DirtyKlot
Ehrenmitglied
- 3.907
[ROM] DroidTurK v4.0 DroidTurk ROM for Galaxy Note 2! - YouTube
Was ist anders an dieser ROM?
DroidTurK wurde in 2 Versionen erstellt. Eine ist für Stock Recovery Nutzer, die andere für Custom Recovery Nutzer. V1 kann über Odin geflashed werden, eure Recovery bleibt dabei unberührt und ihr könnt noch OTA Updates nutzen. V2 und höher sind für Custom Recoveries gedacht. Ab V4 könnt ihr zwischen DPI Werten wechseln um euren ROM anzupassen.
Probiert es aus!!
Changelog V4:
● Custom Recovery Flashable
● MULTI DPI ROM
● Mutli Dpi Launcher (thanks to grilleld)
● Lockscreen Fixed to all dpi mods (except phone)
● battery icons added
● Flashbar / Multiwindow is been modified to fit in all dpi mods.
● Settings updated
● DroidTurK ROM Addons
● xperiaZ lockscreen toggle has been made but not working yet
● 23 toggle has been updated , looks much better now !
● Clear all button has been added to expanded status
● music control has been moved droidturk settings
● notification has been moved to droidturk settings
● Launcher is been modified / rotate
● Ripple Effect has been fixed !!! (took a while , srry guys)
● Aosp vibrate has been fixed (doest work on all dpi mods)
● keyboard icon (IME) has been fixed
● Flash, reboot or recovery selecting @ 23 toggle has been fixed !!
● and some little fixes in system
● uiswitcher added
● MULTI DPI ROM
● Settings updated
● uiswitcher added
ROM Details:
● DroidTurK ROM is based on Lastest European Stock "XXDME6" and is a .tar file. the reason I've made tar file is that no matter what kinda recovery one uses he can flash this rom true ODIN.
● Stock Kernel XXDMC3 (I hope this will fix the IMEI problems)
● Stock DME6 Modem
● Removed Recovery (so users own recovery will not be overwritten)
● Removed some Bloatware (if u want u can flash or move afterwards.. ask me the apks if u can't find)
● Fully Deodexed
● Zipaligned
● Busybox added
● Root su added
● ROM is a Non-Wipe
● Sony Bravia engine v3
● Xperia launcher comes preinstalled. User can select TW or Xperia
● S4 like Statusbar/White icons
● S4/tablet like white SecSettings, MyFiles, Email
● S4 Multiwindow + Semi-Transparant + All apps Supported (no need for 3rd application)
● Some system app icons updated to 4.2.2 (S4)
● Clock Mod
Remove time
Center the clock in statusbar
move the clock to stock location
remove clock from statusbar
remove am/pm
change am/pm to small size
change am/pm to large size
add abbreviated day of week to status bar small size
add abbreviated day of week to status bar large size
remove abbreviated day of week from the status bar
Select clock color
●User Selectable Statusbar Transparancy AND color
● CRT Off Effect With Toggle (On/off) [Will also work on stock kernel but only when wifi is on.. so for a perfect working CRT install a custom kernel]
● User Selectable long press BACK or HOME kill
● Quick unlock on correct password/pin
● Real time notification panel color+transparancy changing (no need to reboot)
● Stand alone battery bar (no extra APK's to install)
Stand Alone Battery Bar w/Options and color picker
Animated bar while charging
● select battery bar dp thickness
● 16 Real time Battery icon selections (no need to reboot)
● 1% Battery Mod
● 23 toggle mod (if you dont want it, deselect all and you will get stock toggle)
● 4 in 1 reboot menu
● changed bootanimation and sound.
● Enabled inkt effect with finger
●CodexSound
- xLoud ported for N7100
- SoundEnhancement full working From Xperia z
- Super Bass (Best feature of the mod)
- Surround Sound
- Clear Audio+ but true ported for N7100
- ClearPhase feel sounds improvement when open walkman
- Clear Bass
- Clear Stereo
- New Powerful custom compiled audio libraries
- SoX Codec for Superior Audio quality
- MP3 LAME Codec for Superior MP3 Quality
- Audio Fluence mode set to Broadside
- New Walkman From Xperia Z
- New Walkman Visualizer From Xperia Z
- TrackID From Xperia Z
- Dynamic Normalizer
- ClearPhase
● Multi lockscreen
Aosp
Blackberry10
HTC Sense 4.0
LG optimus
Acer Cloud
Galaxy note2 Ripple/Circle
● Lockscreen Torch
● Long press volume to Skip music (Music control)
choose Volume timeout
Volume up action: Next, Pause, Play, Play/Pause, Previous, Stop
Volume down action: Next, Pause, Play, Play/Pause, Previous, Stop
●Call recording Enabled. User selectable auto or not, end call delay..
●No increasing Ringtone
●Some MMS/SMS hacks
●Some Camera hacks
"Shutter Sound On/Off" option in Camera Menu:
Camera focus sound disabled
Camera Volume Up/Down and power buttons as a shutte
Camcorder Better audio quality and video bitrate:
VIDEO QUALITY:
1080p: Normal - 17MBit / Fine - 24MBit / Superfine - 30MBit
720p: Normal - 9MBit / Fine - 13MBit / Superfine - 17MBit
SOUND QUALITY:
192kbit/s, 48000 khz
Camcorder can be used with flash in low battery state
Camera can be used with flash in low battery state
●scrolling cache across OS Disabled
● Stock DME6 Modem
● Fully Deodexed
● Zipaligned
● Busybox added
● Root su added
● ROM is a Non-Wipe
● Clock Mod
Remove time
remove am/pm
Select clock color
● 1% Battery Mod
●CodexSound
- Surround Sound
- Clear Bass
- Clear Stereo
- ClearPhase
● Multi lockscreen
Aosp
Blackberry10
HTC Sense 4.0
LG optimus
Acer Cloud
● Lockscreen Torch
●Some MMS/SMS hacks
●Some Camera hacks
VIDEO QUALITY:
SOUND QUALITY:
Bitte macht vorher ein EFS Backup!!!
Wie installiert ihr DroidTurK?
V1:
Downlad and extract the zip file.
Open odin and hit pda, Select the unpacked DroidTurK.tar.md5 file and hit start.
V2 und höher:
Download the RAR file and place it on your phones SDcard, after that go to recovery and flash it.
DOWNLOADS:
V4 Torrent
Mirror V4 (Encryption key: X4SMOS8vNaG2_EV0gBZasnM_WgMltj6_pEQdFrimh6k)
Old Release: V1
Screenshots:
