[ROM][N910F][4.4.4][XXU1ANK4] *07.12.2014* Dr.Ketan Custom ROM V2.0 (Odexed)
  • 20 Antworten
Tyrion
Tyrion
Enthusiast
405
Hab hier ne tolle Rom, ist sehr stock gehalten, rennt aber wie Hulle.
Dr.Ketan custom ROM based on N910F NK4 (DBT)
ROM Additional Features.
-All Languages enabled
-300 Fonts included
-System default Stock battery. 3minit battery Mod available in AddOn (post #3)
-4 Way Reboot Mod
-Two PullUp mods (You can set desired app for gesture settings)
  1. Side Pull up
  2. Long Press Menu
-System default MenuKey reassigned for Menu. You can toggle it from ROM control
-My Sfinder - To choose SFinder from pullUp
-SecLauncher Mod for Hide App and PullUp
-Briefing App - To select dom pullup for Original animation of stock briefing on Lt side launcher.
-Camera Mods - Use camera with Flash at low battery + Shutter sound option in settings) + some addition tweaks for Quality and Duration
-Torch(FlashLight)
  1. Long Pressing Vol up
  2. Quick panel Toggle
-360 degree Rotation
-Ink effect Lockscreen
-Three times pressing Home - ScreenShot
-Buil-In Debloating tool to remove nearly 50 safer bloatware (Dr.Ketan Utility-ROM extra)
-Screen Mirror - PreFixed
-Private Mod -PreFixed
-S Health - PreFixed (No needs to use xposed)
-Ext SD write issue - Fixed
-Fixed Titanium backup restore issue (sometimes after restoring app+data with titanium causing FC)
-App Op Native feature in Settings
-All Application in Pen window and Multi window + Multi instance (May not work for all Apps)
-SnapBizCard - Scan visiting card and add information to contacts with OCR)
-25 Quick Panel Toggle (added Torch,Quick connect,PowerSaving and SFinder)
-Extra Call/SMS Blocking mode (Native) with phrase block option in messaging.
-Dual Setting mod. Note4 style and Note3 Style (Tab view). You can hide unwanted from Launcher.
Extra utilities with Toggles (kann man in Displayeinstellungen Ein/Aus schalten)
  1. Network meter with 6 speed with Toggle
  2. 8Extra Toggle in Notification
  3. Virtual Lock button on status bar
  4. Virtual Recent panel on status bar
  5. Menu long press kill App
  6. CPU usage in Expanded notification
  7. Clean memory option in expanded Notification panel
RomControl (Findet man im Appmenü)
DPI select (640/600/560/520/480 DPI) Note that some app requires to set 640 DPI with app setting xposed module.
- FullScreen Caller ID
- Menu key assign to Menu/Recents
- AOSP Tpggles (SystemUI) mods
- Enable Native Call record
-Sound Mod
  • Mild boost
  • High boost
  • Restore stock
  • Viper mod
Dr.Ketan Utilities
Utility
Die Utilities haben 4 Sectionen
1.Utilities -Toggles
  1. Auto record Incoming call (make Sounds folder on IntSD if not already)
  2. Auto Record Outgoing call (make Sounds folder on IntSD if not already)
  3. Auto GPS (GPS will auto ON with some common app needs GPS)
  4. Auto Wifi (Wifi will be turn off if remains disconnected for 10min)
  5. Auto Blutooth (will be turn off if remains unpaired for 10min)
  6. Smart Network (Mob data will be switched off after 30 sec of screen off)
  7. Media scanner Enable/Disable
  8. Torch light on shaking device (not working right now)
  9. Login security - captures image with wrong password login with multi attempts.
2.Utilities -Tasks
  1. EFS Backup (For N910G Only)
  2. Data restore Fix
  3. Flash recovery/Kernel from intSD
  4. Auto Scan (If you turn On - Media scanner will run only device conected to charger AC/USB) This will override setting of Media scanner Enable/Disable in Toggle section.
3.Rom Extra settings
  1. PullUp chooser for all pull mod 1.Launcher Lt pull 2.Long Press menu
  2. Debloating Tool
  3. Extra setting 1.Horizontal caliberation 2. Air Guesture (Not tested all may be few are working. I have just enabled hidden settings) 3. Network Restriction)
  4. Meet Here (Find Car)
4.Help and version info.
Advanced function SecMMs
  1. Group messeging
  2. Schedule msg
  3. Backup/Restore SMS to SD card
  4. Recipient limit 999
  5. Original time stamps
  6. Disable SMS-MMS
  7. Raise SMS/hr limit
  8. Split view toggle in setting menu
  9. Increased MMS max size
  10. Increased size of image
  11. No SMS to MMS with Emoji
CSC features Findet man auch im Appmenü
  1. Enable camera during call
  2. Enable Popup Notification
  3. Shutter sound Menu
  4. Enable Sub Menu Symbol KB
  5. Raise name lenth limit
  6. Max speed dial 100
  7. Enable call button
  8. Enable export to SD
  9. Message
  10. Raise recepient limit 999
  11. SMS to MMS threshold 999
  12. Enable folder view
  13. Enable font features
  14. Enable schedule msg
  15. Disable phone nu formatting
  16. Phonebook digit matching
  17. Launcher Rotation
  18. Web exit option
  19. Wifi client 10 for MobAP
  20. MultiWindow addOn App
  21. Calender export
  22. Email White BG
  23. Clock enable Auto on off menu
  24. Voice call waitingtone 60
  25. National Roaming Icon enable
  26. Web default desktop site
Changelog V2
- Based on N910FXXU1ANK4_N910FOXA1ANK4_N910FXXU1ANK4_Germany
- All features of V1 as it is
- Odexed
Download
Installationsanleitung:
- Rom downloaden
- MD5 Checken
- Gerät muss CWM/TWRP drauf haben
Achtung durch flashen vom Recovery geht der Knox Counter auf 0x1
- EFS Backup machen
- Rom auf die SD kopieren
- Im Recovery alles wipen und Rom installieren
- neu starten
Weder ich, noch sonst wer übernehmen Haftung für irgendwelche
Schäden. Wer sein Phone flasht ist dafür verantwortlich.
Original Thread: [07Dec14][N910F] [DBT] [NK4] Custom ROM V2.0… | Samsung Galaxy Note 4 | XDA Forums
Diverse AdOns findet Ihr im Haupthread
Reaktionen: MrGalaxy
Hier ist ein Transparent-Themes, habs mal drauf gemacht. super.
Wählbrett, Kontackte, Einstellungen, Titanium Backup, u.s.w
Transparent theme
Restore
Einfach im Recovery flashen
Ach ja, wer auf Benchmark's steht, hab ich nach dem einrichten meiner apps gemacht. Kein Kernel oder sonst was geändert.
Bei XDA sind noch 2 neue Roms die hier vorgestellt werden wollen. :thumbsup:
Warte mal, bis alle aus ihren Weihnachtsferien wieder kommen, dann finden auch die neuen Roms ihren Weg hierher. Im Moment ist ja alles ruhig hier
BoBCaTRom und Super.Fast&Famous sind schon raus.
Hallo
Ich habe gestern
N910G BOF1 NSDr.Ketan custom ROM L7.2 S6 geflasht soweit so gut.
Kernel 3.10.40-5077540
Android-Version 5.0.2
Die Rom geht soweit flüssig und gut . Nun zu meinem Problem! sobald ich mein original Samsung LCD Cover aufstecke bootet das Note 4 immer wieder neu mache ich das Cover weg geht die Rom super . Hat einer von euch da einen Tipp für mich ?
Mfg.Merixi
Hi, versuch es mal mit einem anderen Kernel, vielleicht haste ja glück.
der Pulsar
Reaktionen: Merixi
Hallo Pulsar
Ich habe mal den
N4 AEL Kernel v15 .9 genommen dadurch wurde das Handy aber träge,ich habe dann mein Backup wieder eingespielt und die Rom geht wieder super.Hast du vieleicht noch einen Tipp für mich,mit welchen Kernel ich es probieren könnte?weil die Rom ist schon gut nur falls sie mit demLcd cover ( immer reboots) nicht geht werde ich wieder auf eine andere Rom wechseln.Eigentlich schade denn die Rom ist schon gut
Mfg Merixi
Hallo ich habe jetzt die
N910F BOD2 Dr.Ketan custom ROM L2
Genommen und alles ist gut LCD Cover geht und die Rom ist ja auch gut. Ich muss aber auch sagen das mir die L7.2 S6 ein bisschen besser gefallen hat
Mfg.Merixi
warte bis Android M erscheint, soll es für das N4 geben, rechnen würde ich damit vielleicht ende des Jahres bzw q1 2016. solange verzichte ich auf das LCD.
Hab mir gestern mal die S6 S6e angeschaut, und klar es können die LED Cober nicht unterstützt werden. Somit müssen wir auf eine echte N4 ROM warten, denn in den Ports wird es nie drin sein.
der Pulsar
Reaktionen: Merixi
Im thread nix mehr los?
Ketan hat mittlerweile die m2 rausgehauen auf 6.01 base.
Normal ist die fůr die g version aber es gibt ein fix womit sie bestens auf dem f läuft. Dazu noch ael kernel v10 flashen und su 2.71 und man hat eine fantastische rom mit Samsung theme store und s7 features.
Hier mal ein paar Screens von meiner.
Achso das ganze läuft bei mir mit pok1 bootloader und modem.
klingt interessant bin auch schon am überlegen,
hatte bis jetzt die l16 drauf lief auch stabil und mit dem N7 Kernel war sie auch sehr bat-schonend.
Reaktionen: redbull1
Habe den ael v10 drauf mit nameless profil.
versuch grad zu flashen hab mir den h-vitamin kernel mal drauf geladen mal schauen was passiert.
Hatte ich zuerst. Ging auch ohne Probleme.
ich vermisse bei der neuen rom Dr. Ketan Tweaks N4 sind die nicht mehr dabei?
Rom tool n4 verwenden. So wie ich das mitbekommen habe, wird in der m3 wieder mehr dabei sein. Wird aber alles in rom tool eingebaut werden.
das hat bei mir nicht reagiert genauso wie ich nicht in meine Themes reingekommen bin.
muss ich nächste woche noch mal probieren vielleicht bringt der Doc auch bald die Nachfolgerom.
Su 2.71 flashen ist pflicht. Und dann rootrechte vergeben.
supi das probier ich mal.
bis jetzt war Su bei den ROM´s immer dabei.
Eröffnet bitte einen neuen Thread. Neue Android Iteration, neuer Thread. So wurde es bei AH schon immer gehandhabt.
Danke
