[ROM][N9005][XXUGNE2][4.4.2] *15.05.2014* X-NOTE Galaxy S5 v2.4 [PORT]
  • 134 Antworten
X
xnicplayax
ONLINE - X-Note PORT Galaxy S5 Build 2.4 | True Multi DPI Touchwiz |
Bilder der Rom gibts im folgenden Link: XDA - Thread
Original Thread: X-Note Galaxy S5 (XDA)
Diskussionsthread: Q&A X-Note Port (XDA)
Info für Devs
Code:
Advice for devs:
If you include some of our mods in your rom please
ASK PERMISSION BEFORE, and GIVE PROPER CREDITS
to X-Note Team!
Features
• Based on new samsung base NE2 (lots of optimizations)
• Rooted, busybox
• Region unlocked
• fully themed with X-Note elegant theme
• all previous goodies from previous X-Note release
• moved lots of apk in /data to have more free space in system
• enabled 3rd part apk installation from first boot
• TW launcher grid 5x4
• Multi dpi samsung keyboard (smiley view fixed)
• up to 17 app available in favourite app toggle, settings modified to have scrollable view of selected app list (please select the number of apps according to your screen density, at lower dpi you can select all 17 apps)
• NE2 apk reworked from scratch with better multi dpi compatibility
• disabled safe volume message
• Modified UI sounds
• Keyboard switcher - switch your keyboard theme via X-Note app (the phone will autoreboot after switching)
available keyboards:
- stock samsung theme
- leather blue theme
- leather brown theme
- leather grey theme
- leather brown premium theme
• SystemUI switcher - switch your SystemUI theme via X-Note app (the phone will autoreboot after switching)
available themes:
- Stock samsung theme
- X-Note grey theme
• status bar clock right-center-hide
• status bar clock font selection - 5 fonts available
• enable/disable date near the status bar clock + small/big font selection
• uppercase/lowercase/normal font selection for status bar date if enabled
• 18 available date format: dd-mm-yyyy / EEEE-mm-dd-yyyy / etc.
• status bar color and transparency selection
• status bar clock color selection (at first boot clock is transparent just change in x-note app)
• notification panel clock color selection
• notification panel date color selection
• network indicator now shows upload/download speed + option to hide if no traffic + 4 update frequency available: half second, 1 second, 2 and 5 seconds
• increased toggle number (now 39 total, if you don't see all at first boot just enable all via x-note app/aditional script X-Note), now included all the hidden samsung toggle plus:
- torch toggle
- X-Note toggle
- Shoot it toggle - single press it perform a hidden camera shoot without any sound or flash (3-4 seconds)
longpress - it perform a camera shoot with flash and sound (3-4 seconds), credits @dr.ketan for his great apps
- battery bar
- lock the screen
• added home button and lock button in status bar (can be both hidden with X-Note app)
• removed sfinder and quick connect buttons from notification panel (available as toggles) to save space
• CRT - fade effect when turn off the screen (select via x-note app)
• added Google Home launcher (option in aroma)
• Enabled themes in TW Launcher, available themes
- X-Note Moonshine
- X-Note Gold
- X-Note HTC
- X-Note IOS7
- X-Note JB
- X-Note Default
- S5 pro
• True Multi Dpi Touchwiz (work in progress) - ability to select your screen density (via X-Transformer app)- available parameters:
-480 dpi (stock)
-450 dpi
-420 dpi
-390 dpi
-360 dpi
-330 dpi
-300 dpi
-289 dpi
+ custom dpi selection
• multi dpi modded samsung applications to have best fit at all density (work in progress but almost done)
• Xposed installer
• Xposed app settings module
• Multi dpi play store
• Ability to enable/disable the feature double tap on status bar to turn off the screen
• Ability to choose the number of visible toggles coloumns (1------10)
• Ability to show/hide toggle status indicators
• Ability to show/hide toggle text
• Ability to change color of active toggles
• Ability to change color of dim toggles
• Ability to change color of OFF toggles
• Ability to change color of toggle text
• Ability to change color of active indicators
• Ability to change color of dim indicators
• Ability to change color of OFF indicators
• Ability to show/hide day
• Ability to show/hide Speed Meter statusbar
• Ability to show/hide Bluetooth statusbar
• Ability to show/hide Sound Vibrate statusbar
• Ability to enable/disable on the fly the infinite scrolling in TW launcher
• Ability to enable/disable on the fly the wallpaper scrolling in TW launcher
• Ability to enable/disable Data Mode in power menu
• Ability to enable/disable Airplane Mode in power menu
• Ability to enable/disable Power Off in power menu
• Ability to enable/disable Restart in power menu
• Ability to enable/disable Emergency in power menu
• Ability to enable/disable Accessibility in power menu
• Ability to enable/disable CPU Widget on Dropdown
• Ability to change color of CPU Widget on Dropdown
• Ability to enable/disable Home Button Wake
• ability to change battery icon on the fly (+100 battery types)
• added face unlock security lockscreen (in lockscreen settings)
• delete/restore bin/gsiff_daemon to save battery (via x-note app)
• Device status "official" instead of "modified"
• unlocked multi dpi play store credits @ MyLifeRocks10
• 3 audio level selection (via X-Note app)
• new X-Note feature - wake the device with the Air Sensor
• modified samsung settings with rom apps link
• secondary symbols in stock samsung keyboard
• 9 homescreens in tw launcher
• Universal init d enabler (for stock kernel)
• cpu monitor (via xnote app)
• cpu spy (via xnote app)
• multiwindow manager app - add any app in your side bar (credits @xperiacle)
• 4 multiwindow freestyle mod - ability to open 2-3 or 4 app at the same time (via xnote app)
• add custom shortcuts in notification panel
• camera shutter sound option
• prompt to exit from samsung browser
• youtube ad away xposed module
• greenify app
More to come
Credits:
Samsung for Official Source Code
Faux123 Imoseyon DoomLord Yank555 Jovy23 Angelom TeamHacksung
Codeworkx Gokhanmoral Andreilux Simone201 Ktoonsez ptmr3
Installation:
Da die Rom auf KitKat 4.4.x basiert, solltet ihr bevor ihr die Rom flasht eine offzielle KitKat Firmware installiert haben, ihr braucht ein KitKat fähiges Recovery und ein EFS Backup.
1. Checkt die MD5 Summe eures X-Note Downloads.
2. Bootet ins Recovery
3. Führt einen kompletten Full Wipe aus.
4. Wählt install zip from your internal sd oder eure externe SD, jenachdem wohin ihr die Zip verschoben habt.
5. Lasst die Rom installieren (Dies kann über 5 Minuten dauern)
6. Fertig
Download: X-Note Galaxy S5 ported build 2.4 (N9005)
MEGA
MD5: 405C71C1842D968221D7504F2C4C3E87
Für Updates und Mods öffnet die X-Note App und tippt auf X-Note Update.
Euer aller Dank geht an die Devs der Portierung des S5 Roms von X-Note:
Credits
@sac23 - For his official Sprint S5 port
@ultimatewaffel- For his great help
@Obi_xd - For his great help
@xperiacle - for his great work
@dsixda For dsixda kitchen
@dr.ketan for the shoot-it apps
@ficeto for the rom control app
@Chainfire - For Superuser and a bunch of things
@rovo89 For Xposed framework, for updates http://forum.xda-developers.com/show....php?t=1574401
@Tungstwenty - For Xposed Module (custom dpi density)
@OsamaGhareeb for battery mods
Wenn ihr mit der X-Note Rom zufrieden seid, dann dürft ihr den Devs gern ein Glas Rot Wein oder dem Hund einen Knochen spendieren. :thumbsup:
--> Donate Button:
Reaktionen: P4RTYH4RTY und GalaxyMax90
Hat jemand die rom schon getestet? Kann derzeit leider kein feedback geben, da wir schlechtes internet haben muss die rom bei nem kumpel runterladen
ja ich hatte die Rom gestern drauf gehabt und war ganz gut,Aber dann haben sich paar Fehler gezeigt,wo ich dann erstmal einen anderen Kernel geflasht habe,wo sich aber leider dann nix geändert hat,also bin ich den wieder zurück zur X-note v15.
Hatte nur Probleme mit den Wlan er hat sich Einfach nicht verbunden auch nicht mit den SneakyKat_Rev1.9 Kernel.
Aber sonst ein schöne Rom naja kommt ja auch von X-Note Team.
Okay komisch denn auf xda hab ich das Problem nicht gesehen. Vielleicht bringt ein ernuetes flashen etwas. Aber werde versuchen die tage rom runterzuladen.
/edit: hiernochmal eine liste was derzeit funktioniert und was nicht. Fix Links sind auch dabei http://forum.xda-developers.com/showthread.php?p=52682685
Reaktionen: GalaxyMax90
Rom gefällt mir optisch ein Tick besser als die v15.
Aber ich warte noch bis die Kernel Probleme gelöst sind.
Bis jetzt gibt es noch keinen Kernel der das Deep Sleep Problem behebt bis auf einen.
Doch bei dem stürzt ständig die Kamera App ab.
Von WLAN Problemen und 4g Problemen hab ich auch bei manchen auf XDA
was gelesen.
Da warte ich noch bis die Rom Bug Free & Stable ist :)
Ich hab sie am laufen. Und sie ist sehr gut. Ein paar kleine Fehler sind drin aber verkraftbar
Kleine Fehler ? Alltagsfähig ?
Deep sleep geht nicht das heisst sehr hoher akkuverbrauch
Reaktionen: weberfulda
Du kannst aber via setcpu ein bisschen was ändern. Das bringt zwar keien deep slepp aber ein bisschen niedrigeren akkuverbrauch
Habe das Rom nach 2 Tagen auch wieder runter geworfen.
Nachdem ich gefühlt jedes Note 3 Rom getestet habe (inkl. CM/AOSP) komme ich immer wieder zur ECHOE v13 zurück.
Bin mal gespannt ob sich da "Updatetechnisch" was tut ;)
Für mich is die rom auch noch nicht alltagsfähig. Aber es wird viel an fixes gearbeitet und ein update müsste die tage auch noch kommen :) ich aktualisiere den thread sobald ich mehr weiß
Hab die Rom mal ausprobiert und war weniger zufrieden. Viele Fehler (S Health, Kamera und Co. funktionieren nicht bzw. Stürzen ständig ab) und allgemein läuft das ganze System eher ruckelig.
Wer unbedingt einen S5 Port haben möchte, sollte (noch) auf den Ice Black Port zurück greifen.
Allerdings vermisse ich beim Ice Black Port die vielen Möglichkeiten die bei X-Note Standard sind.
Werde X-Note auf jeden Fall weiter im Auge behalten und wechseln sobald der Port stable ist :D
Die Rom ist stable. Für Shealth gib es einen fix der bei mir funktioniert hat. Bin allerdings wieder auf ei em Testbuild von der Ice Black Rom. Bin dort als Tester von neuen Builds und so weiter aktiv
Hab gerade die v15 wieder geflasht da lese ich das Deep Sleep mit dem Lean Kernel gehen soll. Kann das wer bestätigen?!?
Hmm die Lösung mit dem Aurora Kernel klappte bei mir nicht.
Ach was solls flash die ported mir eben noch mal schnell drüber und teste :D
Ich finde X-Note nicht mal im ansatz stable. Hab die Rom komplett sauber geflasht und im Vergleich zur Ice Black oder sogar Stock ruckelt das System wo es nur geht. Den Fix für Shealth hab ich auch benutzt. Dadurch kamen zwar keine Fehlermeldungen mehr, jedoch kann ich Shealth trotzdem nicht benutzen.
Aber als erfahrenere User sollten wir ja wissen: nur weil es beim einen läuft, muss es nich bei jedem laufen :D
Das einzige was mich an der Ice Black Rom stört, ist dass ich einfach nicht telefonieren kann. Bei der v4.2 höre ich den Anrufer nicht und bei der v4.3 geht mein Mikro nicht :D
Aber egal... Ice Black Rom gehört hier nicht rein :)
Natürlich ist es eine alpha und deswegen sage ich ja auch dass ich diese Rom im Auge behalten werde, da mir grundlegend die X-Note Funktionen fehlen :p
Das sag ich ja nicht das es wenn es bei mir alles wunderbar fu ktioniert bei anderen auch so sein muss. Mit der Ice Black Rom konnte ich auch alles machen was ich will. Auch telefonieren.
Aber jetzt genug mit der Ice Black Rom.
Hier geht es um die Ported X Note und die geht bei MIR einwandfrei ohne Probleme.
Habe sie jetzt 2x getestet, jedesmal waren immer noch Fehler vorhanden (trotz Fix) die für mich im Alltag nicht akzeptabel sind :( *leider*
Optisch und von den Apps her finde ich die S5 Ports super aber es wird wohl noch einiges an Zeit brauchen bis die "Rock Stable" sind ;)
So bin jetzt auch erstmal wieder zurück zu v15
Deep Sleep ist auch mit dem Lean Kernel 2.5/ 2.5.1 nicht zufrieden stellend.
Hab auch Aurora r4/r5 getestet aber die Akku Leistung ist echt nicht das wahre.
Mit Aurora hatte ich gar kein Deep Sleep & mit Lean Kernel auch nicht wirklich.
Schaue echt alle paar min bei XDA rein ob es schon eine zufrieden stellende Lösung gibt.
Da wird man noch verrückt, die Rom ist eigentlich Top, zumindest von der Oberfläche her.
manne49
maxgamer2006
Logel
Kleptomane
waro
