[ROM][N7100][XXUFNE1][4.4.2] *28.05.14* Omega v29 [Omega Files][Themes]
  • 1.810 Antworten
Omega v22 Opening Post and Download Center:
Please read this post carefully.
Here you will find all information you need for to the latest Omega Rom.
Do not download and flash before reading all the info provided here!
Download Center can be found at the end of this post
Changelog:
Based on firmware XXUEML6 Android 4.3 (Date: 31/12/2013)
Kernel XXUEML6
Modem XXUEMK1
Added:
Android Camera 4.4.2 with Photoshare
Dolphin Browser & Dolphin Jetpack
Updated:
Multi CSC updated
busybox 1.22.00
OmegaDroid
Chrome
Es File Explorer
Flipboard
Gmail
Multi Window Manager
Samsung Push Service
Samsung Print Service Plugin
Wanam exposed
YouTube
Added to aroma:
Dolphin Browser
Google Drive
Notifications Manager
All mods from previous Omega JB 4.3 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
Omega Files:
Omega Files Pro:
xda's support thread for suggestions and feedback!
Direct Links for Omega v22 added to Omega Files Pro with resume option
Update repo to Omega Files Pro to get the updates for v22
Please read the following before flashing v22:
Bootloader - Knox:
Omega does not include bootloader and will not change your knox warranty status.
Backup:
Backup your device (nadroid backup, titanium backup, efs backup ... etc), in case you ever need to restore!
Wipe:
Full wipe is needed if you are coming from another rom or stock firmware or Omega 4.1.2 versions
and format of internal sdcard is needed if you are coming from Android 4.1.2 because updating to Android 4.3 will change the location of your internal sdcard
Installation Instructions:
1. Copy rom to your device
2. Boot to recovery and flash Omega v22 and then reboot system.
3. If you are having the old bootloader WiFi will not work, flash this Fix N7100_wifi_fix_for_old_bootloader.tar file with odin. Credits to dr.ketan for the WiFi Fix
If you are using the new bootloader you do not need to flash this fix, WiFi will work.
To check your bootloader go to download mode and if you have an entry: KNOX WARRANTY VOID then you are having the new bootloader.
4. If you are using CWM based recovery ignore "Disable Recovery Flash" and "Fix root (/system/xbin/su)" messages at all times, just select "NO", else selecting YES will break root.
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
csc:
Multi csc included in Omega
Remove bloatware:
You can remove all bloatware during Omegas installation
Note 3 apps:
Galaxy Note 3 features for Samsung Galaxy Note 2 N7100
Read more at OmegaDroid's article by Tamirda. Credits to Tamirda and dr.ketan
Omegas Official & Exclusive Themes::
kalagas mixed theme is available only at omegadroid.co
Download Center:
Please do not make mirror links
Donation:
If you like Omega v22 + Omega Files app and you use them please consider a donation.
Enjoy the new Omega
Reaktionen: Kanomen, TheFarmer30, johsty und eine weitere Person
Hallo zusammen, ich habe die Omega V22 drauf und habe ab und zu ein paar abstürze, jetzt habe ich gelesen das es eventuell mit dem alten Bootloader zu tun hat den ich noch drauf habe.
Nun meine Frage, wenn ich den neuen Bootloader flashe, bleiben dann alle meine Daten erhalten oder wird da was gelöscht?
Es bleibt alles erhalten. Gelöscht wird da nichts. Alles Weitere erfährst du im Bootloader-Info-Thread. :)
Grüße
Reaktionen: Marcel2580
Tach Jungs,
ich habe seit Version 20 probleme mit Google-play dienste. Ewig meldet sich 1 oder 2 Dreiecke die schwierigkeiten mit Google play diensten meldet. Beim installieren bzw aktualisieren kommt der fehler -110.
Kann mir da jemand weiterhelfen?
Mfg Mad
Hast du schon mal versucht die Daten von den Play Diensten zu löschen und dein Google Konto zu entfernen und wieder neu anlegen.
Google Konto entfernen hat schonmal was gebracht. danke!
Also ich habe das 22er rom einfach über die bestehende 21er geflasht. Keine Probleme. Läuft genauso schön wie die 21er.
Für mich ist omega das non plus ultra. Will gar nix anderes mehr:rolleyes:
Hallo Freunde ich suche das Kreis förmige omege bild mit dem Löwe könnt ihr bitte helfen !!
Hi liebe Leute,wie ist denn das? Ich hatte die v.22 geflasht,dann eingerichtet und dann ein Thema(Chrome Blue Style) geflasht.Da passierte dann aber nix mehr.Bildschirm blieb schwarz.Sind die Themes denn mit jedem Omega ROM kompatibel?
Gruß Fiedl
Hallo,vielleicht könnt ihr mir ja weiterhelfen.
Hatte die ganze Zeit eine 20mbit Leitung(Arris Modem+Dlink Router) von*KabelBw*und wenn ich mit der*App*von speedtest.net meine Geschwindigkeit geprüft habe bin ich über*Wlan*immer auf die 20mbit gekommen.
So,nun habe ich vorgestern eine Fritzbox Cable 6340(integriertes Wlan)und meine 100mbit Leitung von KabelBw bekommen und wenn ich nun meine Geschwindigkeit mit meinem Note 2 prüfe,dann knallt der Zeiger kurz auf ca 30mbit hoch und fällt dann sofort auf 15mbit hinab,manchmal sogar nur 10-12 mbi.
Woran kann das liegen ???Ich sitze direkt vor der Box.
Mit meinem Notebook sowie dem*Desktop PC*und AVM FritzWlan Stick komme ich auf ca.85mbit und direkt über Lan auf die vollen 100.
Warum kommt das Note nicht über die 15mbit hinaus,woran kann das liegen,den N-Standart für die 300mbit sollte es ja können.
Hat das problem noch jemand von euch oder ist das normal?
Habe die V18 drauf.
Hast du irgendein Gerät das den N Standard nicht unterstützt? In dem Fall geht die Fritz Box nur auf den höchsten Standard der von allen Geräten unterstützt wird.
Im Netz hängt das S3 meiner Frau, das Note 2 und mein Desktop Pc woran der Fritz Wlan Stick angeschlossen ist.
Wenn ich den Speedtest mit dem Wlan Stick am Desktop mache komm ich auf knapp 90mbit und wenn ich den Speedtest mit dem Note oder dem S3 mache komm ich auf 12-15mbit.
Vorher mit meinem Arris Modem und der 20er Leitung bin ich immer auf die volle Geschwindigkeit gekommen.
Versuch mal den Funk Kanal der Fritz Box zu wechseln.
Hab ich auch schon....
Die V23 kommt demnächst raus wie Indie auf XDA angekündigt hat.
Omega v23 Opening Post and Download Center:
Changelog:
Based on firmware XXUENA1 Android 4.3 (Date: 15/01/2014)
Kernel XXUENA1
Modem XXUEMJ9
Added:
OmegaDroid Kit Kat Wallpapers by our artist Jorq1H
Updated:
Super SU
Super SU binaries
Samsung IAP
Accounts Sync Profiler
ChatON
CPU Adjuster
Dolphin JetPack
Dropbox
ES File Explorer
Flipboard
Google Play Books
Google Play Newsstand
Google Search
Hangouts
Maps
Notification Manager
Recycle Bin
Rom is No Full Wipe
Omega Files:
Omega Files Pro:
Direct Links for Omega v23 added to Omega Files Pro with resume option
Update repo to Omega Files Pro to get the updates for v23
Please read the following before flashing v23:
Bootloader - Knox:
Backup:
Wipe:
2. Boot to recovery and flash Omega v23 and then reboot system.
csc:
Remove bloatware:
Note 3 apps:
Download Center:
Donation:
If you like Omega v23 + Omega Files app and you use them please consider a donation.
Enjoy the new Omega
Reaktionen: TheFarmer30 und LightDr@gon
Noch gar keine Reaktionen auf das Update?
Das update läuft bis jetzt 1 a. Konnte noch keinen Fehler entdecken und sperrt schnell ist auch alles. Habe Alles Stock gelassen und einfach ohne Wipe über die V22 geflasht.
Da ich auch auf der 22er bin kann ich ja auch ohne wipe drüber gehen und installierte apps etc. sollten vorhanden bleiben, richtig? Zumindest in aller Regel.
Ja habe ich auch so gemacht.
Thoddü
  • Thoddü
Lady_in_black
redbull1
bernardo65
bernardo65
Androidwizard
LtComJCFox
