[ROM][N9005][XXUGNH1][4.4.2] *17.10.2014* Sweet ROM v22
  • 34 Antworten
Tyrion
Tyrion
Enthusiast
405
Habe die se Rom bei XDA gesehen, und werde sie mal testeln
Die Rom ist Stock gehalten, und wird direkt installiert.
Bei erstinstallation ist ein Fullwip erforderlich.
Changelog
Samsung N9005XXUGNH1 4.4.2 Firmware release date Thu Aug 28 2014
N3 AEL Kernel v7.9 thanks to @friedrich420
Deodexed & zipaligned
Pre-root rom
SuperSU 2.02 (thanks @Chainfire)
Busybox version 1.22.1
init.d enabled without need for custom kernel (big thanks to @JustArchi)
inti.d tweaks
Build Prop tweaks
light debloat
3Minit Battery Mod. Change battery images on the fly. (massive thanks to @gharrington for his hard work HERE)
knox removed
4 way reboot
S5 Boot Animation
Nova Launcher
S5 Launcher 6 x dock with 2 pullup apps (big thanks to ksr007 for his mod for Note 3)
Added heaps of different themes (thanks to ksr007 for his themes thread)
Full Screen photo & Call record thanks to @Dr Ketan
Region lock removed (removed carrier locks)
HD weather modified Accuweather widget thanks @brhoomy101
S5 MMS
S5 Keyboard
S5 Calculator
S5 SPlanner
S5 SNote
S5 SVoice
S5 Video app & player
S5 Browser
S5 SNS
Note 4 & Galaxy Alpha wallpapers added to modded SecWallpaperPicker.apk
Polaris Office full
My Data Manager - manage your data
Nandroid Manager - restore apps from Nandroid backups
Night Clock
ES File Explorer
Xposed Framework (massive thanks to @rovo69 for xposed)
Wanam Xposed (big thanks to @wanam for his app)
Xposed S5 toggles & recent apps (big thanks @xperiacle for his mod)
Xposed Blurred SystemUI
UPSM by @xperiacle. Please refer to his thread HEREfor activation instructions
Droid Over Wifi - Wireless file transfer
Google L Keyboard
YouTube Downloader
External SD Card r/w fix
added more csc regions and modified (thanks @_alexndr for csc base)
Hidden CSC features enabled including;
Sub Symbols in stock keyboard
Sound menu in Camera
Enabled Camera during call
Show total call time
Enabled call button in Call log and contacts list
Extend speed dial to 100
Disable Message log in Call log
Removed screen capture sound
Enabled sms call back number
Enabled sms Folder View
Removed message recipient limit
Disabled sms to mms automatic conversion
Enabled Call and Message block in Settings
Enable save message
Enable register to calendar
SMS to MMS threshold increase to 999Enable message scheduling
Enabled extra toggles
Plus much more EFS auto backed up during flas
Sweet Settings enabled extra widgets
There's heaps more but I can't remember it all right now
Weitere Infos gibts hier
DOWNLOAD
Mega link - HERE
AndroidFileHost link - HERE
md5 checksum - 9016E5666EAA349DC765D7B0413440D1
Installation:
1. Benutze Costum Revovery TWRP oder CWM ( Garantie ist weg dein Knox geht auf 0X1)
2. Überprüfe "REACTIVATION LOCK" aus ist!!!
3.Nandroid Backup und EFS sichern ist pflicht
4. Rom Downloaden und auf die SD Karte schieben.
6. Im Recovery alles wipen und auf Install speicherort wählen.
7. Rom installieren & neu starten
fertig
Download bei Mega hängt bei ca.47% hat jemand alternativen Download ??
Sicher? bei mir ist der gerade bei 70+%, aber ich habe keinen Schimmer wo der das gerade hinschreibt^^
Edit: Download hat geklappt
Also hab die 14 mal drauf und muss sagen, läuft bis jetzt super. Aufnahme während des telefonieren funktioniert auch.
Alles in allem bis jetzt super.
Gesendet von meinem SM-N9005
Kann mir einer bitte einen Screenshot vom Gear Manager der Rom machen?
sorry, hab ich runtergeschmissen, da ich die Gear nicht habe, und auch nicht will, brauch ich die App nicht
Ja passt schon. Vllt hats ja jemand anderes
Ich nutze diese ROM auch bereits länger und bin sehr angetan, aktuell noch die V14 die läuft so gut, schnell und flüssig das ich kaum einen Grund sehe die aktuelle V15 zu flashen, aber es juckt wieder in den Fingern.
Wer hat die V15 in Benutzung und kann sagen ob es Probleme damit gibt? :thumbup:
Hatte sie drauf, keine Probleme, nur mehr stockapps. Wenn Du deine 14 gut läuft, lohnt sich der Wechsel eigentlich nicht
Reaktionen: jetdevil
Die V14 rennt bei mir richtig gut, Akku auch Top. Dann bleibt die V14 erstmal weiter drauf ^^
Ich habe ein Problem mit Sweet rom V14 und der app Tapatalk. Ich bekomme die app nicht richtig zum Laufen. Hat sonst jemand das Problem, oder weiß wie man es behebt?
Als Meldung erhalte ich das hier.
Gesendet von meinem SM-N9005 mit der Android-Hilfe.de App
Einfach Handy neu starten ich hatte das auch heute morgen im Auto das hat bei mir geholfen hatte kein Internet als bei mir die Meldung kam
Handy neu gestartet, app gelöscht, cashe geleert und app neu instaliert, aber das Problem besteht immer noch. Alles andere funktioniert ohne Probleme, nur diese app halt nicht. Adfree habe ich auch schon deinstaliert, aber auch ohne Erfolg.
Habe Sweetrom v14 NC2 und Tapatalk läuft ohne Probleme.
Hab jetzt das Problem mit neu aufspielen der Rom gewlöst. So wie es aussah, hat adblock, obwohl ich es deinsatlliert habe und alle Daten entfernt habe, Tapatalk geblockt.
Eine andere Frage, wie kann ich auf dem Sperrbildschirm die Uhr und das Datum farblich unterlegen? Mit Wanam geht es nicht.
Xblast und XiuMod nehme ich um die Statusbar zu modden. Mfg.agentdoggie
Statusbar ist nicht das Problem, sondern der Sperrbildschirm mit Nova.:winki:
8Versuch mal XUtilities
Da kann man die Farbe einstellen , ob es klappt teste ich gerade. Nutze auch den Nova Launcher
Mfg.
agentdoggie
Edit.
XUtilities funktioniert bei mir nicht.:-( .
Nutze aber auch nicht die SweetRom.
Dann warte ich auf deine Rückmeldung.:winki:
Triple_H72
deli99
deli99
Logel
Kleptomane
waro
