EXTRAordinary 4.0 SGSII (JVS) ROM
  • 3 Antworten
Q
quasimodo
Gast
[ROM] NEW NEW NEW 27.09.2011 EXTRAordinary 4.0 SGSII (JVS)2.3.5 ROM
Ein Gute Alternative zu
F1 Galaxy S2
EXTRAordinary 4.0 SGSII ROM
und schon auf Basis JVS
Based On XXJVS Firmware
MultiCSC
Deodexed
Zipaligned
Rooted
BusyBox Installed
init.d Support
RTL Support
Arabic / Farsi / Urdu Support (Samsung Keyboard & Swype)
Phone FC Fix
Non-Increasing Ringtone Hack
Browser Lag Fix
3D Blur Fix
MMS Hack
Camera Hack (Low Battery + Shutter + Shoot From Power Button)
CRT-Off Animation
Huge APN List
Overscroll Glow (BLUE)
Extended Power Menu (Reboot, Recovery & Download)
SIP Calling (WiFi + 3G)
Full BLN Integration
Removed Some Samsung Bloatware Apps & Widgets
Galaxy S II Features Listed Below
GalaxianEE Kernel Galaxian
Basic Information
ROM​
(JVS-based modem, GALAXIAN_JVS )
-ROM is stable. I use this ROM.
-The battery lasts 48 hours.
-Rom is fast and simple​
FEATURES:​
Galaxy S II Theme
TouchWiz 4
Icons
Ringtones
Notification Sounds
Startup Sound
Alarm Sounds
Boot & Down Animation
Keyboard
Task Manager
Social Hub
Readers Hub
Game Hub
Email App
Browser (Comes Stock with JVR)
VoiceToGo (Voce Command System)
Tasks App
File Manager
Lockscreen (Latest from XXKH3 - Big Thanks To Dhiru1602)
Lockscreen Setting ( Under Display Setting - Movable Clock Positions )
Battery Low & Charging Indication on Lockscreen
Polaris Office
Weather Widget
Digital Clock Widget
PostIt Widget
Stock Widget
Analog Clocks Widget
Email Widget
Program Monitor Widget
Email Widget
Wallpapers
Ich oder Android-Hilfe.de übernehmen keine Haftung dafür! Ihr seid für euer Handeln selbst verantwortlich!!!
DOWNLOAD LINK FOR EXTRAordinary 4.0 SGSII (JVS) ROM :
Download Here
How can i install this ROM ?
Disable any lagfixes
Get into the CWM recovery
Wipe Data/factory reset
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Install the wipe version of this
picture.php
ALTERNATIVE KERNEL
As you wish. Any kernel that is based on JVS
-A big thanks for Simone201, from whom I learned a lot.
And big thanks for darkyy from whom I learned too
Disclaimer:
I'm not resposible of any bricked, fired,
smoking phone or something related to my ROM!!!
Flash anything at your own risk!!!
THIS ROM MAKES A WIPE
DATA/FACTORY RESET!!!
so make a backup of all your
apps with Titanium Backup!
FLASHING :
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Install the wipe version of this ROM​
HOW TO MOVE INTO CWM RECOVERY:
- Volume Up/Down ----> Move Up/Down
- Power Button -----> Select/Press
If you want to convert from the rfs in ext4, do it through the CWM, or with EXT4 app (If the kernel supports)​
picture.php
DONLOAD LINKS OF MAY ROMS
PH.MTechnology (JVP2.3.4) _1.zip: Multiupload.com - upload your files to multiple file hosting sites!
PH.MTechnology (JVP2.3.4) 1.2.zip: Multiupload.com - upload your files to multiple file hosting sites!
PH.MTechnology (JVP2.3.4) 3.0.zip: Multiupload.com - upload your files to multiple file hosting sites!
PH.MTechnology (JVP2.3.4) 3.0..zip: Multiupload.com - upload your files to multiple file hosting sites!
EXTRAordinary (JVQ) 3.1 : Multiupload.com - upload your files to multiple file hosting sites!
PH.MTechnology 3.1.1 blue (JVQ): Multiupload.com - upload your files to multiple file hosting sites!
EXTRAordinary_3.2_(WIPE).zip: Multiupload.com - upload your files to multiple file hosting sites!
EXTRAordinary_3.2.zip (NO-WIPE): Multiupload.com - upload your files to multiple file hosting sites!
EXTRAodinary_ODIN_ROM 3.3 Odin.zip:Multiupload.com - upload your files to multiple file hosting sites!
EXTRAordinary 3.3 (JVQ) ROM.zip: Multiupload.com - upload your files to multiple file hosting sites!
picture.php
picture.php
Just flash them via CWM!! Normally as a zip file via CWM Recovery!​
HOW TO RECALIBRATE YOUR BATTERY (by heartagramm):
COMPLETE GUIDE!!!
You'll have to use the phone for about 1-4 days (although it varies depending on the phone and battery used; every phone is an individual). It runs out of battery. Yes. Let it run. Recharge. After 3-4 recharges the battery will "gain" it's performance back.
After 3-4 full charge/full drain -cycles, do the following:
1. Charge the battery up to fullest.
2. Keep it plugged in to charger, and reboot to recovery.
3. On the recovery, go advanced, wipe battery stats, scroll on to yes BUT Don't wipe them yet. When you're ready, quickly remove the battery cable and push to wipe the battery stats.
4. Reboot the phone, use normally. Let it run completely out of battery.
5. Charge the phone back to full. Turn off phone. Charge until it says 100% on the green bar and vibrates for full charge.
6. The Important Part. Remove the charge cable for 0-0.5 seconds and plug it back in instantly. Let it charge to 100% again. Do this 1-2 times again, so you've done this 2-3 times total.
7. Reboot to recovery, wipe the battery stats again as on the step 3.
8. After wiping the battery stats, plug the charger back in the phone.
9. Reboot to ROM. Keep the cable plugged in. Keep it plugged in for about 30 mins to 2 hrs. Unplug. Should say 100%, mine did for about 40 mins after it depleted onto 99%.
And this is the way you should really gain great battery performance.
Amazing Battery Life! (by eggshaped)
I just thought I'd mention, I was trying to calibrate my battery the other day by the usual method. After fully charging and resetting the battery data I then tried to drain the battery fully in order to charge it again. Sounds simple. Thought it would take 3 maybe 4 hours with heavy, prolonged phone usage. Wrong lol.
I switched EVERYTHING on, gps, bluetooth, wifi, 3g, sync, screen on full brightness, started up google maps with the navigation on, internet, used a torch app for hours, played music for hours, streamed videos online for hours (just left the phone playing). It took one and a half days to drain the phone!!! It was a bit of a pain but says a lot for the battery life on this rom! Unbelievable.
Credits:
team carbon (THANKS FOR ALL!!!!)
Try to press thanks button
SUPPORT MY WORK, PLEASE​
CLICK ON DONATE​
showthread.php
__________________
GALAXY S I9000
MTechnology
PHP Code:
CLICK ON
DONATE and click the thanks button too
MT LINK: Wix.com MTechnologies created by phmiki based on Pro Production
Addons
Audio/Video
Redy
Talk 2 A/V 1.33 for SGS1
Geht auch unter JVS
application package from SGS2: Multiupload.com - upload your files to multiple file hosting sites!
LINK FOR MOR APP: http://forum.xda-developers.com/show....php?t=1056849 THANKS TO ZOHAWKISH
If tw4 force closes when you press share app do this
Download this apk http://forum.xda-developers.com/atta...3&d=1308077457
Copy it in system-app
Done!
Now enjoy your tw4 launcher! (THANKS TO Spezia12)
>> DOWNLOAD <<
ChangeLog and More!
ADDONS (like apps, themes...)
-HONEYCOMB BOOTANIMATION: Multiupload.com - upload your files to multiple file hosting sites!
- SWYPE KEYBOARD 2.29 FOR SOUTH EUROPE (you need at least 11MB of free space on /system partition): Multiupload.com - upload your files to multiple file hosting sites!
- SWYPE KEYBOARD 2.28 FOR NORTH EUROPE (you need at least 11MB of free space on /system partition): Multiupload.com - upload your files to multiple file hosting sites!
- TW4 Package (heavily modded tw4, customizable, by Fr4gg0r): Multiupload.com - upload your files to multiple file hosting sites!
More Apps:
[APPS] Fully working Gtalk with front facing cam's video chat + SGS2 apps to SGS - xda-developers
reflex
  • reflex
SGSPro87
kingoftf
  • kingoftf
Masta_Gee81
Masta_Gee81
iSad
TheCrow299
