Intentus
Hier eine schöne Rom
Wurde sehr Stock gehalten. Läuft bei mir nach anfänglichen Schwierigkeiten sehr gut
Rom Features:
04.11.2014 JACKYAWAY.GNG1.V11 "BACK IN TIME"
- Samsung N9005XXUGNG1 Base
- Root (SuperSU 2.17), deodex, zipalign, busybox (1.22.1) and init.d support
- Scrolling cache disabled
- Aroma installer
- No Multi DPI (only stock 480)
- Multi CSC
- New aroma options to have statusbar without 3minit battery and 3minit quick launch
- Screen mirroring working on custom kernel
- ExtSdCard writing fix
- All apps in multiwindow and pen window
- Screen OFF animations crt/fade/none in aroma
- 4WAY Reboot in aroma
- Stock, Faux and Lean kernel in aroma
- Touchwake feature in Faux kernel
- Stock (fixed and scrolling wallpaper), Nova and Apex launcher in aroma
- Boot sound on/off in aroma
- Camera 100% quality in aroma
- XPosed installer in aroma
- Camera mods like shutter sound menu, flash on low battery, camera while calling, etc
- Messages mods like emoji, backup to SD, scheduled messages, screen on/off, MMS size increased, split view, sent time, etc
- Stock keyboard with subsymbols
- Stock browser with exit option
- Quad View
- 3minit battery mod and 3 minit quick launch
- Call recording
- Ability to disable the ascending ringtone
- Transparent Accuweather widget
- All rotations enabled
- Remove applications by aroma installer
- Roboto, Roboto Condensed and Full Roboto Condensed in aroma
- Low battery warning disabled
- Recents button in notification header (not in stock statusbars)
- Black framework in aroma
- White quick toggle in aroma
- Center clock in aroma
- Application update only by "my" playstore (no gmail 5.0, inbox, or other leaked apps)
- Network unlocked
- Build.prop tweaks
- Enj
21.10.2014 JACKYAWAY.GNH1.V3
- Bugfix
- Ability to choose the stock Samsung Reboot
- If you choose a custom dpi, xposed installer and play store fixes (you have to setup to 480) will be installed (thanks to rovo89)
- Applications updates
- More stability and faster than previous version
11.10.2014 JACKYAWAY.1.N9005XXUGNH1
- Based on N9005XXUGNH1, deodexed, zipaligned, knox free, rooted, busybox and init.d support
- SuperSu 2.13
- Multi DPI 480 (stock), 430, 400, 361, 321 ( If you choose a custom dpi you have to install Play Store Fixes xposed module and set it to 480. In this way you have no trouble with play store applications update)
- All apps in multi and pen window
- Screen off animations: crt, fade, none (editable in build.prop)
- Kernel in aroma: stock, faux 002b1 and lean kernel 3.11
- Touchwake (only on faux kernel)
- Custom script for mdnie and led setting only on faux kernel (if you don't like, you can disable the script located in /system/etc/init.d/00_tweaks)
- Launcher in aroma: Touchwiz (with scrolling or fixed wallpaper and with hide apps feature), Nova and Apex
- Camera mods (video and phot while calling and while on low battery, also with flash. Shuttee sound menu, 100% quality)
- Messages mod (emoji support,auto sms/mms conversion disabled, unlimited recipients, sent time, increased mms size, split view, save to sd, scheduled messages, screen on/off on notification and more)
- Exit option in stock browser
- Subsymbols in keyboard
- Quad view
- 3minit battery mod 2.2
- 3minit quick launch panel (aroma)
- Patch for screen mirroring on custom kernel
- Multi CSC
- Boot sound on/off
- Call recording
- stock and not ascending ringtone
- 8 statusbar style in aroma (center and right clock, stock or white quick toggle and more)
- Remove unwanted applications in aroma
- Accuweather widget stock and transparent
- Font selection in aroma: stock, condensed and condensed full
- 4way reboot
- Battery friendly and performance improvements
- Recents and lockscreen in expanded notification panel
- Low battery warning at 5%
- and more...
Download
Mehr infos: [ROM][N9005][KITKAT ND5][AROMA] JACKYAWAY ROM [28.04.2014] - xda-developers
Installation:
1. Benutze Costum Revovery TWRP oder CWM ( Garantie ist weg dein Knox geht auf 0X1)
2. Überprüfe "REACTIVATION LOCK" aus ist!!!
3.Nandroid Backup und EFS sichern ist pflicht
4. Rom Downloaden und auf die SD Karte schieben.
6. Im Recovery alles wipen und auf Install speicherort wählen.
7. Aroma ausführen und die Rom installieren.
Viel spaß
Und ein schönes Theme:
BlackandColors
und wer es schlicht mag
Samsung Galaxy Note3 - N9005 Theme by Pille_&hellip
Animiertes Pulldown
Mit bestem Dank an SimonGleinert
Mein Pulldown kann ich hier schon zur verfügung stellen,
einfach im recovery flashen.
Mods die in der Statusleiste sind müssen anschliessend
neu geflasht werden
Vorschau
Fire: https://www.dropbox.com/s/r7uew94zbwaw284/Fire.mp4
Zip
Fire_Jackaway-ng1.zip (69,91 MB) - uploaded.net
Firmware
Rom Features:
- Based on N9005 MJ7 Official
- Deodexed
- Zipaligned
- Rooted with latest SuperSu
- Knox deleted
- Stock kernel
- Busybox
- Support init.d
- Build.prop tweaks
- 4 way reboot
- Roboto Condensed font
- Keyboard with secondary symbols for all languages enabled
- No SMStoMMS conversion
- SMS/MMS Show sent time instead of time received
- Save and Restore SMS/MMS to SD Card
- Enabled group messaging
- Unlimited SMS recipients
- Enabled Split View Mode in SMS/MMS Settings
- Enabled Screen On/Off Toggle in SMS/MMS Settings
- Increased the SMS hour limit to 1000
- Network unlocked
- Exit menu in stock web browser
- Shutter Sound Menu in Camera Settings
- Center clock and traffic meter
- White battery icon
- White signal arrows
- Scrooling cache disabled
- Fast, smooth and battery friendly
- Custom SecSettings not change device status info (if you have "Official" status, flashing this rom will not change it!)
- Adaway
- ES File Explorer
- Flash Player
- All apps updated
- Polaris OfficeViewer deleted
- No boot sound
- and more...
- Aroma installer
- Multi CSC
- Quad View
- Call recording
- Network unlocked
- Build.prop tweaks
- Enj
- Bugfix
- SuperSu 2.13
- Quad view
- Multi CSC
- Boot sound on/off
- Call recording
- 4way reboot
- and more...
Download
Installation:
Viel spaß
BlackandColors
Animiertes Pulldown
neu geflasht werden
Vorschau
Zip
Firmware
EUR-N9005XXUGNH1-2014100720…zip (1,27 GB) - uploaded.net
Ich weise darauf hin, das flashen der Firmware geht auf's eigene Konto.
Sollte etwas schief gehen seid Ihr dafür verantwortlich, nicht wir.
Eine Aleitung findet Ihr hier
