FCB-Fan
Dauer-User
- 648
Wer gefallen an dem Galaxy S2 Look hat,
dem wird dieses Rom sicher zusagenen
_____________________________________
Base Firmware Details:
- Android 2.3.6 - Leaked XXJVU ValuePack Firmware
- XXJVU Modem
- OXAJVU MultiCSC (ATO - AUT - BMC - BRI - BSE - CNX - COA - COS - CPW - CRO - CYO - CYV - DBT - EGV - EUR - FOP - HAT - INU - IRD - ITV - JED - KOR - KSA - MAT - MED - MET - MiD - MMC - MOT - MOZ - MSR - MTL - MWD - NPL - O2C - O2I - ONE - OPS - ORO - ORS - PAK - SEB - SER- SIM - SMO - SUN - TGY - THR - TMZ - TOP - TPH - TRA - TRG - TSR - TWO - VDH - VDI - VIM - VIP - VNZ - VVT - WAN - XEE - XEF - XEH - XEN - XEO - XEU [Default] - XEZ - XFA - XFC - XFE - XFM - XME - XSA - XSE - XSG - XSS - XTC)
ROM Details:
- Fully De-Odexed
- Zipaligned
- BusyBox Pre-Installed
- Fully Rooted
- Huge APN List
- Init.d Support
- No 3rd Party Apps
- Lag Fix Support (EXT4 + RFS)
- Build.prop Tweaks
- Removed Samsung Bloatware
- Disabled Scrolling Cache In Framework (Ultra Smooth Scrolling!)
- SIP Calling (3G + WiFi)
- Full BLN Support
- CRT-Off Animation (Enable All/Some Animation In Display Settings)
- Extended Power Menu (Reboot, Recovery & Download)
- Percentage % Battery Icon
- Phone FC Fix
- 3D Blur Fix
- Non-Increasing Ringtone Phone App
- Hacked Camera App (Low Battery + Shutter + Shoot From Power Button)
- Hacked MMS App (No contact limit + No MMS convert + Sent time)
- Nexus S Live Wallpaper
- Nexus S 3D Libraries
- Nexus S Connectivity Icons (Icons' Turn Green When Connected To Google Services)
- ThunderBolt! Tweaks (80 LMK)
- Chainfire's EXT4 App & Supercurio's Voodoo Control App
- Latest GAPPS (Google Apps)
- Automatic EFS Backup (To Your Internal SD Card)
- Talk2 Audio/Video Calling Support
- Galaxy S II Look & Feel (Galaxy S II Features Listed Below)
Galaxy S II Features: (Ported From Latest XWLA2 Firmware)
- Full Galaxy S II Theme
- TouchWiz 4 (Epic 4G Touch - Alphabetical Support)
- Icons
- Ringtones
- Startup Sound
- Alarm Sounds
- Boot & Down Animations
- Keyboard
- Task Manager App
- Calculator App
- Email App
- Browser (Comes Stock From JVR Update)
- VoiceToGo App (Voce Command System)
- Tasks App
- Memo App
- File Manager
- Kies Air
- Galaxy Note Lockscreen (Stock in JVU)
- Battery Low & Charging Indication on Lockscreen
- Weather Widget
- Digital Clock Widget
- PostIt Widget
- Analog Clocks Widget
- Program Monitor Widget
- Email Widget
- Wallpapers (Moved into Internal SD Card)
Requirements:
- Gingerbread Bootloaders
- ClockworkMod Recovery
Screenshots
- Requirements
Gingerbread bootloaders
- Instructions
(If coming from Froyo Read This)
Download the ROM
Put it on your SD Card
Enter Recovery
Wipe Everything
Install Zip from SD Card
Select the ROM File
After installation reboot the device
Enjoy!
Note:
The first boot will be slow so be patient.
Best performace will come if all of you partitions are of EXT4.
Download the ROM
Enter Recovery
Wipe Everything
Select the ROM File
Enjoy!
Note:
- Downloads
F1 Galaxy S II v8.0 (Final BETA) DOWNLOAD
This ROM is based on Samsung Galaxy S firmware XXJVU. This ROM has Features and Apps of Samsung Galaxy S II which has been ported from XWLA2 firmware. This ROM has the look and feel of Galaxy S II.
DOWNLOAD V8.0 (BETA 2)
This ROM is based on Samsung Galaxy S firmware XXJVR. This ROM has Features and Apps of Samsung Galaxy S II which has been ported from XXKH3 firmware. This ROM has the look and feel of Galaxy S II.
Please check if the attached file works... Attached Files
________________________________________________________________________
DOWNLOAD V8.0 (BETA 1)
F1 Galaxy S2 V7 (Wipe)
(No Mirrors)
Previous Downloads
F1 Galaxy S2 V6 (Wipe)
F1 Galaxy S2 V6 (Non-Wipe)
F1 Galaxy S2 V4 (Wipe)
F1 Galaxy S2 V2 (Wipe)
F1 Galaxy S2 V1 (Wipe)
(No Mirrors)
Addons
Coming Soon!
(No Mirrors)
Requirements:
Full Wipe (Data, Cache & Dalvik Cache)
Disable any Lagfixes before installing
Instructions
Herangehensweise von BESCHDE
Wortlaut: Meiner Meinung nach ist es am einfachsten und am schnellsten die "Ficetos JVP Base"
(hier verlinkt unter weitere Downloads Roms, etc
zu flashen[ re-partion TICKED! ],
dann muss man nur noch in den Recoverymodus (CWM) booten und 3x wipen, Zip installieren, FERTIG
und ggf. das Internet berichtigen wie es bei mir der fall war,
aber das musste ich von jeder Firmware, hatte es von froyo, 2.3.3 und 2.3.4 versucht...
Download the ROM
Enter Recovery
Wipe Everything
Select the ROM File
Enjoy!
Kommentare - Umfragen - Bewertungen
von regety1
Download the ROM
Enter Recovery
Wipe Everything
Select the ROM File
Enjoy!
von regety1
Credits:
- Thanks To 1immortal
- Thanks To Juwe11
- Thanks To Darky
- Thanks To Darky's Crew
- Thanks To xcoom
- Thanks To Ficeto
- Thanks To Montymintypie
- Thanks To $omator!
- Thanks To Nick502
- Thanks To styxx
- Thanks To Fr4gg0r
- Thanks To coldflid
- Thanks To switchrock
- Thanks To sajidmkhan
- Thanks To Fekke
- Thanks To TotallyDubbed
- Thanks To itskapil
- Thanks To rafalense
- Thanks To grsgs
- Thanks To Dhiru1602
- Thanks To Zohawkish
- Thanks To All Who Donated, Beta Tested & Thanked
Ich selbst bin mehr bei den AOSP Roms Zuhause, werde dieses Rom (da nicht Anwender) daher nur begrenzt betreuen.
Es wird sich aber sicher der ein oder andere User finden, der sich siesem Rom annehmen wird
und Aktuell berichtet.
Für das Aktualisieren in Post 1 & 2 Mir einfach eine PN schicken.
Freue Mich auch über Unterstützung, wie z.B. einer Deutschen Installationsanleitung machen,
Hinweise für geeignete Modems, Kerneles etc; Danke!
Ich oder Android-Hilfe.de übernehmen keine Haftung dafür! Ihr seid für euer Handeln selbst verantwortlich!!!
Ich bin kein Entwickler, sondern Anwender/Nutzer und habe kein Tiefer gehendes Wissen über dieses Rom.
Bei Fragen wendet Ihr Euch am besten an die Quellen!
Change Log & Credits/ FAQs / Spezial Thanks
Change Log is in the 2nd post!
FAQs are in the 3rd Post!
YouTube Videos are in the 4th post!
Find & Follow Us On:
Donate:
I have invested a lot of time in developing and testing this ROM. So if you like my work, Please consider a DONATION or Contribute to my Samsung Galaxy S II Fund.
