[ROM][N9005][XXUGNF4][4.4.2] *10.07.2014* BoBCaTROM EVO v10 [OTA Update]
  • 120 Antworten
Darktrooper
Gast
Sceenshots
1 (1).png1 (2).png1 (3).png1 (4).png1 (5).png1 (6).png1 (9).png1 (10).png1 (12).png1 (15).png1 (20).png1 (25).png1 (33).png1 (36).png1 (41).png
• Based on European Samsumg firmware XXUEND6
• Deodexed busybox root zipalign
• Choose in Aroma Installer
- Themes Stock MOD - BoBCaT Blue - BoBCaT Gold
- Wipe/no Wipe
- Debloatware
- CSC Country Set
- Sound Options
- Kernels
- PlayStore and Hangouts Black or Stock
- SecPhone_auto_call_record_N9005_v2.3 Special thanks to @mythtrandyr for this wonderful work ==> http://forum.xda-developers.com/show....php?t=2498449[/SIZE]
• Knox free
• BatteryBar (thx @pvyParts http://forum.xda-developers.com/show...php?p=19878267 )
• OG Battery Mod (83 types)thx @OsamaGhareeb and special Thanks for Kitkat porting @xentrix Xnote Team
• Xposed Intelli3g module
• Modded settings with link to BoBCaTROM application, it include many options:
* Extra Settings
- Multi Window Manager
- PEN WINDOW MANAGER v2 The new application include "ability to open Pen WIndow drawer without using the Spen [Only with the PEN Window Launcher addon/plugin]
- App Permission Manager
- Notification Toggle
- BusyBox Manager
- Viper4AndroidFX (thx @zhuhang http://forum.xda-developers.com/show....php?t=2191223)
- OTA Update Home with link to WUALA folder for Updates, Extra, Themes, link to XDA thread and donation button
- OTA Update Pro, automatic alerts of new release with possibility to download it directly
- Reboot menu 5 way
** Gravity Box (thx @C3C076 http://forum.xda-developers.com/show....php?t=2554049)
• Features list: (application created for nexus not everything working)
- CyanogenMod Pie controls
- Expanded Desktop
- Statusbar QuickSettings tile management with tile reordering
- Lockscreen targets
- Statusbar icon coloring
- Statusbar Brightness Control
- Statusbar icon colors
- Additional QuickSettings tiles:
- Sync on/off, WiFi AP on/off, GravityBox shortcut, Torch, Network mode (2G/3G/2G+3G switch), Sleep, QuickRecord,
QuickApp, GPS on/off, Ringer mode, Volume tile, Camera tile, ...
- Quick pulldown - switches to QuickSettings when status bar is pulled down near edges
- Auto-switch to QuickSettings when there are no notifications
- Center clock in statusbar
- Battery indicator style
- Navigation bar tweaks including cursor control keys
- Low battery warning policy
- Disable LED flashing when battery low
- Disable LED while charging
- Advanced power-off menu (reboot, recovery)
- Volume key cursor control
- Skip tracks by volume key long-press while screen off (thanks to rovo89)
- More volume levels for music stream
- Option to control safe headset media volume
- Button for clearing all recent tasks at once
- CRT screen off animation
- Minimal brightness setting
- Autobrightness levels adjustment
- Lockscreen tweaks - show widgets maximized, lockscreen background style (color fill, custom image)
- Lockscreen rotation
- Hardware key actions - menu long-press/double-tap, back long-press, home long-press
- Dithered Holo background
- Option to use solid black Holo background
- Expandable volume panel
- Option to unlink ringtone and notifications volumes
- Notification drawer style (background color, image for portait/landscape, transparency)
- Button backlight modes (default, disabled, always on while screen is on)
- Dialer (Phone) tweaks
- Launcher tweaks
- Screen recording
... more to come
* Xposed installer + modules
- Gravity Box
- Xposed DPI settings
- Intelli3g module
- Greenify
- Multiwindow Manager
- YouTube Adaway (thx @wanam)
- Boot Manager
* UTILITY
- ES File Explorer
- Cpu monitor
- Cpu spy
- AdAway
- Language Enabler
- LogCat
- MD5 checker
- Boot manager
- GPS Fix
- Led Manager
• Optical Reader
• Bootanimation QMG
• All SMS/MMS Mods
• Enabled secondary symbols on stock samsung keyboard
• Browser with exit option
• Unlocked call and message block settings
• Additional camera effects available by default
• Email Policy Hack
• more to come
Installation Anleitung:
KNOX Counter geht auf 0x1
1. Überprüft die MD5 von eurem Download (http://getmd5checker.com/download)
2. Macht ein Backup von euren Sachen
3. Flasht zuerst die KitKat-Stock FW, falls noch keine drauf ist/war
4. Kopiert die ROM auf eure SD Karte
5. Bootet ins recovery, und flasht die BoBCaTROM mit einem Full Wipe
6. Dann einmal rebooten
7. Installiert Xposed framework und active module (BoBCaTROM Control)
8. Wählt eure Setting bei GravityBox
9. Nochmal rebooten
- fertig
Reaktionen: Fire123, Radagast, Reddy und 7 andere
Versteh ich das bei XDA richtig (mein Englisch ist leider nicht perfekt): Man braucht zwingend die NA6 sprich, den neuen Bootloader, um die BobCat v4 flashen zu können, bzw damit sie fehlerfrei läuft?!
Übrigens: Update auf Bobcat 4.1 :D
Genauso ist es... die NA6 bzw. der neue Bootloader wird zwingend benötigt.
Reaktionen: SimonGleinert
Kann man schon einschätzen, ob das so bleiben wird?
Komme vom s4 und wir hatten damals änliche Probleme, mit 4.3...Mittlerweile spielt es beim s4 aber keine Rolle mehr, welchen Bootloader man hat, solange man das richtige Modem hat.
Würde dann dem entsprechend nämlich erst mal noch warten
Ich denke, dass du wohl oder übel auf den neuen Bootloader wechseln musst. KitKat startet mit dem alten Bootloader nicht, du hast dann nur Bootloader.
Okay, danke.
Ich denke ich werde dann auch noch n bisschen warten....
Muss sowieso noch ein paar Dinge anpassen und PhilzTouch ist ja auch noch nicht soweit, wie ich hier gesehen habe (ist das einzigste Recovery, dem ich vertraue)
Die (zur Zeit) einzige funktionierende Custom Recovery ist die CWM von Chenglu. Philz wäre mir persönlich auch lieber, aber das wird wohl noch dauern.
Die CWM von Chenglu funktioniert übrigens einwandfrei.
Danke, aber ich werde noch trotzdem noch warten...und 4.3 läuft ja soweit auch einwandfrei, das ich momentan noch keinen wirklichen Grund sehe, um wechseln zu müssen
Mal ein kurzes Update von mir...@Asphyx
Debloat-Script und Theme-Anpassung ging schneller als erwartet, von daher bin ich nun auch auf 4.4.2 :D
Gab zwar n kleines Problem, weil das Note3 nach dem flashen am Splashscreen bei "Recovery Booting" festhing, aber nachdem ich die Firmware n 2tes Mal drübergebügelt habe, läuft alles :thumbup::cool2:
Hallo, ich habe ein Problem. Mein WLAN oder nur whatsapp funktioniert nicht wenn das Handy im standby ist.
Gelöst!
ist ein Kernel problem
Hab den original Kernel drauf. Hab das Problem aber irgendwie gelöst bekommen
###################INFO###################
Neuer Thread für die KitKat Version
###################Info Ende################
Reaktionen: mecss und Asphyx
@ Bl4ck3vil
Könntest du mir bzw uns bitte verraten wie du dein Problem gelöst hast ?
Interessiert mich wirklich, da ich bei paar Roms die ich ausprobiert habe
auch das selbe Probleme hatte (Ohne Lösung)
Aber bei der aktuell von mir verwendeten Rom, hab ich das Problem nicht.
Danke im Vorraus
ich habe unter Einstellung/wlan - Erweitert im standby wlan aus angeklickt, Neustart, dann nochmal unter wlan - erweitert im standby immer an und wieder nen Neustart. Und dann noch automatischer netzwechsel ausgeschaltet. Seit dem habe ich keine Probleme mehr.
Reaktionen: Universe ?
Danke für den Tipp, kurze Frage falls das Problem in Zukunft
auftreten sollte, was ich natürlich nicht hoffe.
Du hast geschrieben das du den automatischen Netzwechsel ausgeschalten hast.
Meinst du damit folgende Einstellung: Einstellungen - Verbindungen - Weitere Einstellungen - Mobile Netzwerke - Netzmodus ???
Hast du es auf "NUR WCDMA" eingestellt ?
Weil in meinem jetzigen Vertrag hab ich LTE inkludiert und deswegen ist bei mir LTE/WCDMA/GSM eingestellt.
Grüße
Ne, unter Wlan\Erweitert, da hast du die Option für den automatischen netzwechsel. Das andere habe ich auch so eingestellt wie du.
Bitte keine Direktzitate, danke.
manne49
maxgamer2006
waro
Triple_H72
deli99
deli99
