installed Unslaved-Firmware lost root
  • 17 Antworten
kulrich
I rooted my g1 with RC7.
After I installed Unslaved-Firmware i lost root.
Any ideas what I can do to get them back?
k.
you dont lost root...
you have root about adb
with adb you can install superuser and you have root for your proggies.
Oh, read the fu*** manual :))
thanx
It seems i can't establish a telnet connection as root, right?
already tried command 'su' to get root-access !?
Thank you
Just a question
Is there anywhere a description (how to) to obtain superuser access?
Is it the way via : adb install...? But where can I get the *.apk-file?
Regards
back to telnet.
I actually can't establish a telnet connection at all.
The telentd demon seem to start.
I the moment I connect, the client tells me that the connection is closed by the server.
Danke
@kulrich
There is something happening with the script
"install.sh"
I get
./install.sh
101 KB/s (5480 bytes in 0.052s)
: No such file or directory/su
Failure
' to installbin/Superuser.apk
anybody knows?
Is there missing a space between install and bin?
Regards
Habe gerade mitbekommen das Englisch als Sprache nicht so gut ankommt - sorry - also weiter in Deutsch:
Mehr Details zu telnet:
- adb remount
- adb shell telnetd
weitere konsole:
test@frezz:~$ telnet 192.168.8.26
Trying 192.168.8.26...
Connected to 192.168.8.26.
Escape character is '^]'.
Connection closed by foreign host.
grüße
Kai
kulrich schrieb:
Habe gerade mitbekommen das Englisch als Sprache nicht willkommen ist - sorry - also weiter in Deutsch:
- adb remount
- adb shell telnetd
weitere konsole:
grüße
Kai
Wieso willst du per telnet auf das Gerät, wenn du ne debug bridge hast? Mit "adb shell" bekommst du doch ne root shell - wozu da noch der Umweg über telnet?
Hat 3 Gründe.
1. Bequemlichkeit: Mich nerft der kabelsalat -> Verbindung via WLAN
2. Schutz: Meine USB Verschlusskappe fängt an zu verschleißen - -> Verbindung via WLAN schont. (Ja ich weiß ist lächerlich)
3. Neugier: Ich würde gerne den dropbear (sshd) installiern. Ich habe das Gefühl wenn telnet nicht läuft wird sshd auch nicht gehen.
http://forum.xda-developers.com/showthread.php?t=442754
grüße.
Versuch doch erstmal lokales Telnet. Lad dir die "Telnet" App aus dem Market und mach ein telnet auf "localhost". Wenn das auch nicht geht, kannst du dir in nem Terminal mit "netstat -na" alle Netzwerkverbindungen anzeigen lassen und checken, dass der telnetd auch auf allen Interfaces lauscht.
hm, der port 23 ist nur unter 0.0.0.0:23 offen
wen ich mit dem telet darauf zugreife heißt es
"Error while reading socket"
dann ist der telnetd weg.
0.0.0.0 bedeuted, dass auf allen IPv4 Adressen und allen Interfaces nach Verbindungen gelauscht wird. Somit sollte der telnetd die Verbindung annehmen egal von wo du kommst.
Nicht sehr aussagekräftiger Fehler. Ein read() kann aus vielen Gründen schiefgehen. Lass dir doch mal die Logs mit "adb logcat" ausgeben. Vielleicht findest du da nen Hinweis warum der telnetd sich verabschiedet.
Du kannst auch den telnetd im debug modus starten. Allerdings solltest du das direkt auf dem Gerät aus ner Root-Shell raus machen. Vielleicht gibt der telnetd ne Fehlermeldung aus bevor er crasht oder du kannst anhand der Debug Messages sehen was ihm nicht passt.
hm,
1. Es sieht so aus als hätte telnetd auf android keinen -d debug mode
Options:
-l LOGIN Exec LOGIN on connect
-f issue_file Display issue_file instead of /etc/issue
-K Close connection as soon as login exits
(normally wait until all programs close slave pty)
-p PORT Port to listen on
-b ADDR Address to bind to
-F Run in foreground
-i Run as inetd subservice
2. logcat sacht garnichts. auch nicht mit parameter *:v
3. unter /system/bin befindet sich kein tellnetd !!
:-0
kulrich schrieb:
hm,
Ist wohl aus Platzgründen ne abgespeckte Version des telnetd. Probier's mal mit der Option "-F" für "foreground". Vielleicht loggt er was auf stderr bevor er crasht.
Hmm, das hab ich schon befürchtet.
Ja, das gammelt irgendwo unter xbin rum.
Wenn's gar nicht anders geht, dann bleibt dir eigentlich nur die Möglichkeit netcat oder sowas zu installieren und dann die Ports mal von Hand aufzumachen. Dann siehst du zumindest ob's am Betriebssystem oder am telnetd liegt.
kommt auch nichts
Kann es sein das telnetd irgend welche Rechte fehlen?
HexHecker
HexHecker
HexHecker
  • switch_heel
StyleP
  • alexandre;
alexandre;
