thompson187
super, danke dir!
DetWAR schrieb:
Ih kann nur sagen: Läuft top! Der schnellste Browser bisher und komplett ohne FCPuky70 schrieb:Hi,
läuft bei Euch der Browser "Steel"? Ich bekomme immer einen FC.
Cu Puky70
Here's the kernel for CyanogenMod 5.0.7-test1.
THIS UPDATE.ZIP WILL ONLY WORK WITH STOCK CYANOGENMOD 5.0.7-test1
Please follow the instructions for flashing CyanogenMod, then install this update using the recovery image.
DO NOT FLASH DEATH/DANGER SPL that hboot is just for the size of /system, and the mt3g LE Fender/1.2 has plenty already.
This kernel is exactly the same as Cyanogen's, except it has support for the myTouch 3G 1.2 / LE Fender, and a fix for some memory corruption that caused system crashes on that phone.
"32B" Dream/Sapphire owners, excluding Rogers Dream (see bcrook's port): This will work on your phone too.
UPDATED 2010-05-01
Remapped some of the I/O memory to an address outside of vmalloc (stability)
Updated the binder patch
UPDATED PATCH ONLY 2010-05-02
Accuracy correction for the binder patch commit message, no code affected.
UPDATED 2010-05-03
Fixed zone alignment (stability)
This updates fixes the last crashing bug that I have reports for.
UPDATED 2010-05-03 #2
Fixed battery drain when phone is sleeping.
update.zip (also attached): http://zenthought.org/tmp/kernel-cm-..._3.5mm-233.zip
