[ROM][4.1.2]KingDroid Note 2 v7.2 - Simplistic Framework -Kingdroid World[13/03]
  • 41 Antworten
XtremeAt
XtremeAt
Enthusiast
657
Derzeit ist noch kein Changelog der 7.2 vorhanden. Deshalb füge ich hier an dieser Stelle den Download inkl. Mirror ein[/B(]Danke an bangsti und viper5)
Download : Mirror1 / Bangsti Mirror
MD5Hash:
b429cb812d916c96b7784aeda4e95f61
NEXT GENERATION V7.0 ROM KINGDROID
How will this type of ROM?
It is a ROM Stock Samsung MB4, with:
- Subject Stock
- NO takes the framework of implemented Simplistic Series
- Base XXDMB4
- Modem LK5
- Kernel Stock Modified By Kingdroid
- Root
- Deodexed
- Zipplaning
- Busybox
- Call Rec
- Init.d
- Improved UI speed
- Extended Menu off
- Multiwindow
- Weather Mod in lookscreen
- Improved app Contacts: Fluency and speed
- Sqlite optimiced
- Custom Settings:
- Mods and Themes Ota (Update ME)
- Stweaks for Badwolf Kernel (if not wearing Badwolf Kerel, opening the app only tell us "Sorry, unsupported kernel"!
- Cpu Spy.
- Cpu Monitor.
- CSC Selector.
- Samsung secret codes.
- Fast Dormancy.
What advantages does the Update ME?
- Push Notifications to alert users of new ROM
- Push Notifications to send messages to users
- Check when you want if new ROM
- Download all Mods directly to your phone.
- Automatic Verification MD5.
- Scripts for autoreiniciar and enter recovery.
- App that is published online: that is, able to go toe getting mods to shovel in the app without having to reinstall, flash or anything, just to close and open the app will have added anything new.
Let ME Mods Update We have in the moment?
Category: imprescidible:
- Simplistic Framework 3.5.1
Category: Mods of TW Launcher:
- 14 Mods Accuweather widget
- Coming soon, mods to change grid TW
Category: Mods General:
- Asus Weather
- Effect without S-pen ink
- Camera 4.2 nexus
- Active Button Mod for Nexus type
- Mod to deactivate such Buttons Nexus
Category: Sources:
- 15 packs with 20 each in Apk sources for you to enjoy over 300 sources in your phone
Category: Mods Simplistic:
- 3 Packs with a total of 50 for the battery to flash for recovery Simplistic
- Topics adapted for Simplistic (as explained later install)
Category: Mods Audio / Sounds:
- Mod to modify the Default_gain to 61
- AC! D Noozxoide
- Beats Audio
- Sound Pack 4.2 and Nexus notis
- Star Wars Sound Pack by Masterkira
- Medieval Sword Sound Pack by Masterkira
- Stock Sound Pack By Masterkira
Category: Customizing Keyboards / Dialers:
- No time (under construction)
Category: Subjects without Simplistic:
- Well, that, without simplistic themes
Category: Kernels:
- Collections of the last 6 Kernels for bug
Category: Modems:
- Compilation of the last 3 modems for the bug.
Simplistic I install the Framework? (REQUIRED PAYMENT APP)
- First of all we went to in UpdateME MANDATORY and down the Mod to see inside, flasheamos, install the app payment and adjustments, where we had the Custom settings, we will:
- Control MultiWindow
- Simplistic Control
- Cpu Spy.
- Cpu Monitor.
- CSC Selector.
- Fast Dormancy.
Furthermore, within UpdateME ahroa in category Simplistic Mods, can decargar topics for Simplistic.
I have no Simplistic Pay App, I can put topics?
Yes, we went to UpdateMe and within no Simplistic Themes, you can download themes No Simplistic.
The Resource Packs are compressed in a Zip, and to open all APK see, this is not flashing. Instead all mods, kernels, modems, themes are all via Recovery!
KingDroid Dark Blue Theme V7.0 (el preferido de peter)
Download via UpdateMe
175790d1362082863-rom-xxdmb4-27-02-13-kingdroid-note-2-v7-0-rom-next-generation-online-2f680530.xl.jpg
KingDroid Transparent Blue Theme V6.1:
KingDroid AOSP Theme
attachment.php
Motomoto edit by eliot v6.1:
attachment.php
Download link
Download
Weather Mods
Download
Link zum Notemania Forum (spanisch)
Link
Reaktionen: Robby57, fromfuture, capsulcom und 2 andere
V4 sollte in den nächsten Stunden online sein
gesendet von meinem Note II direkt aus dem Ghetto
V4 ist online..
Meiner Meinung nach einer der besten roms!
Läuft super
XtremeAt schrieb:
V4 ist online..
Läuft super
Und warum juckt es hier niemanden? Schon seltsam.
Gesendet von meinem GT-N7100 mit Tapatalk 2
Ja das frage ich mich auch..
Meiner meinung nach die stabilste und schnellste rom.
Gibt auch mehrere themes etc.
Die meisten nutzen wohl omega..
Ja und wo ist die nun online oder ein link ???
sorry. ging nicht eher... erster beitrag ist aktualisiert..
leider ist es ne mischung aus englisch und spanisch -.- aber sollte soweit verständlich sein
Moin ich werde Kindroid ausprobieren. Ich kenne ihn von früher und hat es verdient das man seine ROM wenigstens einmal ausprobiert! Sage mal was verbirgt sich hinter diesem download?
KingDroid Custom Settings:
http://www.wuala.com/kingdroid/GALAX..._Settings.zip/
Gruss
Ich flashe gleich dann kann ich eventuell vor XtremeAt etwas dazu sagen :)
Full wipe gemacht!
Ui, erstes update ging daneben! Beim einrichten FC ein einrichten nicht möglich! Werde erneut flashen... update folgt!
2. Versuch hat funktioniert :) jetzt mal in Ruhe einrichten!
Gruss
Ich habe die custom settings zwar nicht geflasht aber ich denke es handelt sich zb. um die funktion csc in den einstellungen zu ändern etc
Gibt leider keinerlei Screenshots oder Erklärungen zu den dateien :/
Edit: ja hatte recht.. das sind die Einstellungen wie man sie beim note1 bei chrack zb hatte.. (fast dormancy, cpu spy, csc selector etc. direkt in den einstellungen)
Reaktionen: perog und Cpt. Future
Also wer hätte es gedacht... Bin sehr sehr positiv überrascht. KingDroid bleibt erstmal drauf. :thumbup:
Reaktionen: perog und XtremeAt
KingDroid bleibt beim mir auch drauf.
Moin moin, erstes Feedback...
Also die ROM ist echt gut. Habe den KERNEL PAK AROMA 4 von CRASH mit installiert.
Davon DLK7 als MODEM und die Perseus als KERNEL genutzt.
Ferner mir gestern für einen kleinen obulus SIMPLISTIC APK besorgt nun schnurrt die Katze brav.
Als THEMES kam für mich die DARK BLUE in Frage.
Man kann HIER ANIMATIONEN und HIER FONTS runterladen. Die Fonts sind als apk zu installieren und die ANIMATIONEN unter CWM.
Meine lieblingsfont habe ich angehängt:smile:
So sieht es aus wenn man die... flasht!
KingDroid Transparent Blue Theme:
http://www.wuala.com/kingdroid/GALAX...oid-Theme.zip/
QUELLE: HIER
Viel Spass beim ausprobieren!
  • Armonia[1].apk
Reaktionen: Nightwing82 und XtremeAt
Wie kann ich Live-Wallpaper nutzen ???
werde es auch nachher mal testen bin im mom. noch am GOA hängen geblieben
viper5 schrieb:
Moin ich denke in der jetzigen Situation gar nicht. Den Sie sind diese gar nicht in der ROM enthalten. diese musst Du nachinstallieren zu finden HIER!
Apps Eliminadas v4.0:
http://www.wuala.com/kingdroid/GALAX..._apps_MLA.zip/
Gruss
Hätte ich ja auch mal selbst drauf kommen können :razz:
Vielen Dank !:thumbup:
Der ursprüngliche Beitrag von 06:19 Uhr wurde um 07:14 Uhr ergänzt:
Shit !!! Hab die removed apps installiert und jetzt laggt das Teil !! Kann man das irgendwie wieder rückgängig machen ??? Nein ich habe kein Backup vorher gemacht.
Moin, was genau lagt und was meinst du mit lagt? Hast du nach dem booten einen erneuten Neustart versucht? Wenn es danach immernoch lagt wirst Du wohl die ROM Neuflashen müssen.
Gruss
Der ursprüngliche Beitrag von 11:20 Uhr wurde um 11:26 Uhr ergänzt:
Danke läuft prima nach Neustart.
