[ROM][4.1.2][ME6]Assassin_v8.0|SOFTKEY ENABLED[BUILD,COOK,THEME UR ROM][22/07]
  • 71 Antworten
V4.0 ist raus...
firasusman schrieb:
V4.0 is ONLINE.
Graaaaaaaaaaaaab it.
Important Notes:
1) Make a Nandroid.
2) FULL WIPE is a must. USE TWRP Recovery.
3) Wipe cache, dalvik, system, reboot recovery, wipe cache again. CACHE must be cleaned. /cache is used for temp files during installation.
4) Flash the ROM after you make sure MD5 is correct after download.
It takes a little longer time to load because of lots of aroma pages and .prop files.
GOOD LUCK and Enjoy
Download Link
Gruß,
Mac
Reaktionen: perog
Hi Viper
Ist meine erste MC1 Rom und läuft flüssiger als die MB6 Versionen.
Das neue B&B Black&Blue Fusion v1.8 Theme ging nicht danach gibts Bootloop.
Aber so berauschend ist das Theme auch wieder nicht.
Die Themes vom BoBCaTRom funzen dafür bestens.
LG Robby
Reaktionen: bahrosuz und perog
Update ist auf dem Weg:)
we are soon finalizing the new version of assassin ROM..
all what i can say about it , its
a complete AROMA for (EVERYTHING) .
LG
Reaktionen: VtecMac und Robby57
V 6.0 online Goo.im Downloads - Downloading Assassin_V6.0_XXDME1_MD5_2EF279E7BB374A2D0571F6AC57EB642E.zip
Assassin Resurrection V6.0 CHANGE-LOG
Full Wipe is a must
Assassin is one-stop shop ROM
Based on the latest base XXDME1
Fixed sound recorder in video camera
Added mod to enable / disable softkeys (Aroma - Reserved)
Added Transparent Multiwindow mod (Aroma)
Added Transparent Status Bar mods (50,100) for Non-Simplistic (Aroma)
Added Aroma page for inverted apps (20 Google Play, 1 AOSP messaging with popup window)
Updated recovery twrp 2.5.0.1 (Aroma)
Updated recovery philz 5.00.5 (Aroma)
Added kernel XXDMD2 (Aroma)
Added kernel XXDME1 (Aroma)
Updated kernel Abyss 2.5 (Aroma)
Added kernel TerraBuzz_PR24 (Aroma)
Added kernel Devil-n7100-COMBO-0.18.1_20130428 (Aroma)
Updated kernel N.E.A.K. 1.9x (Aroma)
Updated kernel Perseus-alpha36.3 (Aroma)
Updated kernel Adam 2.4 (Aroma)
Updated kernel RedPill 1.47 (Aroma)
Updated emwnos 4.0 (Aroma)
Updated Toiiki 6.5 (Aroma)
All the goodies from previous release still apply
Do NOT forget the fact that this ROM can be as light as a leather or as full as complete stock depending on your choices in Aroma.
Reaktionen: VtecMac und perog
Download läuft ! Aber ungewohnt lahm, eventuell ist dort etwas überlastet... Download soll in 14h fertig sein :D
Fred mein Freund, danke fürs aktualisieren!:thumbup:
Gruss
Habe nur ich das Problem mit dem Download ? Ich kann die nicht ziehen :/
Bin gerade am Downloaden. Läuft bis jetzt. 15% habe ich und noch ca. 25 Min. verbleiben. Schaut gut aus.
LG
Moin
Hier ein FTP Mirror für die v6.0
Bitte vergleicht die checksum da ich es direkt auf den Server gezogen habe.
Original MD5: 2EF279E7BB374A2D0571F6AC57EB642E
Reaktionen: VtecMac, Cpt. Future, DickenAc und eine weitere Person
Jetzt steht bei mir endlich auch mal was von 10mins bei Beginn des Downloads. Sieht schon vieeel besser aus, Danke ! ;)
Fred danke für den Mirror, den ich auf die erste Seite aufgenommen habe!
Gruss
Moin
Die Links gehen alle nicht mehr auf der Startseite.
Invalid or Deleted File. Bitte mal überprüfen.
LG Robby
Reaktionen: Cpt. Future
Vielen Dank Robby,
habe nun alle Links ausgetauscht, sollte nun alles funktionieren!
Gruss
Reaktionen: perog und Robby57
Danke
Viper ich hätte den Beitrag auch selber geändert.
Wollte nur das man es besser versteht was ich meinte.
LG Robby
Vielen dank, der DEV muss irgendwie den Server geändert haben.
Gruss
Macht doch nichts.
Passt schon.
LG Robby
Assassin Resurrection V7.0:
Based on the latest base XXDME6
Full wipe is recommended in case of issues
Code clean-up
Enhanced Installer Verbosity
Bug Fixes
Major overall improvements
Tweaks for Supreme Performance and Smoothness
Tweaks for Supreme Battery Life
30 Kernel Choices (Aroma)
14 Modem Choices (Aroma)
3 Recovery Choices (Aroma)
11 Launcher Mods Choices (Aroma)
15 different Mods in Customize Aroma Page
86 GPS Mods (Aroma)
Added XXDME4 Modem (Aroma)
Removed Advanced Settings from Aroma, not applicable any more
Removed Google Play inverted apps from Aroma.
Kept only Black AOSP messaging app with popup messages features enabled from app settings.
Updated Recovery Philz 5.06.1
Updated Kernel N.E.A.K 2.0.2x (Aroma)
Updated Kernel Abyss 2.5.1 (Aroma)
Updated Kernel Adam 2.5 (Aroma)
Updated Kernel Toiiki 6.6 Linaro (Aroma)
Updated Kernel TerraBuzz_PR27 (Aroma)
Updated Kernel Devil-n7100-DUAL-0.22.1_20130612 (Aroma)
Added Kernel Saber 3.0.80 (Aroma)
Added Kernel AGNi PSN_pureSTOCK-v2.2 1.6GHz (Aroma)
Added Kernel AGNi PSN_pureSTOCK-v2.2 AutoOC 1.8GHz (Aroma)
Added TouchWiz Launcher Mod 10x6-8 dock icons without wallpaper scrolling (Aroma)
Updated Sound Mod Noozxoide_EIZO-rewire__PRO_Series_(24.03.2013) (Aroma)
CLICK_HERE
Thoddü
  • Thoddü
Lady_in_black
redbull1
bernardo65
bernardo65
Androidwizard
LtComJCFox
