[ROM][N910F/G][5.1.1][XXU1COI3] *24.10.2015* SimplRom & SimpLite v5.5F [SimplKernel]
  • 52 Antworten
Casius
Casius
Dauer-User
404
N910F OTA XXU1COI3
SimplKernel SimplRom & SimpLite v5.5F
Basiert auf N910FXXU1COI3 Android 5.1.1
XDA-Link: [ROM][N910F+G][OTA][XXU1BOE3][SimplKernel]Si… | Samsung Galaxy Note 4 | XDA Forums
Features:
SimplKernel
Root
Busybox
Deodexed
Zipaligned
Knox removed
Debloated
Kurzanleitung:
1. Den aktuellen Bootloader und das Moden muss via Odin geflasht werden.
Downloadlink: downloads for Samsung Galaxy Note 4 by alexndr | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers
2. Die aktuelle TWRP Recovery wird benötigt.
3. Die Zip SimplRom auf die SD Karte kopieren.
Downloadlink: downloads for Samsung Galaxy Note 4 by Psycho666 | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers
4. Im TWRP Dalvik, Cache, System und Datawipe durchführen.
5. Im TWRP die Datei SimplRom_v5.5F.zip von der SD Karte flashen.
6. Der Erststart kann bis zu 20 Minuten dauern.
Durch das Flashen vom Recovery geht der Knox Counter von 0x0 auf 0x1!!
Mods and Addons:
-Added Flashlight operation with Volume. -ULTIMATE SoundMod (DSP+ & XtremeBeats & V4A) with a System-wide configuration. -Added Festival Effects.-Added Themes. -Added AirView Settings. -Fixed Finger AirView. -Added Floating Messages. -Some Settings Tweaks to make your life easier. -SimplThemes Added. (flashables) -SimplKernel 3.10.9-WeRule Added. -DISABLE SCROLLING CACHE (FASTER & Smoother). -Added data roaming option in network. -Added Priority mode for wifi. -Added Message priority. -Added Reset wifi option in wifi settings. -Added support for mirror call. -Added support for rmvb files in myfiles. -Added protection for data folder in myfiles. -Enabled Alarm during silent mode. -Enabled HD voice during 3G connection. -Enabled anonymous thread in Messages. -Enabled Text field color in Messages. -Enabled translation of unknown title in music. -Enabled Camera during call. -Added a Modded TW by SimplTeam. (MUCH FASTER). -Modded Camera (better quality, bitrate and longer recording times). -Added some tweaks to main system files. -Added factory reset password. -Enabled folder view for messages. -Extra CSC tweaks. -Added unique Spen Attach/Detach sounds. -Added MultiWindow support for all Apps. -Added Extra Unlock Effects. -Added Toggle Customization.
Die entfernte Bloadware zum nachinstallieren via TWRP;
Bitte achtet auf die Mods. Wenn die nicht mit der aktuellen Base
gemacht sind, kann die Rom damit unbrauchbar werden. Ich habe die
nicht getestet.
AllShare_PACK.zip, BeamService.zip, ChromecastService_PACK.zip,
DriveLink_PACK.zip, Flipboard_PACK.zip, GoogleTTS.zip,
Health_PACK.zip. MirrorLink.zip, MyFiles.zip, S-Voice.zip,
SAMSUNG_PACK.zip, sCloud.zip, SFinder_Connect_PACK.zip,
SmartRemote.zip, SPlanner_PACK.zip, StockMusic_PACK.zip,
Weather_PACK.zip
Issues & Fixes + SimpLite:
Can the themes be used in other roms as well?
We prefer to keep it for SimplRom only, but since we can't force that,
you can always try it, but don't blame us in case of bootloops or FC's ;)
Alarm didn’t go off in silent mode?
Tap the 3 dots in the alarm screen and check Sound in Silent mode
Many people complained about facing various issues after flashing
the Rom with CWM Use TWRP to avoid these issues.
Samsung Link Platform has stopped working
Freeze or delete the SamsumLinkPlatform.apk to fix it
Volume is too soft/too loud
use Synapse (or a different kernel control app with soundcontrol)
to raise or lower the volume :good:
Call Recording doesn't work
we are working on it, in the meantime you can always use
something from the playstore
Wifi doesn't automatically connect
We have added few extra wifi settings, and due to that, wifi is
going to be manual by default, to make it back automatic, go
to wifi settings then Advanced then Set Network Connection
Method = Automatic.
Screen pin works, but i can't unpin
Screen Pinning works fine, but if it won't unpin, go to Settings,
Accessibility, all the way on the bottom look in the Services,
it's probably all disabled then, tap on one of them, disable it,
enable it again, and after that the unpinning works.
Flashable Fixes:
NoVolumeWarning.zip
Disables the volume warnings.
NoWakeOnPlug.zip
Prevents the screen from turning on when power or usb
are plugged in or out.
Viel Spass und vielen Dank an den Dev. Psycho_666.
Viele Grüße aus Bochum ;-)
Casius
Reaktionen: watcherlein, dies und daVirus
Hey Leute,
ich glaube es dauer nicht mehr lange,
bzw. hoffe es, denn dann kommt BOC3 Simpl ROM mit Simpl Kernel. :thumbsup:
der Pulsar
Reaktionen: Casius
Lassen wir uns überraschen ;-)
so laut Justin, soll die Beta6 die letzte Beta für die v2.1 sein, somit ist bald mit der neuen ROM zu rechnen.
der Pulsar
Gibt es eine Möglichkeit bei der v3 den 3minit battery Mod ohne die netzwerkanzeige in der Statusbar bin zu bekommen? Habe die Stock ui geflasht dann war zwar die netzwerkanzeige weg, als ich dann den 3minit Mod nachgeflasht habe war sie wieder da.
Hi Marcel
wenn du mir die datei zukommen lässt wo 3minit und die netzwerkanzeige drin ist kann ich dir vielleicht helfen und die netzwerk anzeige entfernen
Reaktionen: Marcel2580
Habe dir ne pm geschickt. Vielen Dank schonmal.
hi thunder,
danke habe direkt eine pn an justin geschickt, er will das auch erstellen, dauter nur ein paar minuten ;-)
der pulsar
bin zur zeit noch auf der emotion, wenn wer screenshots von der v3 hat mit toggles usw. bitte mal posten, thx
werd die rom auch mal antesten
hi,
ja mann müsste 2 note4 haben, eins zum testen und eins für den gebrauch, dauert ja immer bis alles rund läuft.
der pulsar
Der ursprüngliche Beitrag von 14:49 Uhr wurde um 14:57 Uhr ergänzt:
so Patch/Mod 3 Mint ohne Netzwerktraffic steht bei den Mods zum DL bereit ;-) have fun.
cya der Pulsar
Gibt es noch eine Möglichkeit die Lautstärke etwas zu verringern? Mir ist selbst die leiseste Stufe noch viel zu laut. Im Store habe ich nur was zum lauter machen gefunden.
@marcel, stell doch mal ein paar screenshots ein, danke
versuch es mal mit v4a in den einstellungen für die lautstärke
der pulsar
Ich habe ja schon die Stock ui geflasht deswegen werden Screenshots nicht viel bringen. Ich versuche mal deine App. Vielen Dank.
Wenn das v4a Viper ist, funktioniert es leider nicht.
hmmm,
das doof.
der pulsar
Ja, denn es ist echt total laut. Suche schon die ganze zeit, finde aber leider nichts.
hi,
versuch mal den equilizer in viper runter zu stellen
workarround, flash nadia kernel ll r7 und dann das tool synapse dort die sound gain für speaker runter auf z.b. -10
der pulsar
Hmm, ich kann den Anfangspost nicht ändern. Da steht nur zitieren aber nicht ändern.
Hi dann schreib einen admin an
Zum Thema Lautstärke laded "kcontrol" aus dem App Store, damit kann die Lautstärke auch in dieser Rom eingestellt werden.
Der pulsar
Mir ist gerade etwas komisches aufgefallen. Der Pulssensor hinten unter der Kamera leuchtet bei dieser Rom die ganze zeit ganz leicht. Wenn man seinen Finger darauf legt fängt er sehr stark an zu leuchten, als ob er eine Messung durchführen möchte.
Dachte erst das wäre vielleicht ein Kernel Problem aber nachdem ich auch diesen gewechselt habe ist das Problem immer noch da. Das braucht doch mit Sicherheit sehr viel Strom wenn das die ganze zeit leuchtet.
Könnt ihr das mal prüfen ob das bei euch auch so ist?
LocDog
Nufan
Nufan
LocDog
handynutzer2016
dack23
hanspampel
hanspampel
