Corius
Ich habe eben mein Htc Hero gerootet und mit der VillainROM 12 Series Rom bestückt. Nun steht bei der Anleitung der VillainRom Seite, dass ich nach dem aufspielen der Rom die Batterie neu kallibrieren muss.
nun, ich komme mit dieser Anleitung nicht zurecht, bzw. ist sie nicht ausführlich genug, damit ich sie verstehe
gibt es die hier im Forum oder wo anders auch auf deutsch?
danke
Every time you flash a new ROM you need to calibrate your battery. The battery meter in the OS (Android in this case) is generated based on the battery stats file.
Battery stats is erased when you flash a new ROM.
Easiest method of battery calibration when you're intending on flashing a ROM:
Ensure battery is fully charged according to the OS. Switch phone off, unplug charger and plug back in. Once light is green, leave charging for another 30 minutes (light goes green at approx 95% charge).
Switch on, flash ROM. Allow first boot to complete.
Shut phone off. Disconnect charger. Remove battery. Replace battery. Place on charge, light green, leave charging another 30 minutes, yadda yadda. Switch phone on, boot immediately to recovery. Wipe battery stats.
Boot phone up. Now would be a good time to install JuicePlotter. Use as normal. Do not charge, let the battery run down completely. When the phone shuts itself off, power it back on. Repeat process until it won't switch on anymore.
Remove the battery. Put the battery back. Turn the phone on. Repeat until it won't turn on anymore.
Now charge the battery on the mains to 100% while the phone is off, keep charging for 30 minutes after light goes green. Power on. Voila, fully calibrated battery.
The last part, run until completely dead and charge only needs to be done once in a while (this is calibrating the battery innards, not the battery stats)
danke
