[ROM][N7100][XXUEMK9][4.3] *18.03.14* AllianceROM v5.2
  • 251 Antworten
Cpt. Future
Gast
AllianceROM N7100 XXUEMK9 JB 4.3 v5.2
Mein Dank gilt folgenden Usern
Goldieking, Comnam90, Trx33, NunHugger, Mr V, Tpip, Dazznutts2000, Dikkebas, Mikey Mopar, Steff
and beta testers
Downloads
Changelog
MK9 v5.2 JB 4.3
As v5.1 plus:
Latest v3.5 note 3 apps
Alliance or stock theme
Choose whether to install kernel/recovery
MK9 v5.2 JB 4.3
Color Changers
Statusbar with Awesome KitKat gradient option!!!
Signal/wifi
Clock
Battery
Notification Icons
Traffic Meter
Battery Bar
Toggles On
Toggles Off
Toggles Dim
Toggles Text
Settings Button
Dropdown Clock
Dropdown Header
Dropdown Date
Dropdown Handle
Dropdown Background
Brightness Slider Background
Clear Button Background
Ongoing Headers
Power Menu
Phone text (option to turn off 3rd party apps)
Dialpad/phone tabs/contact tabs
Overscroll
Checkboxes and Switches
Spinners
Statusbar Mods
Clock
Right/center/none
am/pm style small/large/none
Day of Week small/nnormal/none
Icons
Show/hide Alarm
Show/hide Bluetooth
Show/hide Volume
Show/hide Keyboard
Show/hide Dormant Mode
Battery selector
Battery charge selector
Battery Bar
On/off
Choose style
Choose thickness
Charge animation on/off
Traffic Meter on/off
Dropdown
Alliance Wallpaper app
Hide dropdown Header
Date shortpress launch app
Date longpress launch app
Hide brightness slider
Hide notifications title
Hide no notifications title
Toggles
Hide toggle text
Hide toggle indicator
Number of toggles in view
Power Menu
Show/hide Data
Show/hide Airplane
Show/hide Accessibility
Show/hide Power Off
Show/hide Restart - with 4 way reboot
Show/hide sound options
Phone Mods
Call record
Automatic incoming call record on/off
Automatic outgoing call record on/off
Remove increasing ringtone
Set end call delay
General Mods
Low storage notification on/off
Low battery popup on/off
Full-charge notification on/off
USB connect sound on/off
Email security on/off
NFC With screen off on/off
Nfc icon show/hide
Apps
Restart SysUI
Restart SecPhone
Back N Theme back up app
Dropdown Wallpaper
Unlim multiWindows
Any app pen Window
Alliance control in settings
Torch on lock screen enabled in settings>display
SMS
Save messages to sdcard
No mms conversion
Group messaging enabled
Scheduled messaging enabled
Unlimited recipients
No sms in call log
Increased sms per hour limit
Split view on/off toggle enabled
Increased mms image size
Screen on/off notification toggle activated​​
Wie wird die ROM geflasht?
Benutzt bitte den ROM-Customizer
  • Packt die ROM auf den internen SD
  • Installiert die TWRP recovery
  • Macht eine EFS Backup
  • Öffnet den ROM Customizer und wählt flashen von der internen SD aus
  • Wählt einfach die ROM aus dem internen Speicher
  • Achtet bei der Installation das ihr ein Full Wipe macht
  • Es wird wie immer empfohlen vorher ein Backup zu machen
Quelle: AllianceROM
Reaktionen: McMiller, mareis1973, SlayEngine und 5 andere
Danke Viper:thumbsup:. Werde sie heute Abend gleich mal testen.
LG
Danke Dir perog!:thumbup:
Ich kann es kaum abwarten endlich diese ROM zu testen!
Den Das Team hat in der Vergangenheit geniale ROMS gekocht. Und die ersten Bilder versprechen einiges!
Gruss
Ohne mir auch nur ein Wort vom 1. Post durchgelesen zu haben: geilo!!! Die Roms fürs Note 1 waren immer der Hammer!
Habe es seit heute morgen laufen und bisher top. Die Einstellmoeglichkeiten sind enorm.
Kann mir jemand sagen wenn ich die Farben von zb der Uhr oder Datum ändern will wie der Farbcode von dem JB blau ist ?
Gesendet von meinem GT-N7100
Hey!
Hab die Rom auch schon seit heute morgen drauf. Läuft ganz gut soweit.
Hotboot funktioniert nicht. hängt sich beim Samsunglogo auf.
Aber kann mir jemand sagen wieso in dieser Rom Version ein Kernel von Oktober 2012 intigriert ist? Hat dieser schon den Sudden Death Fix?
Welchen Kernel könnt ihr empfehlen?
Hab jetzt erst mal den RedPill drüber geflasht.
Bildshirm 1.5h an
http://s7.directupload.net/file/d/3158/mqfaqe45_png.htm
finde seltsam das das der Android OS Prozess so viel verbraucht..
Ach du Schei . . .
Nur 57kb?
Das dauert ja Stunden.
Moin lassiter nimm doch den Mirror! Da lade ich gerade mit 1MB/s runter!
MIRROR
Gruss
Reaktionen: T2X und lassiter34
Nutze den neak 1.6 und hotboot geht
Moin Viper, ich danke dir.
Jetzt ist es in 25 Minuten erledigt.
Also die Einstellmöglichkeiten über "Alliance Controll" sind enorm! Man kann wirklich viles einstellen und verändern. Ich habe diese ROM bereits zur Note1 gerne genutzt.
Sehr flüssig keine ruckler. Ich bleibe erstmal auf dem Standard Kernel werde aber später die Perseus flashen.
Gruss
Dem kann ich nur zustimmen.
Alles fertig eingerichtet, ebenfalls mit Standard Kernel.
@Viper, hast du schon an der dpi rumgespielt?
Ich weis echt nicht wo ich etwas verstellen soll :) Nein an der DPI hab eich nichts verstellt da die grösse für mich gut genug ist. Scheint standard 320 zu sein!
Gruss
Hatte sie eben auch geflasht, aber schon das Wiederherstellen von SMS und Protokollen brach mit Fehlermeldung ab.
Habe es mehrfach versucht.
Schade...
Getapatalked von meinem NOTE2...you know... yiiipiiiyayeee, Schweinebacke...! ;-)
Stimmt. Verdammt viele Möglichkeiten. Hätte gerne 230 dpi, hoffe das der Lockscreen mitspielt.
Gesendet von meinem GT-N7100 mit Tapatalk 2
Der ursprüngliche Beitrag von 23:30 Uhr wurde um 23:52 Uhr ergänzt:
Habe mal auf 230 dpi geändert. Samsung Tastatur wird immer beendet und auch Maps.
Leider nicht zu gebrauchen.
Sonst läuft die Rom echt super.
Ich denke das da noch ein Paar dinge verändert werden muss. Ein versuch ist es allemal wert! Ist ja noch die v1. Auf XDA sind die fleissig am kommentieren. ich denke da kommt bald ein update.
Gruss
Also bis jetzt echt top.
Habe es auch seit gestern morgen laufen und bin begeistert War vorher auf omega unterwegs aber die Rom hier finde ich von Look genial und die Einstellmoeglichkeiten sind so enorm gepaart mit dem ota tool ist es für mich die beste Rom im Moment mal sehen wie es weiter geht damit
Kann ich Colt Seavers nur zustimmen. Selbst unser crt-off ist wieder da.
Reaktionen: Seavers11
Thoddü
  • Thoddü
Lady_in_black
V
Androidwizard
Androidwizard
Androidwizard
LtComJCFox
