[ROM][N7100][XXUFND3][4.4.2] *22.05.14* PhoeniX ROM v18.8 [Note 3 Features]
  • 760 Antworten
perog
perog
Stamm-User
690
WICHTIG:
WICHTIGER HINWEIS:
Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg oder die Haftung für jegliche Beschädigungen an eurem Note 2.
Wenn ihr nicht sicher seid, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Daher flashen auf eigene Gefahr.
Hello Flashers!
I'm proud to present you my latest work!
PhoeniX ROM
Users Pay Attention!!!
Make sure you read this before flashing v18:
http://forum.xda-developers.com/show...ostcount=11247
Based on the lastest stock firmware: Android 4.4.2 XXUFND3 (build date: 09/04/2014)
Modem: XXUENA1 Or XXUFND3(Choose in the aroma)
Stock XXUFND3 customized kernel by me:
- Insecured boot.img for full Root Access
- Init.d Support
- ExFat Support
This ROM is 200% Knox Free - You can say "Cya Knox!"
PhoeniX First Setup
Multi CSC(136 CSC) Set to EUR. If you want to change CSC:
Quote:
First, install Stock Android Recovery
Second, select your CSC and install.
Third, Install PhilZ/TWRP recovery
Enjoy
Fully Deodexed
Added latest BusyBox
Added latest SuperSU+Bin files
Added GenieWidget
Added Flashplayer support
Added ES File Explorer
Added Facebook
Updated all stock apps to their latest version(Gmail, Google search, Google Maps, Google Earth, Chrome,Play store etc.)
Mods:
  • Call Recorder
  • Phone with no increasing ringtone
  • All supported languages enabled
  • Added App Ops support in settings
  • Enabled Hidden Settings Widgets:
    - Power Control
    - Mono Audio
    - Negative Colors
    - Portable Wifi Hotspot
    - Smart Network
    - Favorite Settings
    - Hands-Free Mod
  • All supported languages for Samsung Keyboard enabled
  • Enabled init.d scripts
  • Added the following S5 features:
    - S5 Accuweather
    - S5 Customized settings:
    * Removed unsupported options like Fingerprint, Private Mod(need knox),
    * Spen support
    - S5 Splanner
    - S5 Ultra Power Saving Mode
    - S5 Toolbox with support for 10 apps!
    - S5 Customized SystemUI:
    * 33 Toggles mod with unique toggles:
    Flashlight - 1 press turns it on, long press flashlight settings
    Battery status - 1 press battery status , long press battery information
    PhoeniX - 1 Press/Long press open PhoeniX Settings
    Take Picture - Called "Shoot-it" by @dr.ketan. Single press takes picture without shooting sound (3-4 sec) long prees takes picture with shooting sound(3-4 sec) - also avilable as an icon in app drawer, so 1 press on app called Shoot it takes picture without shoooting sound, 1 press on app called Shoot it SF takes picture with shooting sound
    * Removed Quick Connect and SFinder big buttons and replaced with 1 single SFinder button besides the date.(Quick Connect is available as toggle)
    - S5 Lockscreen with option for Weather & Pedometer(If you use personal message you won't see them)
    - S5 Launcher
    - S5 launcher themes with 12 themes!
    - S5 Download Booster
    - S5 Wallpapers
    - S5 Google Search Widget with "Ok google" option from launcher(you must choose Google Search in aroma if you want it)
    - S5 My Magazine
    - S5 SFinder
    - S5 My Files
    - S5 Keyboard
    - S5 Svoice
    - S5 Car Mod(requires svoice)
    - S5 Shealth
    - S5 SamsungApps with option to download all S5 Apps Gifts
    - S5 SMemo
    - S5 Snote
    - S5 SBaro
    - S5 GroupPlay
    - S5 Contacts
    - S5 Phone with no more lag between Contacts and Phone tabs, also with popup call support
    - S5 SBrowser
    - S5 Calculator
    - S5 SMS
    - And more!
  • Enabled & Improved 8 Lockscreen Effects:
    - None (AOSP style)
    - Modded Ripple Effect:
    * No cloudy overlay - Thanks to @Goldie
    * Improved ripple effect - Thanks to @Goldie
    * Ink effect with the finger
    - Light effect
    - Popping Colours
    - Water Color
    - Blind
    - Oil Paint
    - Stone Skipping
  • KitKat SD Support Fix
  • Shutter Sound menu Enabled to stock camera
  • Big APN list
  • Call Delay After call End Reduced to 0ms
  • Enable sub Symbols on Stock Samsung keyboard
  • Added exit menu to stock web browser
  • Option for custom bootanimation. put it in data/local/
  • Dialer search matches numbers in contacts and call logs along with contacts
  • Permanently removed SysSCOPE from system and forced System Status to show "Official" - Special thanks to Aou
  • data/app enabled
  • Added Xposed framework with alot of modules and options:
    - Xposed installer - thanks to rovo89 his thread
    - Wanam Xposed - thanks to wanam his thread
    - DPI Settings - thanks to rovo89
    - MultiWindow Manager New Edition - thanks to BJB, Inc.
  • Enable call button in contact list
  • Upgraded Power Menu:
    - Extended Reboot Menu
    - Flashlight
    - Screenshot
  • Full Note 3 experience made by tamirda, dr.ketan and wesamothman:
    - Note 3 Launcher
    - Note 3 Accuweather Widget
    - Note 3 Multiwindow
    - Note 3 Fully Working Aircommand
    - Note 3 One Handed Option Fot all screens
    - Note 3 Keyboard - Thanks avivalder
    - Note 3 SNote, SNote V3.0 with the ability to sync notes from old SNote using Samsung Account.
    - Note 3 My Files
    - Note 3 Contacts and Phone (with option for popup incoming notifications)
    - Note 3 Browser
    - Note 3 S Planner
    - Note 3 Sounds
    - Note 3 S Finder, Pen Window, Scrapbooker
    - Note 3 Apps like SketchBook, Evernote and more
    - Note 3 Gallery
    - Note 3 Writing Buddy
    - Note 3 My Magazine
    - Note 3 Installation Wizard(First setup)
    - New Note 3 Wether & Calendar widget when pulling down the clock on lockscreen
    - Note 3 Widgets (Like alarm widget)
    - And much more!
  • Added Pen Window Manager - thank you Xperiacle!
  • option for Air Command with the finger - Air Command shortcut by Xperiacle!
  • New SMS app Mods:
    - Folder View Option
    - Backup/Restore SMS Option
    - Split view option
    - Change text size using volume keys option
    - Screen On/Off for notification alerts option
    - and more!!
  • Added Launcher Special support:
    - PhoeniX SlideLaunch -Instead of My Magazine in S5 Launcher you can choose any app you want to open, for example settings, camera or gallery - amazing feature.
    - PullUp Option
  • Added PhoeniX Air Command Controller: Now you can replace SFinder in aircommand with every app you want.
  • Enabled IP Call for SIP users
  • Allowed some hidden settings:
    - Display -> Open Editor after taking picture
    - Air Command
    - One Hand for all screens
    - SPen -> Display input(Writing buddy)
    - Display -> Torchlight
    - Handwrite language selector for Action memo and Air Command
    - And More!
  • Exclusive! Only to PhoeniX ROM!:
    * RTL Menus when you select Arabic/Hebrew as your default language. (Pictures at post 4)
    * New Amazing Wallpapers in Wallpaper Chooser Wallpapers! Beautiful Wallpapers! How to use? Click on Menu-> Set Wallpaper-> Home/Lock/Both-> Wallpaper Picker/chooser-> Select your Wallpaper! (Picture at post 4)
    * New Settings app: Now will be only 1 shortcut in the Settings, to PhoeniX Settings App with the following fetures:
    Samsung Secret Codes
    Fast Dormancy
    Faster Fix GPS
    CSC Select
    CPU Spy Plus
    Battery Chooser
    Terminal Emulator
    Xposed +Modules
    Idle Wifi Time Manager
    Logcat
    OS Monitor
    PhoeniX OTA Center - now you can update the rom without plugin into the computer!
    The OTA Center can be found in PhoeniX Settings.
    The downloads will be save on the internel SD card(if you use my memory script so it will be saved in the externel sd card) undr the folder OTA updates.
    And more coming soon
    Post 4:
    http://forum.xda-developers.com/show...31&postcount=4
  • Added Better GPS Config
  • TouchWIz Rotation available(landscape mode available) - thx to Rotry83
  • Extended speed dials to 100
  • A New superb & amazing Wallpaper pack including S5 & Note 3 & S4 wallpapers + alot of my collection - 61 wallpapers!
  • Added TB Restore Fixer Stub by -viperboy- his thread
  • Added Official OmegaDroid Android News app - I am reporter and editor there, so if you want to read the best news about android, use this!
  • Added OGBatteryMod with 60 different styles from my collection! thanks for OsamaGhareeb his thread
Tweaks:
Built.prop tweaks
zipalign
Kernel Tweaks
Removed from the rom:
- ReadersHub
Aroma Installer:
Apps that was marked as bloatware and can be installed/removed in the aroma:
  • Samsung Gear Support Add Samsung Gear Support
  • Android 4.4.2 Camera Android 4.4.2 Camera from Nexus 5
  • Samsung Chaton
  • Google Plus
  • Google Chrome
  • Google Maps & Street
  • Android 4.2 Clock Android 4.2 Clock
  • DropBox
  • Facebook
  • Adobe FlashPlayer Flashplayer Support
  • Flipboard
  • Samsung S5 Group Features
  • Google TalkBack
  • Google Hangouts
  • Mobileprint services Mobile print services
  • Pie Control
  • Polaris Viewer
  • Samsung Update Samsung Update services
  • S5 SBaro
  • Digital Clock Widgets
  • Dual Clock Digital Widget
  • ES File Explorer
  • Genie widget
  • Google Music
  • Google Search
  • S5 Shealth
  • MusicLiveShare
  • Samsung Apps
  • SPlanner App Widget
  • S Voice
  • AwesomeNote
  • Evernote
  • Story Album
  • S5 SMemo
  • Youtube
  • Samsung Link
In aroma you can:
  • Make Full Wipe
  • Make EFS Backup
  • Added as options in the Aroma:
    You can choose now tweaks you want to install!
    Tweaks list:
  • EXT4 Tweaks:
    Quote:
    This mod will turn ON data_writeback for all 3 partitions - system, data and cache. This will drastically improve I/O performance (mostly on write operations) at the expense of file system integrity in certain situations, like unexpected system shutdown. The risk is not extreme, but still bigger then regular. Use this to improve your system performance, but you flash it at your own risk!
    - thx to mike1983.
  • GPU Rendering:
    Quote:
    This mod is working similar to "Render GUI with GPU" option in Development Settings. Flashing this will force whole system to use GPU rendering (instead of CPU) for all kind of 2D/3D operations. This might improve 2D operations performance, but keep in mind that some apps are not working correctly with GPU rendering. After using this mod you no longer need to tick "Render GUI with GPU" in settings. Even if un-ticked it will be still working. Flash it at your own risk!
    - thx to mike1983.
  • OpenVPN Tweaks
  • SQLite Tweaks
  • Tweak: Force Launcher into memory
  • Tweak: 3G Tweaks - Speed up 3G connection
  • Tweak: Net Speed Tweaks - Tweak to speed up internet connection
  • Tweak: Latest Seeder thx to lambgx02 his thread
  • Touchscreen Responsiveness - Improve the touchscreen for a better responsiveness and user experience
  • Internet speed tweaks - Improve overall browsing speed
  • Battery consumption tweaks - Make battery last longer
  • Install various init.d smoothness tweaks - Improve general responsiveness and fixes lag
  • Enable Internal/External-SdCard I/O tweaks - Improve write/read speed and mount speed
  • Scrolling tweaks - Better, faster and stronger scrolling
  • Flash-Led Tweaks - Better flash-led intensity and camera-flash quality
  • Video-Streaming tweaks - Smoother and faster internet video streaming
    Warning!!
    Choosing all tweaks can cause for lags, etc. Choose only if you really need it.
    You can choose now mods you would like to install!
    Mods list:
  • Install Increased volume(thx to EdgaBimbam his thread) :
    - Mid Increased Volume: Increase to 58 DB
    - Ultra Increased Volume: Increase to 60 DB
  • Option to restore stock phone without call recording and with increased ringtone
  • Disable scroling cache
  • Option to Disable SMS in Call Log.
    You are able to choose between 2 mods:
  • Custom Phone Mod - No increasing Ringtone, With Call Recording.
  • Stock Phone Mod - No call recording, with increasing ringtone.
    You can choose sound mods:
    • Disable / Enable Boot Sound
    • Option to choose sound mod:
      - Install sound mod(Yes/No) :Latest Noozxoide EIZO-rewire™ PRO - Thx To Crescendo Xenomorph his thread
    You can choose transparent mods:
    • All system Transparent Mod:
      You can choose between:
      0% (Means no transparent)
      25%
      50%
      75%
      100%
    You can Choose TouchWiz Launcher Mod:
    • Stock 5X5 Without Wallpaper Scrolling
    • Stock 5X5 With Wallpaper Scrolling
    • TouchWiz Launcher tamirda's Mod - it gives you wallpaper scrolling, 6 apps in the Touchwiz Dock(where is the Apps Menu Icon - you can have 5 apps shortcuts+app menu icon), 5X6 Apps Grid
    • TouchWiz Launcher tamirda's Mod 2 - it gives you wallpaper scrolling, 6 apps in the Touchwiz Dock(where is the Apps Menu Icon - you can have 5 apps shortcuts+app menu icon), 5X5 Apps Grid
    You can choose the kernel you want you install:
    • Latest Stock Kernel
    You can have ulimited memory by using More Memory Script by mattiadj:
    Details: http://forum.xda-developers.com/show...45&postcount=6
    The option to install is in the Aroma
  • Added option to choose between original PhoeniX Boot&Shut down animation to Stock Boot& Shut down animation
    You can choose now which modem you would like to install!:
    Modems:
  • XXUENA1
  • XXUFND3
    Now you can install recovery using Aroma:
  • Latest PhilZ
  • Added option to choose between White S5 Keyboard or Black Note 2 Keybord - Special thanks to avivalder!
    New Section! Now you don't have to download GPS and get crazy any more! From now you can choose in the Aroma your GPS Config!:
  • Africa GPS Config
  • Asia GPS Config
  • Europe GPS Config
  • North America GPS Config
  • Oceania GPS Config
  • South America GPS Config
    thx to gangsterjoop his thread
    New ROM features available in the aroma:
  • Option to choose Flare Effect - special thanks to balliboxer his thread(and screenshots):
    - Blue Fire Rings
    - Blue Fire Flames
    - Blue Lightning
    - Blue Rings
    - Green Rings
    - Red Lightning
    - Red Rings
    - White Lightning
    - Yellow Fire Rings
    - Yellow Fire Flames
    - Stock
Installation Instructions for v18:
  1. DO SUPER WIPE!- Changing from 4.1.2 / 4.3 to 4.4.2 will change the location of your internal sd(In case of 4.3 some system data is stored in your internel SD, that is why you need to wipe it), just, that is why you must to super wipe, to clean your internal sd. backup first.
  2. If you are coming from 4.4.2 full wipe is needed
  3. Use Philz 5.15.0
  4. Flash v18. Choose your mods, etc.
  5. Reboot.
  6. You must be on MJ5 bootloader or higher, or you will have reboots & freezes!!!
  7. Quote:
    Originally Posted by dr.ketan
    1. Download and Install PhoeniX ROM V15 - .....+ watever instruction needs
    2.. Who already having MJ5 bootloader or higer, can start using ROM without further action.
    3. Who are on older bootloader and need to Flash New bootloader, Download this BL_MJ5_DN3 bootloader and extract
    • Open Odin from PC, Press PDA tab and select downloaded MJ5 Bootloader
    • Put device in download mode (Vol dwn + home +power)
    • Connect device and Flash
    Reboot device
    If you don't want this ROM, want to go back and downgrade, do this(Be careful!! This is only for MJ5 Bootloader!!) :
    N7100XXUEMJ5 How to Root + Remove New Bootloader + KNOX Free
    1.First Flash Complete ROM N7100XXUEMJ5 from sammobile posted here
    Now your device will have KNox enabled bootloader.
    2.Download MJ5BLPatch.tar.md5 and Flash with Odin for PDA Tab.
    3.Reboot device, You won't have wifi working.
    4.Download wifi patch and flash with Odin for PDA tab.
    5.Reboot device and you will have old Knox free bootloader with Wifi working.
    6.Flash CWM Recovery
    7.To root device Use my MultiTool. You have to download MultiTool advanced V5 for 4.3 from this post I am uploading right now.
    Once you root with this tool, It also remove KNOX apps from device.
    8.Don't open SuperSU but straight way go to play store and update SuperSU
    9.Now everything should be fine.
Bugs
Quote:​
  1. After First Setup, Hands-Free Mod turns on, you can just turn it off from settings or from Status bar not a big deal(it is only 1 time thing, it doesn't come back after reboot)
  2. After First Setup, Regular Power Saving Mod turns on, although you won't see it is on. In order to disable it go into Power Saving Mod Option(Not Ultra!), Turn it on, go into Restrict Performance and turn it off. That's it.(it is only 1 time thing, it doesn't come back after reboot)
    No big deal bugs.
Notes(pay attention!):
Quote:​
  • I'm not responsible for any damaged caused by using this rom. I test the rom before i publish it so you shuoldn't have any problems
  • Do Not Publish Any Mirror For the Rom!
  • If you use my rom as base, post a link to this thread+ credit
  • If you publish my rom, post a link to this thread + credit
V18.8 OTA Update
Warning! you must read this first:
New in v18.8:
  • PhoeniX Kernel V1.0:
    - Built from Samsung Kernel Source N7100
    - Linux 3.0.31
    - SELinux set to permissive
    - ExFat Support
    - XXUFND3 Ramdisk
    - init.d support
    - Build with stock ARM toolchain 4.4.3
    Kernel Source: Click Here!
  • Replaced S5 Sfinder with Note 3 SFinder
    Fixed:
  • Fixed Gallery FC
  • Fixed WiFi Direct FC
  • Fixed Splanner + Splanner Widget
  • Fixed FC in PhoeniX Settings(Wait till it asks for SU Permission)
  • Fixed init.d support, now EXT2Internel is working
V18.5
New in v18.5:
  • Added Ultra Power Saving Mode Apps Manager - Special thanks to xperiacle
  • Added option to choose 30 apps in Quick Settings(Tab/Grid/List View)
    Fixed:
  • Fixed Smart Clip FC
  • Fixed Bluetooth FC in Settings
  • Fixed SNote and updated to the latest S5 one.
  • Fixed Samsung sCloud sync FC
  • Fixed Smart Pause
    Updated:
  • Xposed Installer
  • Wanam Xposed
  • V18
    New in v18.0:
  • Rebuilt rom for 0! Rebased on the latest Official Android 4.4.2 version XXUFND3 (build date: 09/04/2014)
  • Stock XXUFND3 customized kernel by me:
    - Init.d Support
    - ExFat Support
  • Added new HD batteries styles, 60 in total!
    - S5 Accuweather
    * Spen support
    - S5 Splanner
    - S5 Launcher
    - S5 Wallpapers
    - S5 My Magazine
    - S5 SFinder
    - S5 My Files
    - S5 Keyboard
    - S5 Svoice
    - S5 Shealth
    - S5 SMemo
    - S5 Snote
    - S5 SBaro
    - S5 GroupPlay
    - S5 Contacts
    - S5 SBrowser
    - S5 Calculator
    - S5 SMS
    - And more!
  • Updated all Note 3 apps(Air Command support also).
    - PullUp Option
  • Enabled SFinder & My Magazine in app drawer
    - Flashlight
    - Screenshot
  • Added PhoeniX First Setup
    - Power Control
    - Mono Audio
    - Negative Colors
    - Smart Network
    - Favorite Settings
    - Hands-Free Mod
    - None (AOSP style)
    - Light effect
    - Popping Colours
    - Water Color
    - Blind
    - Oil Paint
    - Stone Skipping
    Removed:
  • Readers Hub
  • Bye Bye Knox
  • Nottach Xposed
    Fixed:
  • Fixed Black background when minimizing apps
  • Fixed YouTube in Scrapbook in newer Youtube Versions
    Updated:
  • 136 CSCs. CSC Version: N7100OXAFND3. How to change CSC?
    Enjoy
  • Updated all mods in the Aroma - All mods are available to install!(Some removed, see Aroma Log)
  • Updated Apps to their latest version:
    - Chrome
    - ES File explorer
    - Adobe Flash Player
    - GMS Core
    - Play Store
    - DropBox
    - Gmail
    - SPPush client
    - Samsung apps
    - Chaton
    - Samsung IAP
    - Flipbaord
    - Earth
    - Voice Search
    - Update Samsung Link
    - Hangouts
    - SuperSU to latest
    - And more
    Attention everyone!
    To get a good battery performance, you have to make Battery Calibration. To make that, search Battery Calibration at Play Store.
    Extra!
    Use PhoeniX Kitchen to get extra items easily!
    Play store link:
    Warning!!
    Wait till I update the mods in the kitchen, using v17 mods on v18 100% will cause for bootloops.
    And more that i must have forgotten
Aroma Changelog:
New in Aroma:
  • Removed 2 old modems.
  • Option to choose modems:
    - XXUFND3
    - XXUENA1
  • Added, Updated & Changed Bloatware selecion:
    - Samsung Gear Support Add Samsung Gear Support
    - Android 4.4.2 Camera Android 4.4.2 Camera from Nexus 5
    - Samsung Chaton
    - Google Plus
    - Google Chrome
    - Google Maps & Street
    - Android 4.2 Clock Android 4.2 Clock
    - DropBox
    - Facebook
    - Adobe FlashPlayer Flashplayer Support
    - Flipboard
    - Samsung S5 Group Features
    - Google TalkBack
    - Google Hangouts
    - Mobileprint services Mobile print services
    - Pie Control
    - Polaris Viewer
    - Samsung Update Samsung Update services
    - S5 SBaro
    - Digital Clock Widgets
    - Dual Clock Digital Widget
    - ES File Explorer
    - Genie widget
    - Google Music
    - Google Search
    - S5 Shealth
    - MusicLiveShare
    - Samsung Apps
    - SPlanner App Widget
    - S Voice
    - AwesomeNote
    - Evernote
    - Story Album
    - S5 SMemo
    - Youtube
    - Samsung Link
  • Keyboards Selecion:
    - Note 2 Black Keyboard
    - S5 White Keyboard
  • Updated GPS Configs
  • Updated Launcher Mods:
    - Stock 5X5 Without Wallpaper Scrolling
    - Stock 5X5 With Wallpaper Scrolling
    - TouchWiz Launcher tamirda's Mod - it gives you wallpaper scrolling, 6 apps in the Touchwiz Dock(where is the Apps Menu Icon - you can have 5 apps shortcuts+app menu icon), 5X6 Apps Grid
    - TouchWiz Launcher tamirda's Mod 2 - it gives you wallpaper scrolling, 6 apps in the Touchwiz Dock(where is the Apps Menu Icon - you can have 5 apps shortcuts+app menu icon), 5X5 Apps Grid
  • Updated EXT2InternalSD to V6 - Read warnings in the link above.
  • Updated SPenBoardSwitcher to V3
  • Removed 240DPI Mod - Makes alot of problems in KitKat
  • Removed Odex Mod - Makes FC to all Google apps, kitkat is fast even in deodexed mod.
v18.5+Old downloads:
http://www.tdroms.com/samsung-galaxy...-rom/downloads
V18.8:
OTA Update has been released. It is working only on V18.5/V18.7. Gallery Fix is included in V18.8.
You can download it from PhoeniX OTA Manager
Or
Click Here!
No Need to wipe.
OTA Is working only on V18.5/V18.7
Extra Items download:
http://tdroms.com/index.php/samsung-...om/extra-items
PhoeniX Kitchen:
http://forum.xda-developers.com/show...31&postcount=3
or
http://tdroms.com/index.php/samsung-...hoenix-kitchen
If you like my rom and work, please consider a donation:​
Click here to lend your support to: Help tamirda to get a Samsung Galaxy Note 3!
If you can't donate or just don't want it is ok! but please make the following:​
Rate this thread 5 stars
Click thank to my Posts
If you wish to report a bug,​
Do it only in this thread or in this link:​
- If you just want to share something, follow me/this rom, talk with me, you have alot of options
1. Write in this thread​
2. Write here: Contact Us
Credits:
  • :indie::
  • mike1986.
  • shnizelon
  • pavelol
  • anbech- For his amazing design of - bootanimation, signatures and logo!
  • LegendK95
  • kkoolpatz
  • Dsixda
  • wanam
  • Chainfire
  • Kleinyair
  • ikogsakanding - for thread & rom graphics
  • FireFDS
  • Rotry83
  • bmw-boy
  • kest874
  • EdgaBimbam
  • cb56
  • iakovl
  • Crescendo Xenomorph
  • Rotry83
  • turkbey
  • ficeto for settings app
  • wl3gan
  • Mr raffaele88
  • Poppuri
  • bala_gamer
  • Xposed Team
  • mattiadj
  • mrlove6
  • Andy Wong
  • droid27
  • DeHuMaNiZeD
  • Eric-Mod
  • mikeyxda
  • jujuburi
  • simone201
  • ravi923615
  • czar22
  • maquinabaja
  • Jeffrey Blattman(for Logcat app)
  • Mirko ddd
  • bjbinc
  • lidroid
  • dr.ketan
  • Didact97
  • grilleld
  • AskinSavacisi
  • noname81 for LMT Pie
  • Nottach for Nottach Xposed
  • -viperboy- For TB Restore fix
  • OsamaGhareeb
  • Jack Palevich For Terminal Emulator
  • shhbz for being helpful friend
  • P.M Me if i had forggoten some one!
  • All XDA Comunnity
Screenshots:​
XDA:DevDB Information
PhoeniX ROM For Samsung Galaxy Note II, ROM for the Samsung Galaxy Note II
Contributors
tamirda
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.0.x
Version Information
Status: Stable
Current Stable Version: v18.8
Stable Release Date: 2014-05-22
Created 2013-09-04
Last Updated 2014-05-22
Reaktionen: netsroh7, Gamer-one, K_One90 und 5 andere
Ich hatte die V7.xx drauf und muss sagen dir Rom läuft richtig schnell und sauber.
Gesendet mit meinem Commodore 64
Edit bin auch schon am laden :)
Danke dir für deine Meinung.
Ich selber kam noch nicht dazu die V8 zu testen werde ich aber noch tun.
Endlich! Ich hatte die schon ein paar mal drauf. Läuft super mit viele Einstellungsmöglichkeiten. Akku war auch gut.
Gruß Dirk
Reaktionen: Robby57
Geladen hab ich sie schon nur noch flashen.
So habe sie auch drauf und bis jetzt alles super.Die Romeinstellmöglichkeiten und die Aroma-Auswahl ist echt sagenhaft.
Transparenzmöglichkeiten von 0 bis 100%
LG Robby
Habe das Gefühl das die Kamera nicht so ganz funzt. Bilder sehen so pixelig aus.
Gesendet von meinem GT-N7100 mit Tapatalk 2
Robby, vielen dank dafür! Das ist der Grund warum ich mein Note2 LTE ohne zucken verkauft habe! Custom ROM wohin man schaut :thumbsup:
Gruss
Reaktionen: Robby57
Habe noch keine Bilder gemacht aber das kann doch normal nicht sein denn an der Kamera App wird doch nichts verändert und die Rom hat auch nichts damit zu tun. Hat sonnst noch wer das festgestellt?
LG Robby
Nope, keine Probleme mit der Kamera feststellbar.
Moin Pio! Erscheint bei dir auch beim schließen der Kamera kurz das Hintergrundbild?
Gruß Dirk
Was meinst du genau ? Ist doch normal wenn man zurück auf den Desktop geht.
LG Robby
Wenn ich den Kameramodus beende kommt erst das Hintergrundbild dann nochmal ganz kurz das Kameramenü und dann schließt sie erst komplett.
Gesendet von meinem GT-N8000 mit Tapatalk 2
Ist bei mir nicht so habe beide Kamera Apps installiert und bei beiden ist das nicht der Fall.
LG Robby
Reaktionen: bullwei
Dann flashe ich sie nochmal neu!
LG Dirk
edit! Entwarnung........funktioniert wieder alles!
Flashe ja immer ohne Fullwipe und hatte noch nie Probleme aber mit Fullwipe
dürfte normal nichts schief gehen.
LG Robby
Reaktionen: bullwei
Reaktionen: Robby57
Gibt es doch garnicht den ganzen morgen war nichts in Sicht und kaum ist nan auf der Arbeit 3 neue Updates.
Der ursprüngliche Beitrag von 20:40 Uhr wurde um 20:57 Uhr ergänzt:
Startseite halbwegs angepasst mit Link .
Rest folgt nach der Arbeit
LG Robby
Hallo zusammen, bin auch seit 1 woche stolzer besitzer vom Note2... :D bin von den genzen Roms an diese hängen geblieben aber ich brauche eure hilfe, bekomme es nicht hin den openpdroid in der rom zu patchen... hat es jemanden von euch geschafft?? M.
Stehe gerade auf dem Schlauch was ist openpdroid bitte?
