[ROM][N7100][KSUKNI3][4.4.4] *21.01.15* DN4 v2.1
  • 578 Antworten
Androidwizard
Androidwizard
Philosoph
2.578
[FONT=Hind, sans-serif]Fixes V1:[/FONT]
SoundAlive Equalizer in Music - Wipe data and cache of the app before use. OR install Viper
Action Memo - Schrifterkennung -fixed- Update languages in Samsung Keyboard
SuperSu-ständige Anfrage -fixed- flash Su update 1.94 and then update from market.
Lockscreen - kein Wetter -fixed- Need to be located with gps for weather.
Fehlermeldung bei Anruf - GestureService FC -fixed- Freeze the service with Titanium.
Settings app - nur englisch -fixed- New settings from: https://my.pcloud.com/publink/show?c...hNwBUYCJMzwgsy
Bluetooth-kein Sound - Update 1
Schwacher Sound -Fixed- Install ViperSoundMod oder AGNi Sound Mod
Group Play und Group Camcorder -FC when exiting app kein Share -fixed- update 1
Camera -fixed- Update 1
Dictionary -Fixed- Update 1
Removing the pop-up notification after phone restart about Data- Go to Settings>Data Usage> Remove the Confirm network Connection tick.
Weltuhr - FC- Fixed- Just replace stock app (system/app) with this and set permissions 0644https://www.dropbox.com/s/697h914dbk...ckage.apk?dl=0
Studio-Not working properly-Fix by @nitol : here
Fix für alle, die PIN oder PASSWORD gesetzt haben : Here Thanks to @dr.ketan .Just follow his guide .
PIN protect- FC-do not touch- Fixed with Update 2
Password lockscreen-woking but unable to unlock phone -do not touch bug-Fixed with Update 2 from ETeam
Delivery reports in SMS - Not working.- Fixed with Update 2
Email-Signature- can't select word-FC-Fixed with Update 2
Keyguard FC and stuck on lockscreen-Caused by changing the launcher- Before locking the phone or restart be sure to select default launcher
In call when using speaker phone- mic is not working-avoid speaker phone.- fixed after Update 2.
Move Content Function-FC-Reported working.
Palm to Mute/Pause-reported Working OR For Mute/Pause you can use - Turn Device Over.
Bugs[FONT=Hind, sans-serif] :[/FONT]
FM Radio - No Sound
Abstract tiles lock screen Effekt-FC-do not touch
Action Memo-no buttons if write on right side of memo
SPen Pointer Position
In Wi-fi-Share Wi-Fi Profile- No profiles stored no matter how many networks are saved.
Smart Alert and - Not working.
Video Clip Studio and Shot&more in studio - Not Working
Unable to make video call over 3G.
Gyroscope, magnetic &light sensor- Self test -FAILED
Calendar start end time-FC when moving trough menu.
Recent button- no haptic feedback.
Dual clock widget- FC when changing city or press MENU (the 3 dots on top)
Galaxy Essential widget- Graphics glitch
Share Shot -FC
Slideshow-some effects- FC
SMS to short numbers(operator)-FC
IN CALL VIA PHONE, SKYPE, VIBER- MIC DOESN'T WORK WHILE ON LOUD SPEAKER
No Docking Sound Output
Reaktionen: Marccom
UPDATES und FIXES V1
UPDATE 1 (01-11-2014)
INFORMATION:
Fix GroupPlay
Fix Camera
Fix Audio Bluetooth
Fix Dictionary
MEDIAFIRE
UPDATE 2 (04-11-2014)
INFORMATION:
Word Clock fixed in Clock app
Note2 Camera with option to disable shutter sound
Fixed content selection in Email app
SMS Delivery report fixed
Pin lock and Password lock fixed
Photo Studio can now save modified pictures
Gallery and SStudio are now multilanguage
Sms app is now multilanguage
Settings is now multilanguage
N4 Voice note added
Option to hide/unhide brightness bar added
Busybox added to avoid issue with Reboot shell
MEGA oder Mediafire
MD5: 94066C360A6607C0D2CF018C464852FA
UPDATE 3 (06-11-2014)
INFORMATION:
FIX Gesture service
MEGA oder Mediafire
UPDATE 4 (12-11-2014)
INFORMATION:
Smart Clip Fix
Signatue Lockscreen enabled and working
Fix for shutdown popup window (now it's white themed)
More pop-ups and apps white themed
Pen Select Pointer fixed
SMS to operator (short number message) fixed
Lockscreen effect added, now we have 15 lockscreen effects
Maybe something else will be fixed...
MEGA oder MEDIAFIRE
UPDATE 5 (28-11-2014)
INFORMATION:
Menu key Haptic Feedback
AirMessage added (THAT WILL WIPE YOUR MESSAGE DATA, MAKE A BACKUP)
Move contents fixed
No loudspeaker Mic sound in Skype and other Tchat apps fixed
Sound a little boosted
MEDIAFIRE 5
MEDIAFIRE 5b (für Nutzer von Xposed)
Reaktionen: dortmundez und Marccom
DIE ENTWICKLUNG WURDE EINGESTELLT
HOMEPAGE ETEAM
XDA-THREAD
Ditto Note 4 main features
  • Note 4 Air Command (new features)
  • Note 4 S Note with Action Memo
  • Note 4 Smart Select
  • Note 4 Image Clip
  • Note 4 Scrapbook
  • Note 4 S Finder
  • Note 4 Quick Connect
  • Note 4 Multiwindow
  • Note 4 Recent Apps
  • Note 4 Direct Pen Input
  • Note 4 Side Key Panel
  • Note 4 Resize Windows from corners (new Pen Window)
  • Note 4 Power Saving Mode
  • Note 4 Ultra Power Saving Mode
  • Note 4 Settings and UI
  • Galaxy Note 4 Launcher and Accuweather
  • Galaxy Note 4 Contacts app
  • Galaxy Note 4 Phone app with N4 feature incoming call popup notification, resize window during calls feature and call recording feature
  • Galaxy Note Messaging app with N4 feature SMS pop-up notificaton
  • Galaxy Note 4 lockscreen with charging effects and new lockscreen effects (only Abstract Mozaic don't work)
  • Galaxy Note 4 Music Player
  • Galaxy Note 4 Video Player
  • Galaxy Note 4 Internet Browser
  • Galaxy Note 4 Gallery with SStudio
  • Galaxy Note 4 S Voice with new pop-up features
  • Galaxy Note 4 S Planner, Email, Keyboard, Clock, My Files, Calculator
  • Galaxy Note 4 Story Album
  • Galaxy Note 4 Photo Note
  • Possible to use the same app in both multiwindows
  • Many more things that we might forget... see it yourself today.
CHANGELOG DN4 v2.1:
Music FX equalizer fixed
Agni Kernel 4.3.4 with Wolfson sound
Fixed SOD issue (screen not turning on)
Toolbox and Smart Scroll removed
S Note updated to latest version till date
Infinite spinner bug of Floating Message fixed
DOWNLOAD 2.1
MEGA PCLOUD MEDIAFIRE
MD5: A4D4D6C3A5C689EB7CD80F4104A7A2D4
Version 2.0
CHANGELOG V2:
Apart all the improvements of DN4 and the 5 updates this are the new things in DN4 v2:
Agni 4.3.2 kernel with Boeffla Sound Mod (Thanks to @psndna88)
Toolbox added (Credits to kenet & grouxo from esp-desarolladores)
Smart Scroll added
Splanner lag and Font issue in Year calendar fixed
Handwriting mode in stock keyboard fixed
Bluetooth should work properly now
Abstract Tile added
CURRENT BUGS:
Radio FM app doesn't sound
DOWNLOAD V2:
MEGA oder PCLOUD oder MEDIAFIRE
md5: C01B1AC44A64A9095ACB2FDE2197EF0B
240 DPI MOD für V2
DOWNLOAD V1:
PCLOUD
md5: 1368fac4432251596dc29581e4303e9f
INSTALLATION:
TWRP wird empfohlen, Philz ab 6.26 funktioniert
Full Wipe
Rom von ExtSD + SuperSu flashen
Reboot
240 dpi Mod
UPDATES in Post #2
FIXES UND BUGS in Post #3
Reaktionen: bernardo65, Marccom, dortmundez und 3 andere
Hab mir die DN4 gestern mal drauf gemacht. Lief erstmal sehr gut und gefiel mir auch. Hab dann angefangen meine Apps zu installieren. Damit einige Apps laufen, mußte ich öfters Neustarts durchführen. Nach dem xten Neustart wollte ich das Handy entsperren, Pin eingegeben und Meldung kommt, dass das Handy entsperrt wird. Diese Meldung ging dann nicht weg.
Nach 5 Minuten warten hab ich die DN4 nochmal neu drauf gemacht. Das Problem trat dann wieder auf. Hab dann mein Backup eingespielt. Schade...
Eventuell hätte auch geholfen, unter Sicherheit auf Werkseinstellungen zurückzusetzen.
Hast du denn einen Fullwipe vor dem flashen der ROM durchgeführt?
Nach dem Auftretten von dem Fehler bin ich da ja garnicht ran gekommen. Oder sollte ich das gleich nach den Flashen machen?
Jo, Fullwippe hab ich gemacht.
Gleich nach dem flashen, bevor du mit der Ersteinrichtung beginnst.
Reaktionen: Hexi
Hier noch ein sehr nervender Bug, egal wie Laut/Leise ich das Telefon stelle etc. Das Klingeln wenn ich jemanden anrufe ist so laut das ich fast Taub werde.
Das Freizeichen?
Japp genau das. Richtig laut und es macht mich Wahnsinnig,
Mit und ohne Lautsprecher kann ich das nicht nachvollziehen. Volume ändert auch nichts?
Soundmod beim AGNi?
Habe ich installiert mit dem 4.3.0. Mit der Stock rom ist der Ton normal laut.
Spricht stark dafür, dass es an AGNi Einstellungen oder einem verbundenen Soundmod liegt, denn im O-Rom ist AGNi 4.25 drin.
Einen guten Morgen an alle,
Wie kann ich
Weltuhr
Installieren !?
Danke für eure Hilfe. Einen schönen Sonntag.
Das erledigt man mit einem Filemanager mit Rootrechten.
ES oder Rootbrowser, ist wie ein Dateimanager unter Windows.
Gibt es schon nen Fix für den S Planer? Wenn ich da auf die Jahres Ansicht wechsle ist da alles zusammen gestaucht :/
Noch nicht.
2x DeepFreeze in 15 Minuten, seltsam.
Kann ich so nicht bestätigen die Rom läuft seit Release Stabil.
Hatte noch kein Deep Freeze seit über einer Woche, allerdings auf AGNi 4.30, was ich empfehle :thumbsup:
Thoddü
  • Thoddü
Lady_in_black
Androidwizard
LtComJCFox
redbull1
bernardo65
bernardo65
