[ROM][4.3][XXUEMI6]Tigra_Rom V4[NOTE 3 Features][21/11]
  • 79 Antworten
redbull1
redbull1
Enthusiast
1.293
[ROM] [XXUEMI6] [4.3] [NOTE 3 Features]Tigra_Rom V4
Updated 21/11/2013
WICHTIGER HINWEIS:
Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg
oder die Haftung für jegliche Beschädigungen an eurem "Note 2 (N7100)".
Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Daher flashen auf eigene Gefahr.
Base
Sammy 4.3 Leak XXUEMI6
Features
Deodexed
Prerooted
Zipaligned
Turbocharged
Init.d Tweaks
buildprop tweaks
Launcher from Note3 with my Magazine
My files from Note3
Accuweather from Note3
All Note3 features from this thread (THANKS to the Op and the other guys here)
Ota updater
Xposed installer (in data)
Wanam xposed (in data)
Pen Window Manager (in data)
Lg Keyboard With Handwriting For people having problems with stock One
Polaris Viewer replased with Polaris Office
All Hubs Removed
Screens
Changelog
v4
Sammy 4.3 Leak XXUEMJ5
All System mods for Note 3 Features From Team Electron System Rom Base Quote:
Deodexed
Prerooted
Zipaligned
Turbocharged
Init.d Tweaks
buildprop tweaks
Build in entropy generator
PopUp Browser
All Note 3 Ported Featutes (One hand features,air command,air view options, and other more)
Modded SecMMS.apk thanks to friedrich420
All syncs work great
No gapp problems
Ota updater
All Hubs Removed
All knox related staff Removed
TigraRom V2.4
No major fixes.
Added Note 3 working keyboard (continious input and pen writing) thanks to @avivalder
This is a V2.3 with mini update and settings & pen window manager fix integrated.
Warning
If you have flashed V2.3+mini update+fix there is no need to flash V2.4.This is ONLY for new users of TigraRom
Quote:
Fix Fc with google proccesses
Google accound disappear Fix
Knox Removed
New keyboard with working Continious Input (Bug with handwriting and 2 languages didnt fix yet
All Updates of Tigra_Rom to a single Zip
no need to flash anything else.
I will update changelog if i remember anything else
Quote:
TigraRom V2.1 Update
Fix the missing frame on pen window thanks to @slink_59
Easy Clip fix included thanks to @funky81
Action Memo cosmetic fix thanks to @ravijiani
Added Note3 sounds thanks to @XDA_Waghmare
Air Command can now by activated/deactivated from Settings and Enabled One Hand Operations inside Settings thanks to @Arsaw
Browser from Note2 thanks to @slink_59
Thank you again to all From the Note 3 Porting Thread who make this happen
http://forum.xda-developers.com/show....php?t=2467810
Installation
1)Make A full Wipe System-Preload-Data-Dalvik
2)Flash Zip
3)Flash TigraRom_Update_To_V2.2
Downloads
v4
Link:https://mega.co.nz/#!mUVHgJDS!CXkKNG...YwKlsZ0wOxgb-E
MD5:FC9199597A1E4BB1917B4054846DCD8C
V3
https://mega.co.nz/#!LBNmnL4D!EjlpBGfzbBGK7Oi-AmklXQ1pHDZsDdOdvInChAwmL-E
MD5:E8CE1316E772068CCD66B7F17B466D57
v2.4
https://mega.co.nz/#!jQE2mbpI!TvBR138nWoFxGZqB4kSuERTUZehU--MIT1HSG_NIbzw
v2.3
https://mega.co.nz/#!TAsSSKDD!ci3_-x...Hz_5R8UKu0-RXg
MD5 Checksum
5DC6D72BC4BE6DC3979F4549C59676A6
v2.2
https://mega.co.nz/#!uZdiTaAT!bBs0XFhkxHVHxWi_RKt9PVJGdt4kMRhmAbXX5R_etrk
Viel Spass beim Testen!
Reaktionen: geier1, perog, Olli von G und eine weitere Person
So installiert isses der Ota-Updater bringt mir das die V2.1 als Update da ist.
Moinsen, sehr schön und erneut eine neue ROM:smile:
Habe den Titel etwas angepasst, bitte nicht wundern. Es waren Sonderzeichen darin enthalten.
Ferner wird diese ROM nun in unserer Index Liste gelistet.
Reaktionen: redbull1
Hatte sie kurz drauf, alles lief soweit fehlerfrei. Ota blieb nach dem fix auch ruhig.
Aber ich muss ganz klar sagen, dass für mich im Moment die hawkish v2 mit Abstand am besten funktioniert. Wanam und xblast sind da neben einigen anderen Features direkt im Einstellungsmenü integriert.
Aber wie gesagt die tigra ist auch nicht schlecht.
VG
Hallo habe gerade das Rom wie beschrieben geflasht.
habe nur kleine Probleme:
1. Das Dislplay (Handy oberseite) wir d serh warm nach dem flashen.
2. Der Root ist weg.
SU zeigt ne fehler meldung das manuell gerootet werden soll.
kann mir jemand behilflich sein?
kann es sein das ich von Version 4.2.x nach 4.3 gewechselt bin?
Ebenso will das Rom immer ein Update von V2.2 auf Version 2.1 runterladen
danke
Zu 2.: SuperSu per Recovery flashen, steht glaube ich im Opener.
Zu Update, lies #3, gleich weiter oben!
trotz dem update-fix will er updaten.
hab sie per ES explorer manuell verschoben und die rechte angepasst und per cwm geflasht.
ergebnis bleibt gleich.
man kann aber im ota updater die benachrichtigung ausschalten wenns doch nervt.
*18.10.2013* [4.3] Tigra_Rom Updated
Post 1 angepasst!
*22.10.2013* [4.3] Tigra_Rom Updated
Post 1 angepasst!
Fazit nach 5 Tagen :Rom läuft super ,Akku ist auch super, etwas besser wie bei Wanam.
Ota Updates gab es 2 .Aktuell ist jetzt Version 2.4.3.
kann sein das ich es nicht sehe aber er will beim 2.4 download ein passwort? kann mir jemand helfen? würde die rom gerne mal testen..
Update 2.4.4 auf XXUEMJ2 über Ota ist da.
Ich habe die Rom jetzt auch auf meinem Galaxy Note 2. Es funktioniert auch soweit alles super das einzige was mir auffällt ist das das Handy vorne an der oberen Hälfte des Displays etwas warm wird. Zwar lange nicht so warm wie wenn ich eine Zeit lang intensiv etwas aufwändiges gespielt habe, aber halt auffällig warm. Kennt noch jemand das Problem und kann mir jemand sagen ob ich mir da Sorgen machen sollte?
Also meins ist kalt .
Hab gerade wieder ein Update über OTA erhalten.
Bisher alles super.
*31.10.2013* [4.3] Tigra ROM Updated
Post 1 angepasst!
So hab es auch drauf und bin fürs erste zufrieden.
Besten Dank an alle.
Gruß geier1
Hallo zusammen, ich habe die V3 ROM geflasht so weit so gut.
Nun habe ich keinen vollen Root Zugriff mehr. super SU jagt mir es währe keine su Datei installiert.
Kann mir Jemand weiterhelfen.
Gruß: geier1
