Cpt. Future
Gast
[ROM][4.3]MK4|CRISKELO-Rom NOTE II V22|NOTE 3 MOD v2 Aroma Universal Theme OK - Super Fast
READ THIS TUTORIAL TO THE END! We will avoid ISSUES AND CONCERNS INSTALLATION!
Thank you for your patience, thank you for your faithfulness, hugely JB working on this, we are very happy to offer you today!
Our Rom is based on stock rom with mods added, and a and AROMA Installer.
The installation will be easy for everyone, whether you come from a stock rom or other rom, we will see all this in detail
ROM V22
-Fix txt in TW launcher 4x5 and 4x4 ok
-New AROMA Installer Fix no more problems (lot of work but very solid now)
-data/data :Flash player, Xposed installer, Xposed Wanam and Penwindowmanager
-And many other minor improvements
-Delete Roletube
-Add OGYoutube Download Video ok
-Fix error in Note 3 Mod ( FlashAnnotate.apk Fc ) ADD system/VODB/mul from Note 3 system
-Add MMS.apk Note 3 ( ok funtions Air view)
-Add Contact.apk Note 3 ( ok funtions Air view)
Note 3 Mod Project V2.0 thanks tamirda, dr.ketan and Team
New in V2.0:
- New Note 3 Settings with Search Options and more! (Do not ask why touch with gloves doesn't work or other note 3 stuff - the answer is simple, you don't have Note 3 HW)
- New Note 3 Multiwindow with amazing features:
- Quad screen: you can split multiwindow up to 4 different apps!
- Floating windows: Like Pen Window, just with the finger(One click on the app in multiwindow will open it as floating window)
- Abillity to open same app from this list(If you need any more app please make a list so I can add in the next release) :
Code:
com.sec.chaton com.sec.android.app.myfiles com.google.android.talk com.google.android.youtube com.infraware.polarisviewer4 com.infraware.polarisoffice4 com.whatsapp com.kakao.talk com.sec.android.app.sbrowser com.android.email com.android.mms com.android.chrome com.facebook.katana com.google.android.gm com.google.android.videos com.twitter.android com.quoord.tapatalkpro.activity com.sec.android.app.videoplayer com.estrongs.android.pop - New black themed Note 3 Keyboard with the following fixes(Thank you dr.ketan!) :
- No more big smilies!!!
- No more missing icons!! - New Note 3 Signature Lock! Oh I love it!
- New Lockscreen effect - Watercolor effect! Now you have 3 options:
- Watercolor Effect
- Ripple Effect
- Flare Effect - New Note 3 Story Album app + widget
- New Smart Scroll & Smart Pause Options!
- New Quick Glance option (In order to use it you must activate Air Gesture, Motions and Palm Motions)
- New SPen Features(In order to understand better go into Settins -> Air Command and use tutorials there) :
- Air Click on a picture in gallry will open new Air Menu
- Air Click on Attact/Contact in SMS will open new Air Menu
Fixed: - Fixed Camera/Favorite apps in Lockscreen
- FIxed SNS FC
- Fixed App FC when using Emojis in keyboard
Note 3 Launcher Fix Criskelo
Note 3 Multiwindow
Note 3 Fully Working Aircommand
Note 3 One Handed Option Fot all screens
Note 3 Keyboard + AndroidEmoji.ttf- Thanks avivalder
Note 3 SNote
Note 3 My Files
Note 3 Contacts and Phone (with option for popup incoming notifications)
Note 3 Browser
Note 3 S Planner
Note 3 S Finder, Pen Window, Scrapbooker
Note 3 Apps like SketchBook, Evernote and more
Note 3 Gallery
Note 3 Writing Buddy
Note 3 My Magazine
SPlanner App Widget
No more sporadic FC.s
And much more!
Now in AROMA
Selector
>Install ROM NOTE 2 Stock
>Install ROM NOTE 3 MOD
AROMA
>Items, remove or add apk Group (This checkbox allows to remove groups of applications and reinstall)
-Install ROM BASE
-All share app and service
-Dropbox app and service
-Samsung KNOX
-Samsung App store
-MobilePrint service
-Samsung Voice talk
-Yahoo stock and news
-Samsung Widgets
-Install LiveWallPapers
Selectors
>Kernels
>Recovery
- Touch Recovery
- Touch Recovery TWRP
>Modem
-XXEMI6
- XXEMJ2
- XXEMJ5
- DDEMJ9
>Launchers
-TW Launcher 4x5 5x5 Stock
-TW Launcher 4x5 5x5 MOD
How to install:
Download and install Xposed framework from here. then REBOOT your device
Download Wanam Xposed from the PlayStore (or attached file)
Activate Wanam Xposed from the Xposed Installer then REBOOT your device
Enjoy!
This rom will be installed by recovery mode, your device need Clock work mode recovery before installing.
Firstly, always make an android backup before flashing any rom
Reboot into recovery, select option "backup and restore" and choose "backup", the backup will be in your sd card / clock work mode folder.
How to install this CriskeloRom ?
IF YOU COME FROM CriskeloRoma, NO NEED TO WIPE, BUT IF YOU COME FROM ICS ROM OR OTHER CUSTOM ROM : WIPE DATA FACTORY RESET IS NEEDED BEFORE INSTALLING THE FULL ROM
- Make a Nandroid backup of your current rom (mode recovery/backup and restore/backup)
- Save your user apks with Titanium backup or other (don't save system apks)
- Put the zip downloded (CriskeloRom) on your intern SD card
- Go to recovery mode and : WIPE DATA FACTORY RESET + WIPE CACHE PARTITION + IN ADVANCED/WIPE DALVIK CACHE
Your phone is now clean, you can flash the Rom CRISKELOROM :
- Install zip from sd card
- Choose zip from Intern SD card
- Go on CriskeloRom, select " Yes "
ROM INSTALLING IT WILL TAKE SOME TIME...
- When you see : install rom complete : press go back, and press reboot system now :
You are on Jelly Bean Criskelo Rom
Downloads CriskeloRom Note II V22 - MK4 Android 4.3
LINK (Dev-host):
CriskeloRom-NoteII-V22-MK4-4.3-MD5-92A0A664EC1BC1867AF69D577B63C1A1.zip
Mirror 2 TeraFile
Mirror 3 pCloud
CriskeloRom-NoteII-V22-MK4-4.367AF69D577B63C1A1.zip
Mirror 3 Mediafire
To all of you, for your confidence
@Crash 1976
@Chainfire, @Wanam, @Vertumus, @OlliG, @ Team
If you like this rom, supports our site with your registration
