom unterwegs, aber gerade den neuen Entwicklern sollte man auch eine Chance geben und deren Arbeit und Mühe honorieren !
Außerdem hab ich sowieso die Nase voll von Doc, gab zuviel Probleme in der letzten Zeit damit !
Ich bin gespannt :biggrin:
So, hab mir das ROM auch gestern Abend mal aufgespielt (ber DOC 1.3 beta mit CF 3.1), läuft problemlos und schnell. Allerdings fand ich bisher immer alle neuen ROMs die ersten Tage schnell, gibt sich leider oft mit der Zeit. :thumbdn:
CRT off Effekt und Bat Mod von hier: XDA
(Was mir aufgefallen ist: In der Beschreibung des ROMs steht "kein custom kernel bzw stock JVB kernel" bei mir war allerdings CF 3.1 mit den entsprechenden Apps direkt drauf. Kann das einer bestätigen oder hat es mir beim Aufspielen des ROMs den Kernel aus irgendeinem Grund nicht mit eingespielt?) Erledigt s.u.
Insgesamt muss ich sagen, ich seh bisher eigentlich keine Unterschiede zur JVK. War aber echt schnelle&gute Arbeit von c0llal0 und ich denke ich werde die updates mal weiter verfolgen. :thumbsup:
Edit: Droidwall läuft immer noch nicht. Hab wieder den iptable fix von chainfire benutzt aber immer noch Fehler 1. Werde mal rumtesten...
Edit2: Ok, ich bin ein Idiot. In der Beschreibung steht, dass der Kernel nicht geflasht wird bei CWM 3.0.5...
So habe das Rom nun auch geflasht. Erster Eindruck ist gut. Werde jetzt mal alles einrichten und gucken wie es dann läuft.
Bin immer etwas schlecht drauf,wenn ich weiß das ich alles wieder neu einrichten muss.
Aber was soll's..:D
So alles drauf :) jetzt warte ich auf das update. Wo sind die Klingeltoene alle hin? Das ist doof. Hat jemand die orginalen? Das ausschalten sieht witzig aus ^^
Edit : Lösung war der Thread Firmware entpackt für alle die kein Backup haben... Das ging sogar vom Handy aus ^^ Jetzt klingelt es wieder schön :)
Sent from my GT-I9000
Jo das mit den Klingeltönen hat mich auch gestört.
Werde mir die gleich mal draufpacken.Ist nicht schön so.
Laüft aber sehr gut finde ich!
Die Widgets (Übersicht) öffnet viel schneller usw..
Fühl sich alles sehr rund an! Bleibe jetzt auf jeden Fall auf GB.
Screenoff rockt schon,sehr schick!
Edit: Habe ja den Zeam Launcher drauf und beim scrollen muss man echt langsam machen,sonst scrollt er gleich alle Screen durch.
Ist das bei euch auch so?
Hallo Leutz,
habe die Nacht dann doch nicht so viel geschafft wie gedacht ... nach der 1:3 Pleite des FC musste ich erstmal um die Häuser ziehen ;)
Habe jetz gerade das erste Update zum 1.0 Rom hochgeladen ... leider habe ich die selben problems mit dem 5 lockscreens wie die andren
bastler ... naja, ich benutz ja auch die selben source files :) ... bin aber weiter am ball und habe vorhin auch was gesehen, dass eventl. die lösung ist ....
whatever ... für alle die noch nicht auf 1.0 sind und auf das entschlackte ROM warten <--- kommt heute abend ... spätestens morgen nach meiner
täglichen betätigung als moderner sklave ;)
habt ein erholsames wochenende !!!
blessings
c0llal0
Edit: Klingeltöne ... ich stell gleich mal ne zip bereit mit klingeltönen! Cyanogen-Sounds und Samsung-Sounds ...
ihr könnt dann die zip, vorm flashen, mit hastenichtgesehen öffnen und rauswerfen was euch nicht gefällt!
Was sind denn das eigentlich für Probleme?
Ich habe in meinem Theme die 5-Lockscreen-Mod von Rimmer eingebaut und weiß nicht wovon da immer die Rede ist.
Kannst du kurz erklären was nicht läuft bzw. eigentlich anders sein sollte? Danke!
Bei mir sieht eigentlich alles ganz in Ordnung aus...
hallo scheichuwe
bei mir gibs noch folgende probleme:
1. der puzzle bildschirm ist nicht ganz sauber dargestellt, soll heißen die fläche in die man reinpuzzelt sitzt zu tief!
2. die text-darstellung im "verbinden mit usb" screen wird von dem connect button überlagert
letzteres habe ich zumindest für portrait ansicht ausgemerzt! aber so ne hunder prozent geschichte ist das irgendwie nicht!
grüße
Reaktionen: scheichuwe
Also sieht das bei dir anders aus als bei mir?
ein bisschen schon ...
gefällt mir besser ... was du da hast ;)
shoot me macht mir grad kein landscape ... aber da überlappt der text :(
Aha, also wie gesagt, ich habe die Dateien von Rimmer1966 als Basis genommen. Und nichts an den betroffenen Sachen geändert...
Reaktionen: collalo
ich muss eh gestehen, dass ich dein farbloses theme grandios finde und mir das selber immer drüber bügel :D
spricht da was gegen wenn ich für den 2.0-tree dein framework integriere und vllt. hier und da kleinigkeiten ändere???
Du kannst das auch 1:1 übernehmen, wie du willst :)
