Nasenspray-Junkie
Dauer-User
- 667
So heute hatte ich dann mal dieses Google Problem, Alzheimer lässt Grüßen
ultraslan schrieb:Obwohl ich bei der Browser Desktop ansicht deaktiviere , beim erneuten start ist es wieder bei Desktop ansicht. .![]()
4.3 is optimized for higher wifi frequency
- Some users like the ROM full, some others like it lite;
Here, giving you the freedom to select/build/cook your meal the way you like.
- Package size is ~ 1.2 GB. But that doesn't mean system partition will be full.
If you go bloatware-free (lite), you save > 312MB from your system partition.
- I could debloat more, but that might affect the stability/features of the ROM.
- Major overall improvements
- Updated Aroma binaries.
- Enhanced Installer Verbosity
- Aroma code/style changes
- Aroma code clean-up
- Kept Allshare: needed for WiFi-direct.
- Updated busybox.
- Updated hosts file to block unwanted apps.
- Updated sqlite
- Reverted to default CSC features for
Super [battery life, Fast, Smooth]
Memory optimization.
Tweaks for lower RAM.
Tweaks for supreme performance and speed.
Tweaks for better smoothness.
Tweaks for better and longer battery life.
Stability Update (Solid as Rock)
