Möchte euch das MitRa ROM vorstellen!!!
  • 44 Antworten
rewesun
rewesun
23
hallo,
habe schon fast alle Rom´s durch und muss echt sagen das ich von dem hier sehr begistert bin....schnell und stabil!!!
Testet es selber und seht!!
NEUE VERSION 5.0!!
guys new version on JW1 Base
include everything latest version. like market and youtube and ....
Download MitRa Rom 5.0 JW1
special tnx to M_J_NAZARI.
toggle status bar by = M_J_NAZARI
IMPORTANT:::
best method for install this version"
1.flash your phone to stock 2.3.6 .
2.install samephare kernel ,
3. install rom...
4.enable lagfix right now.
5.now i highly recomend you doing wipe and install again mitra rom 5.0 from recovery..
i hope to understand my english
some screenshot.
[ROM] MitRa Rom V4.6 [JVT][2.3.5]|- Graphical-Stable-Fast (Persian Support)[04sep] - xda-developers
:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
Ein paar Screenshots und die Beschreibung des Roms hier bei AH wären nett.
Ja das weiß ich auch aber dann ist dieser Thread unnötig!
MitRa Rom is a fast and stable rom - ENJOY !!!!
Screenshot of Version 4.6:
Screenshot of MitRa Rom 4.6 (ST) ( Stock Theme)
Screenshot of Optional Theme BluePro Ginger For MitRa Rom
Important
you must backup your efs folder via root explorer for security reasons before changing any custom ROM.[put the backup on safe place]
efs folder contains the phone details like IMEI and sale code and.... don't share with anybody
The Current Version : V 4.6
No WIPE Version
Based on Samsung JVT 2.3.5
Release in two versiom. one of with stock theme and the other one with graphical theme
Semaphore 1.8.1 Kernel
Deodexed Rom
Zipalign + Root
Busybox - Superuser
Voodoo Sound Version 10
Middle-East Languages Supports [Persian/Urdu/Arabic]
10 Lock-screens and Extended Power Menu + CRT off screen
Touch-wiz 3.0
Camera hack. (take snapshot with powerbutton and better quality) ( tnx from amestris team for hacked camera )
Neldar's BLN [SMS + Call notification Support]
Percentage Battery
Graphical Theme
New Icon + Statusbar + ....
Dialer
Install Go SMS instead Stock message (you can use stock sms too)
Quickpic 1.5
Market 3.3.11
use some files from pauldidy and blueocean them (special tnx)
Talk 2 [Video/Audio Support]
Multi Csc
Support right side keboard ( include - Persian - Urdu - Arabic - English - France - and i think china
+Some Tweak
Some application has been removed on this version like some widget and ... (doesn't matter you can install that app later )
Download MitRa Rom 4.6
Download MitRa Rom 4.6 (ST) {this version have stock Theme + 10 Lock-screen + graphical animation in menu + crt off + percent Battery + cam hack and .....}
Download Optional BluePro Theme For MitRa Rom
credit:
i used some file from ShadeofDusk_by_whaave and BlueProGinger - some file build by my me and my friend Ermia[/SIZE]
i hope to enjoy with my rom..
IMPORTANT TIPS:::::::::
1.
YOU SHOULD ENABLE LAGFIX BEFORE INSTALL...
2.
FOR USE GO SMS DONT FORGET TO ENABLE "stocke sms unistalled" IN IMPORTANT TIPS ( advance setting in go sms - if you dont like go sms stock sms in customize package
3.
you have 3 icon in dock bar you just need to select edit in menu and drag and drop messaging app to dock bar
4.
Problem with market?
check here
5.
Select " all animation " or " some animation " form display settings to enable CRT-TV Off effect.
installation guide ( for beginners):
1- flash your phone with 2.3.5 JVT with repartion checkbbox (with odin)
2- install semephore kernel 1.8.1 (with odin)
3- install lagfix file ( install recovery menu)
4- then you have ex4 program in menu . open that program and choice convert to ex4 .
5- install the rom from recovery menu.
Eralier Version:
Download MitRa Rom 4.5 JVT
Download Another Theme for MitRa Rom 4.5
Download MitRa Rom Version 4 with another them ( update 4.1 included)
Download MitRa Rom Version 4.0 JVT
download MitRa Rom Version 4.0
download Update 4.1
Download MitRa Rom V 3.x
Download MitRa Rom version 3.0 RC - JVT - 2.3.5
Download Update MitRa Rom 3.1
Download MitRa Rom V 2.0 (JVS) (include 10lockscreen + camerahack and ...)
Download MitRa Rom 2.0 - JVS
Download MitRa Rom V 1.0 (JVS)
MitRa Rom NO-wipe version
Download Update 1.1 for MitRa Rom...
more screenshot:
Screen shot from this Theme
http://padl67.com/ermia/mitra_rom/ve...022-082743.png
http://padl67.com/ermia/mitra_rom/ve...022-014106.png
http://padl67.com/ermia/mitra_rom/ve...022-013917.png
http://padl67.com/ermia/mitra_rom/ve...030-225220.png
Screenshot of Version 4.5:
http://padl67.com/ermia/mitra_rom/ve...%20%281%29.png http://padl67.com/ermia/mitra_rom/ve...%20%284%29.png
http://padl67.com/ermia/mitra_rom/ve...%20%283%29.png http://padl67.com/ermia/mitra_rom/ve...%20%286%29.png
http://padl67.com/ermia/mitra_rom/ve...%20%287%29.png http://padl67.com/ermia/mitra_rom/ve...%20%289%29.png
http://padl67.com/ermia/mitra_rom/ve...030-153154.png
http://padl67.com/ermia/mitra_rom/ve...022-011849.png
http://padl67.com/ermia/mitra_rom/ve...%20%282%29.png
http://s3.postimage.org/41aa17bmh/SC20111015_130842.png
http://s3.postimage.org/419ygfw61/SC20111015_044105.png
http://s3.postimage.org/41a3f1xnd/SC20111015_044222.png
http://s3.postimage.org/41aboqo49/SC20111015_133028.png
http://s3.postimage.org/41a8dnz4p/SC20111015_120536.png
http://s3.postimage.org/419v5d76h/SC20111015_043934.png
http://s3.postimage.org/419wswjo9/SC20111015_044021.png
http://s3.postimage.org/41a1ril5l/SC20111015_044216.png
http://padl67.com/ermia/mitra_rom/ve...022-082743.png http://padl67.com/ermia/mitra_rom/ve...022-013917.png
http://padl67.com/ermia/mitra_rom/ve...022-014106.png http://padl67.com/ermia/mitra_rom/ve...022-011849.png
Reicht das!!
Sorry aber stell zum ersten mal ein ROM vor!!
bin aber
Ist mit den bluetheme und animationen ganz Nett.
hi,
hab jetzt den neuen kernel sema 1.8.2bm hinzugefügt!!
läuft 1A!!!
seit 14 tagen, ohne fc´s oder ähnliches, sehr schnell und stabil!!
FÜR MICH DAS BESTE!!
:thumbup::thumbup::thumbup::thumbup::thumbup::thumbup::thumbup::thumbup::thumbup::thumbup::thumbup::thumbup:
Sehr gut rom
läuft alle flüssig
habe keinen hänger bisher
probier noch den neuen kernel 1.8.2bm von semaphore aus, damit läuft es nochmal besser!!
mfg
Sharism schrieb:
Sehr gut rom
läuft alle flüssig
Kann ichs ûber cyanogenmod flashen habe kein USB Kabel zu hause
Mir war langweilig, also hab ich's mal geflasht, und es macht einen soliden Eindruck. Sehr schnell und flüßig. Probleme bereitet mir jedoch ab und an das Wlan, was aber wohl ein Bug seit der offiziellen JVS zu sein scheint…
Eher Nein
Ist das Rom auf Deutsch?
MfG
Ja
Reaktionen: Schweizer7
Gut, dann kann das bei Dir ja eigentlich nicht passieren... weil das Mita ja auf JVT basiert und Du wenns gut glaufen ist, von einer JVT gekommen bist :D
Bin auch sehr zufrieden damit im Moment.
Der Bug existiert seit der JVS und wurde in der JVT noch nicht behoben.
So hab es auch mal drauf getan. War vorher auf Darky 10.2.2 und bin positiv überrascht.
Interessante Einstellungsmöglichkeiten, zB. das mit dem Lockscreen, blick das aber noch nicht durch^^
Benchmark schreib ich gleich.
MfG
@Schweizer: BM sagt nichts aus^^
Finde gerade das Theme recht nice... Bin ernsthaft am überlegen ob ich nicht mal kurz von MIUI runter sollte.
Werde aber definitiv NICHT den Semaphore Kernel benutzen, sondern es mal mit dem Tornado Kernel etwas quälen... Mal schauen ob es bei 1.4GHZ und einem UV von 45 immernoch so flüssig wie bekanntere Roms läuft ;D
Infos folgen in spätestens 30min
//Edit: Oder auch später wenn der DL so langsam ist :/
ok^^
Jetzt hab ich ein Problem mit dem Titanium Backup.
Hab die gleiche Version wie vorhin.
Dann wieder das Titanium gestartet und es zeigt mir einfach nichts an bei wiederherstellen.
Kann mir jemand helfen?
Hat sich erledigt: Hab das "Anwendungen aktualisieren" nicht gesehen.
MfG
kingoftf
kingoftf
kingoftf
jodahush
beicuxhaven
  • beicuxhaven
7 8 9
Bow_Wazoo
Bow_Wazoo
