[4.3][N7100 MK4][1Dec]Dr.Ketan's Custom ROM V6 Deodexed|Prerooted|Note3 Fs
  • 47 Antworten
tibibi
14
Nachdem ich hier bereits angefragt habe, möchte ich euch nun Dr. Ketans 4.3er Custom ROM vorstellen. Auf anderen Webseiten erfreut sich diese ROM großer Beliebtheit, umso mehr wunderte mich, daß man die hier nicht gelistet hat.
Ich übernehme die Specs mal aus Ketans Original-Threat auf XDA:
[N7100 4.3]Dr.Ketan's Custom ROM Deodexed | Prerooted | ZipAligned | AROMA | Fully User controlled customization. V3 | Note3 Fs
ROM features V5 & V6 :
Features V5
-Based on 4.3 N7100 MK4 ROM + N900 MJ7 Deodexed, ZipAligned, PreRooted
-Inbuilt Aroma file manager in case anything go wrong while playing device with different mods, you can manage to explore device from recovery
-EFS Backup/Restore
-Recovery Flasher Philx/TWRP/Stock (optional)
-Backup of various parts of ROM like System/app and System Framework folder, before trying any MODs (Optional)
-Various kind of restore utility - As reversal from above said backup
-Coustomized Bloatware remover, select only app you don't want.(including Knox)
Integrierte features
-Pre rooted (No need to flash SuperSU zip)
-KNOX Free, Minimal debloated (still you have option to debloat more)
-Inbuilt Note3 package
  • Air command
  • PEN Window (PEN window manager is inbuilt as data app, You will lose on post flashing wipe, but you will find extra copy on your sdcard, simply install from there.)
  • Action Memo
  • Scrap booker
  • ScreenShot
  • S Finder
  • S note with attachment option like chart, map, video, YouTube,scrap book
  • S suggest
  • S finder
  • ScrapBook
  • Gallery
  • Contacts
  • Name card sending option
  • Sketch Book
  • Magazine
  • Single hand operation for all screen
  • Writing buddy
    And more !
-30 battery module inbuilt, you can change on the fly.
-Call Recording with Incoming call popup option
-MultiWindow manager
-NFC offscreen Polling
-Ad Free (Choice to remove ad free while installation)
-4 way reboot menu
-Patched with android power JAR tools
-Advanced function SecMMs
-Linux Permissive Kernel
-Init.d support
-PEN window and MultiWindow Manager
  • Group messeging
  • Schedule msg
  • Backup/Restore SMS to SD card
  • Recipient limit 999
  • Original time stamps
  • Disable SMS-MMS
  • Raise SMS/hr limit
  • Split view toggle in setting menu
  • Increased MMS max size
  • Increased size of image
-Camera Hack
  • Shutter sound on/off menu From CSC)
Optionale Features
-2G Toggle : Toggle 2G/3G with variable predefined conditions credit @TheMasterBaron
-Multifunctionl SecMMS + No log
-Internet speed meter Rt/Lt side user selectable.
- Remove ad free
-Optional CSC features with Backup/Restore option (some features not tested)
  • Enable camera during call
  • Enable Popup Notification
  • Shutter sound Menu
  • Enable Sub Menu Symbol KB
  • Raise name lenth limit
  • Max speed dial 100
  • Enable call button
  • Enable export to SD
  • Message
  • Raise recepient limit 999
  • SMS to MMS threshold 999
  • Enable folder view
  • Enable font features
  • Enable schedule msg
  • Disable phone nu formatting
  • Phonebook digit matching
  • Launcher Rotation
  • Web exit option
  • Wifi client 10 for MobAP
  • MultiWindow addOn App
  • Calender export
  • Email White BG
  • Clock enable Auto on off menu
  • Voice call waitingtone 60
  • FM local tunning
  • FM Record volume11
  • National Roaming Icon enable
  • Web default desktop site
-Optional Tweak ROM according your choice
  • 3G data speed improvement
  • Battery saving
  • Wifi connect disconnect speed
  • Deep Sleep
  • Higner image quality
  • Improve Inetrnet speed
  • Increase touch responsiveness
  • Fast Boot
  • Faster scrolling
-Push system files from SD card
-Select your own region GPS fixer
- ROM flashing is Optional, you can use this as Utility tool too.
- wanam Xposed compitible
-Some other utilities may I forget
And yes all the features you can select in one go
Changelog V6
Note 3 Accuweather Widget Also transparent option with mod selection in aroma
Note 3 Multiwindow
Floating windows
New black themed Note 3 Keyboard with the fixing emoji (Thanks and credit to @avivalder)
Note 3 Signature Lock!
Lockscreen effect - Watercolor effect/Ripple Effect/light Effect
Story Album
New Smart Scroll & Smart Pause ( pause option not working for me too)
Quick Glance (must activate Air Gesture, Motions and Palm Motions,try using help from menu inside device)
Fixed copy/share/edit option for air view
Most of reported bug Fixed
Still have issue with SNS crashing, I have gave option to use note2 gallery in mod section
Inbuilt option to install Devil kernel Thank and credit @DerTeufel1980
Inbuilt solution for Emergency only issue after flashing 4.3 (Network lost)
And huge Thanks to @tamirda for his outstanding support throughout 4.3 build ROM.
Download und Flashing Anleitung
1.Install CWM Recovery
2.Copy ROM file to SD card
3.Reboot to recovery
4.select wipe data/Factory reset
5.select wipe Data/factory reset (if you had any issue with previous Flash then select second option - clean to install a new ROM)
6.Back to menu and select Install zip
7.Select choose zip from sd card (depends on ROM file you have copied)
8.Select ROM file and proceed
Wer Probleme wg. WiFi hat (das bekannte Bootloader-Problem), muß noch den Wifi-Patch integrieren:
https://www.android-hilfe.de/forum/...oblematik-samsung-4-3er-firmwares.501351.html
Downloadlink Ketans ROM:
https://my.pcloud.com/#page=publink&code=XZ1xBZm2SBTsBJgyQyvxyGKsDG7YamIiRX
Originalbeitrag auf XDA:
[N7100 MK4][1Dec]Dr.Ketan's Custom ROM V6 Deodexed|Prerooted|Note3 Fs - xda-developers
Reaktionen: Dodge, stevebiker, perog und 5 andere
Hallo tibibi,
vielen Dank für das Herholen des ROMs in unser Forum. Dennoch möchte ich dich bitten, den Thread nach den [OFFURL]https://www.android-hilfe.de/samsung-firmware-basierende-custom-roms-fuer-samsung-galaxy-note-2/499259-richtlinien-zur-gestaltung-von-rom-threads.html[/OFFURL] zu überarbeiten.
Vielen Dank und Gruß!
mhhh, irgendwie nix neues. Auser dem Namen sind fast alle MK4 4.3er ROMs gleich. Die neuen stabilen ROMs basieren auf ML3 und ganz vorne liegt das Phoenix V16.7 mit neustem Kernel (18.Dez.13) aus ML4. Was Stabilität, Schnelligkeit, Akkuwerte und Support betrifft, derzeit das beste ROM auf diesem Planeten! Ein Blick ins XDA Forum lohnt sich! Wie heist es doch gleich ?
Vorwärts immer, Rückwärts nimmer :D
Welche rom stabil und gut läuft, liegt doch immer im Auge des Betrachter´s!
Das gleiche gilt für den Support. Also hier im Forum sind Dev´s, die auf Fragen doch sofort Support bieten und das auch noch in deutscher Sprache.:thumbsup:
Was deine Aussage zur Stabilität von rom´s betrifft, möchte ich doch anmerken, dass auch andere rom´s stabil und extrem Akkusparrend laufen.
Einziges wo ich Dir nicht wiederspreche ist vieleicht der neue Kernel und die base.:D
sry für off topic, aber das musste mal raus.
@tibbi : schöne Sache...werde ich gleich mal flashen, hast du denn auch vor den Threat in Zukunft weiter zu pflegen?
Ja, ich versuche das schon bissl zu pflegen und aktuell zu halten, zumal ich ja selbst großes Interesse daran habe :)
Den Threat räume ich noch ein wenig auf, entsprechend der Boardregeln...
ketan roms sind super, auch der dev ein sehr netter mensch.. super cool finde ich z.B seinen batterie mod :)
@tibibi
hast du zufällig ne ahnung wie ich mit der v5 nen fullcaller hinbekomme ?
mit xblast geht´s irgendwie nicht.
Fullcaller? Keinen Schimmer, was du damit genau meinst, oder ich habs noch nicht vermisst ;)
wie bekomme ich Rastergrösse eingestellt bei der DrKetan ROM?
irgendwie bekomme ich das Design gar nicht bearbeitet. vllt. stelle ich mich auch nur dumm an...
genauer gesagt nennt sich das " full screen call "
thx.
Dr. Ketans Rom ist bemerkenswert, stabil und mit den Features des Note 3 versehen. Keine unnütze und speicherintensive Apps, schnörkellos und simpel.
Leider hat Ketan sich nunmehr aus der Entwicklung zurückgezogen.
Trotzdem kann ich es aus eigener Erfahrung vorbehaltslos empfehlen. :thumbup:
Servus,
warum hat er sich von der Entwicklung des ROM's zurück gezogen?
Adé.
.... via App
@Xrunner
Er hat sein Note 2 seiner Frau geschenkt und befasst sich nun mit seinem neuen Note 3.
Reaktionen: Xrunner
Habe soeben mit dem Doc kommuniziert, der für Fragen zu seinem Rom und Support immer noch uneingeschränkt zur Verfügung steht: Eine Android 4.4.2 Version seines Roms scheint ihn doch zu reizen, vor allem in Hinblick darauf, dass Touchwiz für 4.4.2 Note 3 seit letzter Woche verfügbar ist. Man darf gespannt sein :thumbsup:
Reaktionen: Xrunner, stevebiker und tibibi
Das klingt interessant. Das Einzige was mich von der Rom bislang abgehalten hat, war, daß die Enzwicklung eingestellt ist. Vielleicht schau´ich´s mir an.
Der ursprüngliche Beitrag von 11:54 Uhr wurde um 12:03 Uhr ergänzt:
Eine Frage noch zu V6: wo finde ich die md5 Summe?
Hat sich erledigt, bei XDA gefunden.
Das Einzige (bislang), die Optionen im Rom Flasher bzw. Multitool sind ein wenig verwirrend, weil englisch und nicht Alle selbserklärend. Was soll man da Alles wählen oder nicht wählen?
Der Doc empfiehlt fürs Erste, nicht zu viele der Optionen auszuwählen, nur die, die man unbedingt haben will. Man kann verschiedene Dinge auch nach und nach ausprobieren, wie Kernelwechsel, 240 dpi usw.
Selbst wenn man die Optionen überspringt, hat man eine perfekte Oberfläche ohne Reboots oder Freezes, eine saubere Installation vorausgesetzt.
Toggles und AirCommand sind gethemed!
Reaktionen: stevebiker
Leider habe ich die meisten Optionen ausgewählt. Die Rom läuft zwar ohne Fehler, aber ist irgendwie zäher als andere 4.3er. Nicht gravierend aber doch. Und, mir fehlen einige goodies von anderen Roms, die ich fairerweise nicht nenne. Ich habe es per Backup zwar gesichert, bin aber zu meiner seit einiger Zeit super laufenden Rom zurück.
Also ich hab bei mir keine gethemten Toggles und AirCommand auch das battery Icon ist bei mir normal was muss ich dafür installieren?
Thoddü
  • Thoddü
Lady_in_black
fromfuture
Feuerstern1
Feuerstern1
Androidwizard
LtComJCFox
