elefelle
HIIILLLFFFEEEEEEEEE.
Mein Handy macht nix mehr.
Dabei wollte ich nur den Bootloader wieder schliessen, mehr nicht.
Ganz nach der Anleitung hier vorgegangen.
Jetzt gehts nicht mehr aus dem Flashmodus raus.
WAAAAAAAAHHHHHHH
Auch ein- und ausschalten half nix, auch ned vol. up und Ausschalter gleichzeitig bis es 3 mal Vibriert. NIX.
Hier mal das LOG vom Flashtool:
03/025/2012 23:25:55 - INFO - <- This level is successfully initialized
03/025/2012 23:25:56 - INFO - Flashtool Version 0.8.0.0 built on 2012-05-27 21:57:12
03/025/2012 23:25:56 - INFO - You can drag and drop ftf files here to start flashing them
03/026/2012 23:26:03 - INFO - Device disconnected
03/026/2012 23:26:57 - INFO - Device connected in flash mode
03/027/2012 23:27:10 - INFO - Selected Xperia-S_Relock_bootloader.ftf
03/027/2012 23:27:10 - INFO - Preparing files for flashing
03/027/2012 23:27:10 - INFO - Please connect your device into flashmode.
03/027/2012 23:27:11 - INFO - Opening device for R/W
03/027/2012 23:27:11 - INFO - Reading device information
03/027/2012 23:27:11 - INFO - Phone ready for flashmode operations.
03/027/2012 23:27:11 - INFO - Start Flashing
03/027/2012 23:27:11 - INFO - Flashing loader
03/027/2012 23:27:13 - INFO - Loader : S1_Root_de72 - Version : R5C004 / Bootloader status : ROOTED
03/027/2012 23:27:13 - INFO - Flashing preset.ta
03/027/2012 23:27:13 - INFO - Writing TA unit : [00, 00, 08, B2, 00, 00, 00, 02, 00, 00]
03/027/2012 23:27:14 - INFO - Ending flash session
03/027/2012 23:27:14 - INFO - Flashing finished.
03/027/2012 23:27:14 - INFO - Please wait. Phone will reboot
03/027/2012 23:27:14 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
03/027/2012 23:27:14 - INFO - Device connected in flash mode
03/027/2012 23:27:53 - INFO - Device disconnected
03/029/2012 23:29:45 - INFO - Device connected in flash mode
03/030/2012 23:30:01 - INFO - Selected Xperia-S_Relock_bootloader.ftf
03/030/2012 23:30:01 - INFO - Preparing files for flashing
03/030/2012 23:30:01 - INFO - Please connect your device into flashmode.
03/030/2012 23:30:02 - INFO - Opening device for R/W
03/030/2012 23:30:02 - INFO - Reading device information
03/030/2012 23:30:02 - INFO - Phone ready for flashmode operations.
03/030/2012 23:30:02 - INFO - Start Flashing
03/030/2012 23:30:02 - INFO - Flashing loader
03/030/2012 23:30:04 - INFO - Loader : S1_Root_de72 - Version : R5C004 / Bootloader status : ROOTABLE
03/030/2012 23:30:04 - INFO - Flashing preset.ta
03/030/2012 23:30:04 - INFO - Writing TA unit : [00, 00, 08, B2, 00, 00, 00, 02, 00, 00]
03/030/2012 23:30:05 - INFO - Ending flash session
03/030/2012 23:30:05 - INFO - Flashing finished.
03/030/2012 23:30:05 - INFO - Please wait. Phone will reboot
03/030/2012 23:30:05 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
03/030/2012 23:30:05 - INFO - Device connected in flash mode
03/030/2012 23:30:57 - INFO - Device disconnected
03/032/2012 23:32:13 - INFO - Device connected in flash mode
03/032/2012 23:32:39 - DEBUG - (MyLogger.java:106) - <- This level is successfully initialized
03/034/2012 23:34:10 - ERROR - (X10flash.java:346) - ERR_SEVERITY="MAJOR";ERR_CODE="0019";ERR_DYNAMIC=" SIN header verification failed";
03/034/2012 23:34:10 - ERROR - (X10flash.java:347) - Error flashing. Aborted
Ist etwas länger weil ichs danach nochmal versucht habe.
BITTE HELFT MIR.
EDIT: Im Gerätemanager taucht das Handy auf als SEMC Flash-device. Hoffe das bringt etwas. Es tut ungefähr alle 10 -15sek. sich trennen vom PC und wieer verbinden.
Vielen Dank,
elefelle
Der ursprüngliche Beitrag von 01:26 Uhr wurde um 01:28 Uhr ergänzt:
Hallo.
PUUUHHHHHHH:
1 Std. gebraucht, aber dann:
Ich hab mal spasseshalber den update Service von Sony eingeschaltet, ohne Hoffnung allerdings weil das PC-Companion auch versagt hatte.
Doch siehe da, das Programm erkennt nicht nur mein Handy, nein. Es bietet mir auch ein Update an.
Gesagt, getan. Die knapp 380MB runtergeladen und installiert .....
Jetzt hab ioch ICS drauf (Version 4.0.4).
Rooten muss ichs anscheinend doch wieder neu, Titanium Backup sagt es hätte keine Berechtigung. Was solls, ein kleineres Problem.
Nur eins mach ich jetzt sofort: ein Backup!!!
Iss es nicht herrlich?
Immerhin nicht umsonst die Nacht um die Ohren gehauen.
Schönen Tag euch.
elefelle
WAAAAAAAAHHHHHHH
BITTE HELFT MIR.
Vielen Dank,
elefelle
Hallo.
PUUUHHHHHHH:
Schönen Tag euch.
elefelle
