perog
Stamm-User
- 704
WICHTIG:
WICHTIGER HINWEIS:
Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg oder die Haftung für jegliche Beschädigungen an eurem Note 2.
Wenn ihr nicht sicher seid, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Daher flashen auf eigene Gefahr.
Novum_Initium_AmnoSferumRom_1.0.0_N7100XXDMG1&Thematizador Pack
DONLOAD THE NEW VERSION
Download Novum_Initium_AmnoSferumRom_1.0.0_N7100XXDMG1
Unfortunateley i forgot to include in the last release my wallpapers
you will have to flash this zip
Download AmnoSferum Wallpapers
Theme pack for
ROM Novum_Initium_AmnoSferumRom_1.0.0_N7100XXDMG1
3 Battery Icons
4Dial Pads
3-Animated Skins for the System
4-Statics Skins for the System
3-Animated Skins for the pull down status bar
4-Static Skins for the pull down status bar
In order to make a clean instalation before to flash the Thematizator pack you shall be surre about the type of rom that you have installed in your phone.
The first option in Aroma installer from the Thematizador Pack will give you the option to choose between Wannam 23 Toogles or Simplistic Framewok
4Dial Pads
WARNING
Youn can´t Flash Wanam 23 Toogles over Simplistic Framework
If you running in your phone Wanam 23 toogles then pick the same option for the thematizador pack
If you running in your phone Simplistic Framework 25 toogles then pick the same option for the Thematizador Pack
CREDITS and Thanks
The biggest thanks and credit go to Xperiacle
Got a lot of help from my friend ffalete
Winterlove
Mythtrandyr
Wanam
Criskelo
RocketSauce83
Kashortiexda
Dougi
NittenE39
rovo89
iBotPeaches
dsixda
Winterlove
Mythtrandyr
Wanam
Criskelo
RocketSauce83
Kashortiexda
Dougi
NittenE39
rovo89
iBotPeaches
dsixda
Novum _Initium_AmnoSferumRom_v.1.0.0_&XperiaclizatorMod_ XXDMG1
8D097701C580FDFA8BFC9CFFB32033E9
Based on the XXXDMG1 firmware of Samsung
Reworked all my sources
Reorked part of the Frameworks
More smoothness
Better battery life
Aded my tweaks
Aded new layuouts in status bar for a quick acces with scroll on horizontal
Eliminated scrolling cache
Reworked all the structure of the Rom
Rewrite part of my scripts
New zip format and new Updater Script
Coming soon additional zip for Theming
Included Floating Multiwindos in Simplistic Framework 3.6
Unfortunately I cannot test the Simplistic Framework 3.6 because I don´t have the SC.apk
Implemented the Latest Floating Multiwindows work of Xperiacle
Deodexed & Rooted & Zipaligned & Busybox Added
BusyBox run-parts support init.d scripts
4 Way Reboot Menu
Unlimited SMS recipient list
Unlimited Contacts
Large APNs List Imported from CM
No incremental Ringtone
Shutter Sound Menu Enabled to Camera
Enabled Sub Symbols on Samsung Keyboard
Desktop Browser added as an Option
Confirmation hen Exit From Browser
Skip Music Tracks from Volume Button by Long Press
Eliminated OTA Updates from Settings
Extended Multi Languages suport (also for for Samsung Keyboard-Thanks to Wanam
Automatic Call Recording- Thanks to Mythtrandyr
InkEffect Lockscreen - Thanks to Criskelo
Big weather display on note 2 lockscreen - Thanks to NittenE39
Screen Off Animation (CTR-OFF)- Thanks to Dougi
Transparent Pack Of Wigets- Thanks to Kashortiexda
Eliminate Screen Wake Lag- Thanks to Mikeyxda
Customizable 23 Statusbar Toggles - Thanks to Wanam
S4 Multiwindows FlashBar with Custom Text Colors - Thanks to Winterlove
Xposed Framework - Thanks to rovo89
Updated all the apps
Updated all the Libraries
More smoothness
Better battery life
Aded my tweaks
4 Way Reboot Menu
Unlimited Contacts
How to change between floating multiwindows and the dual mode
Aroma Features
Widgets
-Samsung Stock Widgets
-Transparent Pack of Widgets
System
-Stock Samsung Toogles with Floating Multiwindos
-Wanam 23 Toogles with Floating Multiwindows
-Simplistic Framework NoFloating Multiwindos
Kernels
Stock Samsung kernel
Perseus-alpha36.3 kernel
RedPill_Rev1.47 kernel
N.E.A.K-Note.v2.0.2 kernel
Adam.Kernel.V2.7
Battery Themer
4 styles of battery icons (not works with Simplistic Framework)
Dial Pad Style Themer
4 styles of Dial Pads
System Background Texture Style
4 Styles of Backgrounds
PullDown Status Bar Background Texture
Status Bar Transparency
AmnoSferum themed Status Bar Style
25% of transparency
50% of transparency
75% of transparency
90% of transparency
100% of transparency
Status Bar Ckock & Icon Colors
Various ways to choose the colors of the status bar icons
Various ways to choose the place and color of Clock
Windows and System Animation
Stock Windows Animation by Samsung
AmnoSpherum Windows Animation
Tweaks Installer
Various init.d Scripts
Variuos Build.prop Scripts
Simplistic Framework V3.6-Thanks to LegendK95/To make fully funcional this
You have to download the controler app from here LegendK95 Thread
TIPS
WARNING!!!!
Before anything be surre that you have a backup if not.....
Make a backup and it will be better to use TWRP
....chose all the options ticking as well the EFS to be backup and keep that TWRP folder in your PC
in this way you can recover your IMEI if someday you will need it
When you flash for the first time the ROM if it stuck when is doing the wipe or at the final when you press the FINISH button then just make a long press on the power button (around 7-9 seconds) and that will make the Phone to reboot again in Recovery menu
. Then Flash again the ROM
If you choose the clock in the middle of the status bar and you can see the clock just plug the phone on your PC or make a screenshoot after the flash.
If you choose a level of transparency on the aroma and after flash you can´t see the status bar transparent just drag pulling down the status bar
To make work this mod you have to actívate from Phone/call setting/custom settings- and -reboot
YOU HAVE TO REBOOT THE PHONE TO MAKE THIS CHANGES TO WORK PROPERTLEY !!!!
Complet_Remove_of_ALL_BlueMuppet_from_Phone_Call_C ontacts.zip
Quelle: XDA
