Nytro
Welcome to Omegas Thread for Samsung Galaxy Note II N7100
Omega v29 Kit Kat 4.4.2
Based on firmware XXUFNE1 Android 4.4.2 (Date: 06/05/2014)
Screenshots:
Omega v28 Installation:
Bootloader - Knox:
Omega does not include bootloader and will not change your knox warranty status.
Backup:
Backup your device (nadroid backup, titanium backup, efs backup ... etc), in case you ever need to restore!
Wipe:
Full wipe is needed if you are coming from another rom or stock firmware or Omega with another android version
and format of internal sdcard is needed if you are coming from Android 4.1.2 because updating to Android 4.3 will change the location of your internal sdcard
Installation Instructions:
Boot to recovery and flash Omega
Done, Reboot and enjoy kit kat Omega
NOTICE: If you are having the old bootloader WiFi will not work, flash this Fix N7100_wifi_fix_for_old_bootloader.tar file with odin. Credits to dr.ketan for the WiFi Fix
If you are using the new bootloader you do not need to flash this fix, WiFi will work.
To check your bootloader go to download mode and if you have an entry: KNOX WARRANTY VOID then you are having the new bootloader.
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
csc:
Multi csc included in Omega
Remove bloatware:
You can remove all bloatware during Omegas installation
Backup:
Wipe:
csc:
Remove bloatware:
Inside Omega v29:
Kernel Stock
Modem XXUFND3
csc multi set to BTU
Busybox
Aroma Installer
Installation is fully customizable by user and there is options to install everything or remove all Bloatware
aroma installer now has the option to remove more then 800 mb of almost 80 bloatware apps, widgets and services
Option to full wipe from aroma installer
Option to Remove all Bloatware from aroma installer
Option to install or not all Omega addon apps from aroma installer
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
Wipe System automatic before roms installation
efs Backup (added the option to create efs backup during installation)
Omegadroid Walk Bootanimation by Jorq1H and anbech
Omegas Emblem Shutdown Animation by anbech
OmegaDroid Kit Kat Wallpapers by our artist Jorq1H
Applications developed by Omegas Team (bartito & indie):
Omega Files by indie
OmegaDroid - The official application of www.omegadroid.co by indie
OmegaDroid Wallpapers application - Screenshot by indie
Task manager shortcut app by indie
Accounts Sync Profiler - xda thread for support & suggestions - Play Store link - by bartito
Backup manager for apps & data - xda thread for support & suggestions - Play Store link - by bartito
CPU Adjuster - xda thread for support & suggestions - Play Store link - by bartito
Notification Manager - xda thread for support & suggestions - Play Store link - by bartito
Recycle Bin - xda thread for support & suggestions - Play Store link - by bartito
Wireless Scheduler - xda thread for support & suggestions - Play Store link - by bartito
more to come ....
if someone wants to help with our app development, with beta testing, suggestions, translations and be part of our app dev team please sent me a pm.
Mods:
Call Recording
Phone with no increasing ringtone
4-way reboot menu
Omegas OGBatteryMod app with 60 battery mods - credits to OsamaGhareeb
TW Launcher with scrolling wallpaper (can be disabled from Omega Files)
Hide sms from call logs
No sms to mms conversion
Unlimited contacts to sms - mms
sms/mms Backup - Restore
Increased sms hour limit to 1000
Disable scrolling cache
Email with Exchange Security Disabled
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Exit button to stock browser
Join more unlimited contacts in the contacts
Enable sub Symbols on Stock Samsung keyboard
SamsungSans.apk with a lot of system fonts - by nitol
Addon applications:
Xposed Framework Installer by rovo89 - read more about Xposed here
Android Camera 4.4.2 with Photoshare
Android Keyboard 4.4.2 - available at Omega Files
Flash player Support
Dolphin Browser with Flashplayer support
Dolphin Browser Jet Pack
Es File Explorer
Hide It Pro
ZArchiver
Hi-Q MP3 Recorder
Pen Window Manager
Removed:
Knox
Removed (Can be added from Omega Files):
Boot sound
Charger Connection Sound
Stock Theme Changes:
Accuwheather widget transparent by indie
Omega Theme for aroma installer by our artist anbech
Bloatware :
Rom is Deodexed + Rooted + Zipaligned
Kernel Stock
Modem XXUFND3
Busybox
Aroma Installer
more to come ....
Mods:
Call Recording
4-way reboot menu
Addon applications:
Es File Explorer
Hide It Pro
ZArchiver
Hi-Q MP3 Recorder
Pen Window Manager
Removed:
Knox
Boot sound
Bloatware :
Omega Files:
Omega Files Pro:
Omega Graphics:
OmegaDroid:
Download:
Twitter:
Omegas Team:
indie
anbech - Thread |OP| & Beta testing & Graphics
cooza - Thread |OP| & Beta testing
devabhishek - Thread |OP| & Beta testing & themes
Jorq1H - Thread |OP| & Beta testing & 3D Graphics
gimmick56 - Thread |OP| & Beta testing
kalagas - Thread |OP| & themes
motomoto00 - Thread |OP| & Beta testing & themes
mythtrandyr - Mods - Programming
MVKA - Thread |OP| & Beta testing
nadmaj - Thread |OP| & Beta testing - Themes - Mods
raubkatze - Thread |OP| & Beta testing - Themes - Mods
ttav - Thread |OP| & Beta testing
wesamothman - Thread |OP| & Beta testing
Thanks - Credits:
::indie's:: Omega Roms SeriesTo my wife
To Omega's Team
To anbech - devabhishek - Jorq1H - kalagas - raubkatze for Omegas Graphics
To Jorq1H for Omegas 3D Graphics
To danishprakash for Note II psd icon
To Samsung
To all of you who support my work and help me
<b></b>OmegaDroid - your android portal ...
Omega Files Pro app - Build and Customize your rom the way you like it!!
Samsung Galaxy S5 Samsung based
Samsung Galaxy S4 Samsung based I9505 - Samsung based I9500
Samsung Galaxy Note 3 N9005: Samsung based 4.4.2
Samsung Galaxy Note 2 N7100: Samsung based 4.4.2
Samsung Galaxy S III I9300: Samsung based 4.3 - Omega AOKP 4.4.2 - Omega Omni 4.4.2
Samsung Galaxy S II I9100 Android 4.1.2 - Android 4.2.2 AOKP
Samsung Galaxy Note 10.1: Samsung based 4.1.2
HTC HD2 + Tmous HD2 - Omega v30 - WM6.5.x Build 29022
:: User Friendly Developer ::
Please use Omegas Threads for Support and Suggestions and don't sent me pm's!
