Xi-bit
Dauer-User
- 211
gehen die normalen spen gesten ?
deluxe299 schrieb:Ist ein fullwipe nötig von v 2 auf v3 ?
Hurricane v3.0 Changelog [17/10/13]:
- Rebuilt to be compatible with @dr.ketan ROM's MODs.
- Stability Update.
- Major overall improvements.
- From now on, both of current/future mods are mutually compatible between Hurricane and Dr.Ketan's ROMs.
- Enhanced installer verbosity
- Kept Helphub.apk in case you want to use Dr.Ketan's Note3 MOD package, it is needed.
- Changed wallpapers (homescreen+lockscreen) to the ones from android 4.4 kitkat leak
- Updated hosts file to block un-wanted ads.
- Removed Gameplay.apk
- Removed SMS from call log.
- Added videos.apk by request
- Added transparent widgets (Aroma)- Clock Widget- Added modem options (Aroma)
- FmRadio Widget
- Music Player Widget
- DDDMG1- HNCC (Hurricane NoteII CSC Controller) Tool compatible with both ROMs (Hurricane & Dr.Ketan's) ROMs
- XXMEI6
- Updated the following system apps:- FWUpgrade.apk
- ChatON_Market.apk
- ChromeWithBrowser.apk
- Earth.apk
- Gmail2.apk
- GmsCore.apk
- Velvet.apk
- MobilePrintSvc_HP.apk
- GMS_Maps.apk
- SPPPushClient_Prod.apk
- Youtube.apk
skysat schrieb:z. B. der Infrarotsensor, mit dem Gesten über dem Sensor erkannt werden.
Geht das mit unserem Note 2 mit den installierten Mods auch ?
