ICiP
Hallo Android Gemeinde
Da es noch kein Thread für die neue Phronesis 6.0.1 Rom gibt,
hier ist er
Ich übersetze hier nichts. Ich kopiere nur das wichtigste von XDA Thread.
Phronesis Rom Series, Here we go again....we are known for our professionalism and excellence because "We Know How"Da es noch kein Thread für die neue Phronesis 6.0.1 Rom gibt,
hier ist er
On the back of the most successful Lollipop N5 firmware Port, we once again bring you the best N5 MM port you will ever experience on your device.
This Port has been in development for over 6 weeks and great effort has been made to bring you once in a life time experience with your Note3. I and the
team have been working hard behind the curtain to make it one of the best ever. It's stable, solid, feature rich and full of customization you will ever want.
Note 5 users will probably want to give away their phone to get Note 3 just to use the Phronesis N5 Port for N3.....not even kidding!
Rom Installation:
1. Download Phronesis rom and save it to your phone memory or sd card
2. Get a good recovery. TWRP recovery recommended, 2.8.7.0. Newer versions are not supported
3. Boot into recovery, factory reset (full wipe, clean install is recommended). Make choices in Aroma.
4. Optional flash kernel of choice if you're
4. Reboot after successful install and wait for best rom in town to build. Allow about 10 - 15 minutes for first boot.
5. Your phone will reboot once after the first boot to complete customizations..
6. Sit back and enjoy
For full wipes Rom Releases:
1. Boot into recovery (say TWRP 2.8.7.0)
2. Select wipe in recovery menu
3. Select Advanced Wipe
4. From the resulting window, select to wipe system, data, cache and dalvik cache (of course after backing up your rom / data)
5. Swipe to wipe the selected partitions.
That's recovery wipe completed.
In Aroma menu when you get to option to wipe, select:
1. Select "Full Wipe" radio button
2. Select "Full wipe 1" radio button
3. Select your CSC as desired
4. Continue making other choices as you like....
Kernel Installations: VERY IMPORTANT
This rom does not come with any kernel. It was tested with darklord 1.9 by @darkera13. It will be expected that you will be find a link for this kernel and
have it ready in your sdcard to flash immediately after flashing the rom. There are two options in aroma to choose from, you can choose to keep your existing
kernel or install a new kernel after rom flash.
Links:
Original XDA Thread:
[Rom][6.0.1][N5 Port][26.06.2016] [Multi-DPI] Phronesis MM Rom v1.1 Feature Rich
Phronesis N5 MM Port Features:
Rom Feature - Post #2
Download:
Download Section - Post #3
http://forum.xda-developers.com/showpost.php?p=67367849&postcount=3
Screenshots:
