theNick
Stamm-User
- 76
Hi sblock,
leider erkennt GMD den Stift nicht. Die Gesten lassen sich nur mit Fingern ausführen.
BG NIck
BG NIck
wesamothman schrieb:- ROM setup starts in English now, not in French.
- Full wipe is must.
- Fully Pre-rooted; no need to flash supersu anymore.
- Do NOT update supersu from play store; some testers had root issues after updating supersu from play store although I updated fine.
- Hurricane 4-way Reboot menu by default.
- Mixture (Hybrid) between (MI6, MJ2, MJ5, MK4) firmware releases.
- SE Linux status: permissive.
- Compatible with Xposed Installer and Wanam Xposed.
- Stability Update (Solid as Rock)
- Added MJ9 modem as an option in Aroma (total 5 modems)
Quote:
- DDDMG1
- XXEMI6
- XXEMJ2
- XXEMJ5
- DDEMJ9
- Fixed FCs in (SecBrowser, SecBluetooth, SamsungCamera).
- If google search gives you FC, just update it through Play Store.
- No need to flash new MJ2 or MJ5 or MK4 bootloader.
- KNOX free.
- Upradable / downgradable
- Stable, Super Fast, Super Battery Life, no lags
- Memory optimization.
- Tweaks for lower RAM.
- Tweaks for supreme performance and speed.
- Tweaks for better smoothness.
- Tweaks for better and longer battery life.
- Updated busybox
- Updated hosts file to block unwanted apps
- Enhanced installer verbosity
- Kept Allshare: needed for WiFi-direct.
- removed LuminousDots.apk
- removed NoiseField.apk
- removed PhaseBeam.apk
- removed PhotoWall.apk
- removed TopicWall.apk
- removed WeatherWall.apk
- removed bluetoohtest.apk
- removed Books.apk
- removed Magazines.apk
- removed Lcdtest.apk
- removed FactoryTest.apk
- removed Hangouts.apk: can be installed from play store.
- removed NfcTest.apk
- removed PlusOne.apk (Google+): can be installed from play store.
- removed SecFactoryPhoneTest.apk
- removed SelfTestMode.apk
- removed WlanTest.apk
- removed Stk.apk
- removed ContainerAgent.apk
- removed ContainerEventsRelayManager.apk
- removed KLMSAgent.apk
- removed KNOXAgent.apk
- removed KnoxAttestationAgent.apk
- removed KNOXStore.apk
- removed KNOXStub.apk
- added DeepSea.apk
- added vidoes.apk
- added secvideolist.apk
HNCC (Hurricane NoteII CSC Controller) Tool compatible
- updated Gmail2.apk
- updated GmsCore.apk
- updated Velvet.apk
- Don't forget to wait until you receive play store update 4.4.21
- Battery life to be tested after the ROM settles down for couple of full charging/discharging cycles.
- All the goodies from previous release still apply
