[ROM][N9005][XXUGNJ2][4.4.2] *20.11.2014* X-NOTE v21.0
  • 1.956 Antworten
P4RTYH4RTY
P4RTYH4RTY
X-NOTE ROM
IT'S KITKAT TIME!
Weder ich noch Android-Hilfe.de übernehmen Haftung für schäden am Gerät
!!!Flashen auf eigene Gefahr!!!
Changelog X-Note v21:
#Based on latest NJ2 Samsung N9005 firmware
#Deodexed, zipaligned, rooted, busybox
#Many apps moved to data partition to allow easy uninstall
#Changes in aroma
#most of our code is recoded to have smoothness and battery life
[X-NOTE app]
#totally rewritten X-Note control app... now the navigation is done with swipeable tabs.
when open the app the first page links to all tabs, the back key automatically redirect to first tab.
so you can swipe or navigate.
#New amazing theme (the old temes will be available in few time in OTA)
#300 fonts included
#face unlock feature
#Viper for android audio mod (aroma)
# New google applications (aroma)
#3 sound boost levels accessible with xnote app
#new 3D bootanimation + bootanimation switcher
#enable/disable music skip track and time control (xnote app)
[ADVANCED MULTIWINDOW]
#select any app in multiwindow mode with @xperiacle application (included)
#select any app in pen window mode with @xperiacle application (included)
#multi instance available for all apps
#4 window in the same screen available (X-Note app)
[MULTI DPI X-TRANSFORMER]
#X-Transformer feature: THE WHOLE ROM IS MULTI DPI available dentity:
- 480
- 450
- 420
- 390
- 360
- 330
- 300
- 290
- 289 (phablet notification panel)
+ custom density
- Air wake up
- LMT launcher (pie-gesture control)
- Cpu monitor
- Cpu Spy reborn (credits @Mirko ddd)
[TW LAUNCHER] (Xnote app)
#Theme manager
#Enable/disable infinite scrolling
#Enable/disable wallpaper scrolling
[SETTINGS]
#options in settings:
X-Transformer
X-note app
X-Reboot
#Enabled all hidden settings widgets
#Switch grid layout/tabs layout/list layout
[SCREEN]
#3 screen mode available
- black and white
- High contrast
- default
[Features MMS-SMS]
#Unlimited Contacts Joining, SMS/MMS Max Slide Count, Recipient Limit Messages Per Thread, Max Subject Length, Max Email Address Length.
#Disabled SMS To MMS Auto Conversion For Long Text
#Disabled SMS To MMS Auto Conversion For Emoji
#Save And Restore Text Messages Using The Messaging App
#Enabled Group Conversations In Stock Messaging App
#Messaging App Screen On/Off Toggle
#Messaging App Split-View Mode
[Features Lockscreen]
#Lockscreen Select AOSP - Samsung
#Ink effect custom color
[Features Power Menu]
#Power menu customizable
- Show/hide reboot menu title bar
- show/hide data mode
- show/hide airplane mode
- show/hide power off
- show/hide restart
- show/hide flashlight
- show/hide screenshot
- show/hide accessibility
- show/hide sound mode
# enable/disable home button
[Features Statusbar]
#6 system UI theme switchable with xnote app
# Double tap on status bar to turn off the screen + ability to
# Customized battery text style with the following options
text style
enable/disable Auto Color
Static Color selection
Charging Auto Color selection
Regular Auto Color selection
Medium Auto Color selection
Low Auto Color selection
# 100+ battery icons
# Show/hide Battery icon
# Show/hide Samsung Battery text
# Advanced Battery bar fully customizable
#Customized network Traffic Meter
# Traffic speedmeter - ability to change
Disabled
Outgoing
Incoming
Outgoing
# ability to autohide
# ability to change color
#Customized toggle
- ability to show/hide toggle status indicators (x-note app)
- ability to show/hide toggle text (xnote app)
- ability to change color of active toggles (x-note app)
- ability to change color of dim toggles (x-note app)
- ability to change color of OFF toggles (x-note app)
- ability to change color of toggle text (x-note app)
- ability to change color of active indicators (x-note app)
- ability to change color of dim indicators (x-note app)
- ability to change color of OFF indicators (x-note app)
#Additional toggles
- torch toggle
- X-Note toggle
- Xtransformer Toggle
- Shoot it toggle (dr. Ketan app)
- air command toggle
- enabled many hidden samsung toggle
#Customized Clock
- status bar clock right-center-hide
- status bar clock font selection - 5 fonts available
- enable/disable date near the status bar clock + small/big font selection
- uppercase/lowercase/normal font selection for status bar date if enabled
- 18 available date format: dd-mm-yyyy / EEEE-mm-dd-yyyy / etc.
#Customized Dropdown panel
- ability to change color and transparency of Droppanel
- custom image view selection (12 images) with transparency control
- cpu widget show/hide
# 10 KEYBOARDS available switchable with xnote app (new white keyboard)
# # # sure we've forgotten to mention some feature, sorry
X-Kernel V.3.0 - only for N9005
  • UPDATED TO LATEST SAMSUNG OFFICIAL SOURCES Opensource Update 9 NG2
    Close to stock for stability and best battery
    Selinux status = Permissive
    ExFAt support
    init.d support
    insecure & adb insecure
    Add swap support
    Add CIFS support
    Add NFS support
    Add NTFS support
    Add Xbox controller support
    Add cdrom option to UMS-lun-devices
    Add DriveDroid support
    USB: f_mass_storage: 2048 block size for cdrom devices
    USB: f_mass_storage: Added cdrom option to UMS-lun-devices
Credits Kernel:
Samsung for Official Source Code
Civato specially for the ramdisk
Faux123 Imoseyon DoomLord Yank555 Jovy23 Angelom TeamHacksung
Codeworkx Gokhanmoral Andreilux Simone201 Ktoonsez ptmr3
General Credits:
@xperiacle - for his great work
@Mirko ddd for the Control app Sources
@tamirda for additional power menu options
@dr.ketan for the two shoot-it app (free version)
@lidroid - for the superb coding of call recording
@Mythtrandyr - for the additional call recording code
@dsixda - For dsixda kitchen
@civato - for spen pointer tips
@Chainfire - For Superuser and a bunch of things
@rovo89 - For Xposed framework, for updates http://forum.xda-developers.com/show....php?t=1574401
@foreverloco for many AOSP theme PNG images
@DaOldMan for white samsung keyboard
@Tungstwenty - For Xposed Module (custom dpi density)
@OsamaGhareeb for battery mods
Please pm me if I forgot some Dev ;)
1- Vergewissern dass die Reaktivierungssperre in den Einstellungen deaktiviert ist
2- ein EFS Backup der Kitkat Firmware
3- Checkt die MD5 Summe eurer heruntergeladenen XNote Rom
4- ins recovery booten
5- wipe data (andere Wipes sind nicht nötig)
6- install zip und die Rom von eurer SD auswählen
7-Nach Installation Gerät neu starten.
8- Beim ersten einloggen in euren Google Account unbedingt die Stock DPI 640 verwenden.
9- Viel Spaß mit der Rom :)
Full X-NOTE Theme:
GREY THEME
TÜRKIS THEME
X-Note Leather Themes:
Um die Themes zu erhalten müsst ihr folgendes tun:
1. Dem Dev eine Kleinigkeit spenden via PayPal
2. Kontaktiert den Dev nach dem Spenden bei XDA per PM oder per Email, gebt folgendes an:
  • Gewünschtes Theme
  • Transaktionscode von PayPal
  • Device
  • Vor- & Nachnamen
3.Der Dev schickt euch schnellst möglich eine PM/Email
mit dem Link zu eurem gewünschten Theme
4. Speichert euch den Link zum OTA Ordner des Themes ab,
für eventuelle Updates
FLASH ANLEITUNG:
- Erst muss das AOSP THEME installiert sein, bevor ihr das LEATHER THEME flashen könnt
Von TÜRKIS THEME zum LEATHER THEME:
1 Installiert das GREY THEME
2 Installiert das AOSP THEME
3 Installiert das LEATHER THEME
Vom GREY THEME zum LEATHER THEME:
1 Installiert das AOSP THEME
2 Installiert das LEATHER THEME
Vom AOSP THEME zum LEATHER THEME:
1 Installiert das LEATHER THEME
Von LEATHER THEME zu beliebigen THEME:
kann direkt geflasht werden
Von LEATHER THEME zu anderen LEATHER THEME:
Von AOSP THEME zu TÜRKIS THEME:
Von AOSP THEME zu GREY THEME:
Von GREY THEME zu TÜRKIS THEME:
Von GREY THEME zu AOSP THEME:
Von TÜRKIS THEME zu GREY THEME:
Von TÜRKIS THEME zu AOSP THEME:
https://www.dropbox.com/sh/xpwfd5pc...RUCTIONS/02_TURQUOISE_THEME_build_21.zip?dl=0
MD5: A5EE71FD2900F30178629874B44D9609
Android File Host
Downloads: X-NOTE Build v20 (N9005 NG1)
MIRROR 1
MD5: 5810A14FAAEE87991EA6F5A3E7A1B4C6
Android file host - ONLINE HERE
______________________________________
Downloads: X-Note build 18.0 (N9005 NF4)
MIRROR 1
MD5: 11C12E0370185CE6FAF44FD932DBD795
ONLINE - Android File Host
Downloads: X-Note build 17.0 (N9005 NF3)
MIRROR 1
MD5: 9605F3CD7940E232FF39B75312795C3E
Downloads: X-Note build 16.0 (N9005 NE4)
MIRROR 1
MD5: 5A9B2926372A3EC11202171EE144D34C
ONLINE - AndroidFileHost
Downloads: X-Note build 15.0 (N9005 ND5)
MIRROR 1
MD5: 448BBD3FCEE3981B8A3788D65180E9C8
MEGA - ONLINE
Downloads: X-Note build 14.0 (N9005 ND5)
MIRROR 1
MD5: DE9F65552E13C2349686B87198FD4A1E
Adroid Filehost - ONLINE
Downloads: X-Note build 13.0 N9005-NC2
MIRROR 1
MD5: D11F4BFAD920791B3B9158733355C4D4
MEGA - ONLINE
MIRROR 2
androidfilehost - ONLINE
_______________________________________
Downloads: X-Note build 12 N9005:
MIRROR 1
MD5: 2639AB30F4B611AD9B56F305FF0B790E
MEGA - ONLINE
Downloads: X-Note build 11 N9005:
MIRROR 1
MD5: B1049ADA0D4F167AFBA924755FD78491
MEGA - ONLINE
MIRROR 2
___________________________________________
Downloads: X-Note build 10 N9005:
MIRROR 1
MD5: 614a3fac73272c9b53e74dc2ef5675f3
Mega
MIRROR 2
androidfilehost
Downloads: X-Note build 9 N9005:
MIRROR 1
MD5: 294A97B7C4F4BCBF385318B6176D9596
MIRROR 2
MEGA - ONLINE
Downloads: X-Note build 8 N9005:
MIRROR 1
MD5: F68B9165DE001CDCD8096FCCD545775B
AndroidFileHost
MIRROR 2
Mega
Aller DANK geht an die DEVs des X-Note ROM :
Entwickler:
Soloilmeglio
Xentrix
OrigThread:
@ XDA
Diskussionsthread:
Q&A
Join us on facebook
HERE
Google + page
HERE
Donate to us to support X-Note rom! just click
HERE
Reaktionen: MarkusOS, sebastian79hl, rtv und 15 andere
Morgen soll ja das XNote 8 KK released werden.
Ist folgende Vorgehensweise richtig?
1. Full Wipe inklusive SD Karte
2. Stock NA6 mit Haken bei Bootloader flashen
3. Chenglus CWM 6.0.4.7 flashen via Odin
4. Über Recovery SU1.91 flashen
5. Reboot
6. Full Wipe
7. XNote 8 via Recovery flashen
Ist das so korrekt?
Reaktionen: P4RTYH4RTY und Vincent V.
Also soweit ich das gelesen habe auf XDA ist das korrekt
Reaktionen: Seavers11
Ich glaube sobalt die XNote online ist werden die Server dermassen überlastet sein dass nix mehr geht......da warten so viele im XDA Forum und in anderen Foren ...:lol:
Ja da gebe ich Dir recht... Die F5 Taste glüht bei vielen einfach... Ist aber auch das einzigste TW Rom was verschiedene DPI bietet und das ist mir sehr wichtig... Dieses riesige Stock Aussehen sieht einfach schrecklich aus....
5. Reboot
6. Full Wipe
Ist das so korrekt?
Frage,muss ich das auch alles nochmals machen wenn ich schon Kitkat drauf habe
x-note 8 online
wenn kk schon drauf ist, denke ich man kann ab Punkt 6 weitermachen.
Reaktionen: GalaxyMax90
Wenn du schon die Sammy KitKat aus Polen drauf hast brauchst du das nicht nochmal machen aber auch dran denken das neue CWM mit odin zu flashe.
Gesendet von meinem SM-N9005 mit der Android-Hilfe.de App
Ich Danke Euch....
kann ich mit dem neuen CWM auf meine alten Backups zurück
Nein ein zurück auf 4.3 geht nicht mit den neu Bootloader
So die Xnote 8 geflasht und der erste Eindruck ist wieder grandios... Ich bin gespannt wie sich der neue Kernel macht !!!
Als Tip, solltet Ihr von einer Custom Rom kommen und die Stock NA6 flashen und Euer N3 beim booten "hängen" bleibt, dann flasht einfach nochmal die NA6 drüber danach startet es ordnungsgemäß... Hat mir eben erstmal einen leichten Schrecken gegeben :)
Reaktionen: depetti73
also hab die xnote 8.0 drauf
wird bei euch auch das wetterwidget nicht richtig angezeigt ? ist irgendwie total nach oben links verschoben. uhrzeit ist da zb nicht lesbar
Löchche nochmal das Widget.... und dann mal wieder neu anlegen und zurecht ziehen
dann sollte es passen
Reaktionen: OPC85
Moin zusammen,
heißt das, wenn ich jetzt die MJ7 habe, kann ich diese drüber bügeln und dann nochmal flashen? Hatte nämlich gerade das beschriebene Problem. Mit TWRP drüber geflasht und dann bleibt es bei Set warranty bit: Kernel hängen. Danach bin ich dann mittels Nandroid Backup zurück zur MJ7..
Danke vorab.
1933 schrieb:
Moin zusammen,
Danke vorab.
5. Reboot
6. Full Wipe
Ahh, steht auch in der Anleitung :/ Danke :)
Lesen bildet.. Aber muss CWM genommen werden? Oder geht auch TWRP?
also ich hab twrp drauf, ging ohne probleme
Hier noch die Anleitung zum Flashen des polnischen Kitkats: xda-developers - View Single Post - [OnLine][26.01.2014] X-NOTE build 8.0 N9005 NA6 4.4.2
Ist halt erst notwendig wegen neuem Bootloader. Ich hab mir schon mal alles runtergeladen und werde erstmal auf Arbeit fahren und heute Abend gehts dann los. Hab mich nämlich entschieden auf KitKat zu warten und dann doch zu rooten. Stören mich einige Dinge, die ich dann endlich los bin...
und schon die bootanimation zerschossen XD fängt gut an ^^
einer ne idee wie ich die originale wieder hinkriege ohne neu das rom zu flashen
Bei jedem Reboot kommt "Remote Controls angehalten" weiß jmd woher das kommt?
Gruß black
Gesendet von meinem Nexus 7
manne49
maxgamer2006
manne49
manne49
manne49
waro
