[ROM][4.1.2]EmotionMIUI V2.6 - Clean and Fast[Aroma][multilanguge][10/07]
  • 148 Antworten
smooth 123
Gast
EmotionMIUI Note II V2.6 GT-N7100
Changelog V2.6
Based on MIUI 3.7.5 from MIUI
Thanks to Trunk for his translation in spanish
Multilanguage packeg 3.7.5 adapted to 240 dpi, center clock,etc.
Added modem XXDME4 (highly recommended) and XXDMF1
MIUI Browser works well, no more FC
Enable GPU rendering for 2D operations thanks to mike1986
Added all improvent of v2.5
Fixed other little bugs
TODO:
Multidpi
Crt-off Animation
Disable exchange security
Improve miui launcher
and more..
Changelog V2.5
Based on MIUI 3.6.21
Changelog - MIUI ROM 3.6.21 Changelog | MIUI Android - Redefining Android
Multilanguage packeg 3.6.21
Added last stock kernel
Enable crt-off animation
Fixed 3-way boot menu
Fixed stweaks
Fixed dialer on 240dpi
Added small gapps
Added MiHome 2.5.1-0625-alpha
Added all improvent of v2.4
Ältere Changlogs
Changelog V2.4
Based on MIUI 3.6.14 Changelog - MIUI ROM 3.6.14 Changelog | MIUI Android - Redefining Android
Multilanguage packeg 3.6.14
Fixed Media Scanner (wakelock)
Added script to kill some processes
Added new settings
You can change lcd density from settings (thanks to xperiacle for his apk ui switcher)
All apks support multidpi (if you use the Samsung keyboard you will have to flash samsung keyboard 240dpi)
Fixed dialpad for 240dpi
Added Multidpi Play Store
Added more apks (cusettings, youtube,etc.)
Added all improvements from the previous version
And other little things that I don't remember
Changelog V2.3
Based on MIUI 3.5.24 Changelog - MIUI ROM 3.5.24 Changelog | MIUI Android - Redefining Android
Multilanguage pacheg 3.5.24 (Fixed in Aroma Installer)
Added Bravia Engine
3-way reboot menu
TODO: Multidpi
and more..
Changelog V2.2​
Based on MIUI 3.5.10 Changelog - MIUI ROM 3.5.10 Changelog | MIUI Android - Redefining Android
Multilanguage packeg 3.5.10 (In Aroma Installer)
Last Stock Kernel (Optional in Aroma)
Added Nadia Kernel V1.0 (Optional in Aroma)
Added Modem DXDLK5
Center Clock on status bar
modified multiwindows
Increase overal touch responsiveness
Made streaming videos faster
Increased quality of JPEG images
Changelog V2.1
Based on MIUI 3.4.26
Last Stock Kernel
Multilanguage packeg 3.4.26 (In Aroma Installer)
Added Spen Helper
Added several tweaks to improve fluency
Changelog V2.0
Based on MIUI 3.4.12
Last Stock Kernel XXDMC3
Init.d
Removed some applications
Improved signal and 3g
Improved GPS
Added Last Play Store, and Gmail
Improved speed of MIUI Launcher
Added new sounds
Increased volume of the speaker and headphones
speed of SD "1024"
Improved speed of all
RAM improved
Zipalign in realtime
New Theme by Ivanebdesign (Second Post)
Changelog V1.2 Control app extended (Center clock, etc.)
Added GAPPS
Added Multilanguage
MIUI Equalizer
Spen Helper
Modem XXDLK7 or DDDLK6
Efs backup
Flash player
Apps stock Samsung and others
Fixed Ui settings (Second post)
Changelog V1.1 Fix SU permissions
Added Emotion Wallpaper apk
Changelog V1.0
Based on MIUI V4 FINAL
Last stock kernel 4.1.2
Root
Deoxed
Zipalling
Init.d
Lite
Last compilation LORDSTENKA (Thanks)
Includes programs of MIUI
Multi langueges (Spanish too)
Improved translations
4 way boot menu
Multiwindows with all apps
All functions of Spen
Added Tweaks to improve performance
Improved GPS
Blue theme by Jcanonico (Second post)
Bootanimation By Ivaneb-design
Stock aplications of Samsung (Second post) (Thanks DeadSix17)
Stable, fluid and clean
Added new sounds
And little things that I don't remember
About AROMA INSTALLER
1. Full wipe / No full wipe
2. Efs backup / No efs backup
3. Tweaks and mods
4. Stock apps of Samsung and others apps
Kernel
1.The rom is with stock kernel
2.We have tried almost of kernels and Perseus goes very well
NOTES:
1. Default Sprachen English oder Spanish, im Aroma "multi-language"
auswählen um es zu installieren!
2. Wenn ihr nur play store und gmail benötigt keine GAPPS instalieren. Play store und Gmail are included in the rom.
3. Um den Launcher smoother zu machen go to : Settings/ Developer Options/ and change Animation scale .5x of "Windows animation scale, Transition animation scale and Animator duration scale"
How to install?
Full wipes
Format system
Install zip and restart
Kommt Ihr von einer MIUI V5 reicht cache and dalvik cache!
Note: Es wird empfohlen die interne SD zu formatieren um eine bessere Performance zu erreichen!!
Notes for EmotionMIUI V2.1 (Thanks to Intergalacdroid):
There is a form of multitasking on this ROM...go to:
Settings > Buttons & Keys > Home Key > select "Launch Recent Panel"
Or
If you are using something like Nova Launcher (as I am)...you can map the "recent apps" function to a gesture.
Download:
Emotion Miui V2.6 Aroma
http://click.xda-developers.com/api...roma English&jsonp=vglnk_jsonp_13735401835469
Multilanguage Miui 3.7.5
http://click.xda-developers.com/api... MIUI 3.7.5&jsonp=vglnk_jsonp_137354032329210
Emotion MIUI V2.5 Aroma English
http://www.mediafire.com/download/m1gc95qn52oz9jj/EmotionMIUI-V2.5-AromaEN-3.6.21.zip"
Emotion MIUI V2.4 Aroma English
http://www.mediafire.com/download/ele1sbh0tw5jk3r/EmotionMIUI-V2.4-AromaEN-3.6.14.zip"
Samsung Tastatur 240 DPI
http://www.mediafire.com/download/c85r8tsq1m6ht74/Samsung_Keyboard_240dpi.zip
Samsung Uhr 240 DPI
http://www.mediafire.com/download/780xrves8h4fxt8/Samsung_Clock_240dpi.zip
Samsung Tastatur 320 DPI
http://www.mediafire.com/download/amtpdov2nlbjm2u/Samsung_keyboard_320dpi.zip
Samsung Uhr 240 DPI
http://www.mediafire.com/download/g3gv290fwo3qqfc/Samsung_Clock_320dpi.zip
Emotion MIUI V2.3 Aroma English
http://www.mediafire.com/download/6ppzztw9zzwwlgu/EmotionMIUI-V2.3-AromaEN-3.5.24.zip
Emotion MIUI V2.3 Aroma Spanisch
[ROM] EmotionMIUI Note II V2.3 [Aroma Installer] [Basada en MIUI V5] [Estable, fluida , limpia] [30-05-13] EmoTroid Team HTCSPAIN
EmotionMIUI V2.2 Aroma English
http://193.77.138.197/phone/index.p...fcholini?download=38:emotionmiui-v2-2-english
EmotionMIUI V2.2 Aroma English (Mirror by Xaoc747)
EmotionMIUI-V2.2-AromaEN-3.5.10.zip
EmotionMIUI V2.2 Aroma Spanish
[ROM] EmotionMIUI Note II V2.2 [Aroma Installer] [Basada en MIUI V5] [Estable, fluida , limpia] [14-05-13] EmoTroid Team HTCSPAIN
Old Versions:
EmotionMIUI V2.1 Aroma English
http://goo.gl/KQQuE
EmotionMIUI V2.1 Aroma English (Mediafire)
MediaFire - Online Space for your documents, photos, videos, and music.
EmotionMIUI V2.0 Aroma English
EmotionMIUI V1.2 Aroma English Mirror (cjhmdm)
Dev-Host - - The Ultimate Free File Hosting / File Sharing Service
http://goo.gl/IaPb5
EmotionMIUI V1.1 (Thanks Bangsti)
http://goo.gl/JS0g2
EmotionMIUI V1.1(thanks to bangsti Dev-host)
Dev-Host - EmotionMIUI-v1.1-Emotroid.zip - The Ultimate Free File Hosting / File Sharing Service
EmotionMIUI Note II V1.1Mirror
http://goo.gl/Vz7tc
EmotionMIUI Note II V1.0
http://goo.gl/khLRe
Please, we need comments to improve future versions
THANKS TO:
Acura
Franlov
People who donated:
- Rimgoru
- Hanss
- keenan316
- lucian1
Spende an den Developer
https://www.paypal.com/es/cgi-bin/w...3663d3faee8d96fc0752e9614158f04872d2f2ae25dc/
Quelle
[ROM] |14 May| EmotionMIUI Note II V2.2 |MIUI V5| |Aroma| |Clean and Fast| Emotroid - xda-developers
Reaktionen: simonwest
Vielen Dank für diesen Thread, ich hatte es kurz ausprobiert. Musste aber erkennen MIUI ist nicht meine Welt. Aber es ist schön umgesetzt, die Farben gefielen mir definitiv gut.
Gruss
Leider beide Links down (zu viel Traffic)...
Richtig Rom ist nicht downloadbar.
Gruß Robby
ist in Arbeit.... son wie ich das gerade auf XDA gelesen habe
gibt wohl Probleme mit dem Server oder in der Art
Reaktionen: Robby57
Viper, du hast nicht zufällig eine schnelle Leitung und könntest die Rom hochladen? Bei xda scheint es noch zu dauern mit dem Mirror...
Bitte sehr. Ist leider nur ein DEV-Host Mirror.
Nicht mit TWRP flashen da es da Probleme gibt. Am besten mit einen CWM Recovery.
Reaktionen: Korra<3, Nasenspray-Junkie und Pio
Habe es genau 30 Minuten getestet das hat schon gereicht.
Erstens wiedermal nicht alles auf deutsch. Zweitens lassen sich
keine Themes downloaden und sehr viele kosten Geld. Das war früher
nicht so bei Miui. Stocktheme sieht noch schlechter aus als ein iphone.
Kann die Miui leider nicht empfehlen so wie sie momentan angeboten wird.
LG Robby
Ich finde sie okay! Is noch nicht alles super aber funktionieren tuts, und robby du bist ein alter miesepeter in deinem Feldzug gegen miui. Übrigens Themen runterladen geht sehr wohl! Übrigens, robby, di würdest die Rom auch nicht empfehlen wäre sie gut ;-)
Peace n Love
Ist so nicht richtig denn habe schon Miui auf dem HD2 gehabt und fand sie super.
Und dann erzähl mir mal was du an Themes laden konntest. Egal was ich anwählte und auf Download
drückte tat sich nichts. Bis auf Hintergrundbilder und ein paar wenige aus dem Mix Bereich aber keine komplette Theme. Nur soviel dazu.
Tja konnte ich nicht wissen, aber freut mich zu hören,hatte auch damals auf dem s2 mein erstes miui, ändert meinen Eindruck zumindest :) ich nahm mein anscheinend spezielles Note 2,ging auf themes->online u d habe mir dort diverse Themen heruntergeladen,nachdem ich mich bei meinem xiomi Konto angemeldet habe. Um aber ehrlich zu sein habe ich die diversen heruntergeladenen themes gemischt. Somit kann ich nicht bejahen oder verneinen was das komplette aufspielen eines themes betrifft.
Peace n love
Reaktionen: Robby57
Changelog V1.2
Added GAPPS
Added Multilanguage
MIUI Equalizer
Spen Helper
Efs backup
Flash player
Download
EmotionMIUI V1.2 Aroma Spanish
Post 1 angepasst​
Also diese halb Englisch halb Deutsche ist nicht meins, auch dass mit den Themes ist nicht so fein, nicht mein Ding!
Gibt nun MIUI v5 fürs note in deutsch
Werde mal testen, fand MIUI früher sehr geil
Gesendet von meinem GT-N7100 mit Tapatalk 2
Wäre nett wenn du auch den Startpost inc. Download Link für die
User anpasst. Dafür gibt es das Forum.
LG Robby
So Post 1 angepasst,und mal nen link zur deutschen Miui fürs NoteII ist dann aber Stock
Wie ist die rom akkufreundlich und schnell?
Hätte auch mal ne Frage zu der Rom, falls die schon jemand drauf hat und zwar hat die Rom nen DPI changer? bzw. ist da was geändert?
Gruß t0bi
So habe sie mal drauf gehabt, leider kein Deutsch und unterscheiden tut sie sich nicht großartig zur deutschen Version vom MiUI
Diese hatte ich am We mal drauf, Problem an dieser ist man kann zwar die DPI mit ROM toolbox lite ändern, aber dann passen die Themen leider nicht mehr wirklich.
Ich habe Miui auf meinem HTC Sensation gehabt und wollte nix mehr anders drauf haben. Und nun gibt es ja Miui V5 und das ist ein gewaltiger schritt
mir passt das eben mit der DPI nicht sonst wäre es wieder aufm Note
Hier mal nen Bild von der v5
hatte neue Icons bekommen
und mal nen Video
Miui V5
