Bootloop, Brick und andere Gründe für den Nicht-Start des Sony Xperia S (Root)
  • 553 Antworten
22/045/2014 19:45:34 - INFO - Flashtool Version 0.9.18.1 built on 08-25-2014 23:00:00
22/045/2014 19:45:34 - INFO - Executing search strategies to find proxy selector
22/045/2014 19:45:35 - INFO - No proxy found for IE. Trying next one
22/045/2014 19:45:35 - INFO - Proxy found for firefox
22/045/2014 19:45:35 - INFO - Syncing devices from github
22/045/2014 19:45:36 - INFO - Scanning devices folder for changes.
22/045/2014 19:45:45 - INFO - Pulling changes from github.
22/045/2014 19:45:45 - INFO - Devices sync finished.
22/045/2014 19:45:50 - INFO - Device disconnected
22/046/2014 19:46:03 - INFO - Selected Bundle for Sony Xperia S (LT26i). FW release : 6.2.B.1.96. Customization : o2_DE
22/046/2014 19:46:03 - INFO - Preparing files for flashing
22/046/2014 19:46:09 - INFO - Please connect your device into flashmode.
22/046/2014 19:46:13 - INFO - Device connected in flash mode
22/046/2014 19:46:14 - INFO - Opening device for R/W
22/046/2014 19:46:14 - INFO - Reading device information
22/046/2014 19:46:14 - INFO - Phone ready for flashmode operations.
22/046/2014 19:46:14 - INFO - Current device : LT26i - CB511YAQ2F - 1257-2015_R7H - 1252-0023_6.2.B.1.96 - WORLD_6.2.B.1.96
22/046/2014 19:46:14 - INFO - Start Flashing
22/046/2014 19:46:14 - INFO - Processing loader.sin
22/046/2014 19:46:14 - INFO - Checking header
22/046/2014 19:46:14 - INFO - Flashing data
22/046/2014 19:46:15 - INFO - Processing of loader.sin finished.
22/046/2014 19:46:16 - INFO - Loader : S1_Root_de72 - Version : R5C011 / Boot version : R10CA003 / Bootloader status : ROOTABLE
22/046/2014 19:46:16 - INFO - Disabling final data verification check
22/046/2014 19:46:17 - INFO - Processing partition-image.sin
22/046/2014 19:46:17 - INFO - Checking header
22/046/2014 19:46:17 - INFO - Flashing data
22/046/2014 19:46:19 - INFO - Processing of partition-image.sin finished.
22/046/2014 19:46:19 - INFO - No bootdelivery to send
22/046/2014 19:46:19 - INFO - Processing kernel.sin
22/046/2014 19:46:19 - INFO - Checking header
22/046/2014 19:46:20 - INFO - Flashing data
22/046/2014 19:46:24 - INFO - Processing of kernel.sin finished.
22/046/2014 19:46:24 - INFO - Processing fotakernel.sin
22/046/2014 19:46:24 - INFO - Checking header
22/046/2014 19:46:24 - INFO - Flashing data
22/046/2014 19:46:28 - INFO - Processing of fotakernel.sin finished.
22/046/2014 19:46:28 - INFO - Processing amss_fs_2.sin
22/046/2014 19:46:28 - INFO - Checking header
22/046/2014 19:46:28 - INFO - Flashing data
22/046/2014 19:46:30 - INFO - Processing of amss_fs_2.sin finished.
22/046/2014 19:46:30 - INFO - Processing amss_fs_1.sin
22/046/2014 19:46:30 - INFO - Checking header
22/046/2014 19:46:31 - INFO - Flashing data
22/046/2014 19:46:32 - INFO - Processing of amss_fs_1.sin finished.
22/046/2014 19:46:32 - INFO - Processing amss_fsg.sin
22/046/2014 19:46:32 - INFO - Checking header
22/046/2014 19:46:32 - INFO - Flashing data
22/046/2014 19:46:33 - INFO - Processing of amss_fsg.sin finished.
22/046/2014 19:46:33 - INFO - Processing apps_log.sin
22/046/2014 19:46:33 - INFO - Checking header
22/046/2014 19:46:34 - INFO - Flashing data
22/046/2014 19:46:36 - INFO - Processing of apps_log.sin finished.
22/046/2014 19:46:36 - INFO - Processing cache.sin
22/046/2014 19:46:36 - INFO - Checking header
22/046/2014 19:46:36 - INFO - Flashing data
22/046/2014 19:46:40 - INFO - Processing of cache.sin finished.
22/046/2014 19:46:40 - INFO - Processing system.sin
22/046/2014 19:46:40 - INFO - Checking header
22/046/2014 19:46:41 - INFO - Flashing data
22/048/2014 19:48:42 - INFO - Processing of system.sin finished.
22/048/2014 19:48:42 - INFO - Processing userdata.sin
22/048/2014 19:48:42 - INFO - Checking header
22/048/2014 19:48:42 - INFO - Flashing data
22/048/2014 19:48:49 - INFO - Processing of userdata.sin finished.
22/048/2014 19:48:51 - INFO - Resetting customizations
22/048/2014 19:48:51 - INFO - Writing TA unit : [00, 00, 08, A4, 00, 00, 00, 0E, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00]
22/048/2014 19:48:52 - INFO - Ending flash session
22/048/2014 19:48:52 - INFO - Flashing finished.
22/048/2014 19:48:52 - INFO - Please unplug and start your phone
22/048/2014 19:48:52 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
22/048/2014 19:48:52 - INFO - Device connected in flash mode
22/049/2014 19:49:15 - INFO - Device disconnected
selber effekt... sony ==> xperia ==> Animation ==> Reboot
Allerdings hatte ich dieses mal sony ==> Schild mit wartungssymbol und ladebalken ==> xperia ==> Animation ==> Reboot
Lade dir mal eine Custom ROM oben aus dem gepinnten Bereich, meinetwegen Paranoid oder SlimBean. Extrahiere daraus bitte die Boot.img und kopiere diese in den Flashtool Ordner "x10flasher_lib" rein und flashe die mal bitte über Fastboot mit dem Flashtool.
Danach startest du bitte in das CWM oder TWRP und dann mal alles wipen, was zu wipen ist, also auch System! Dann Gerät ausschalten, wieder in das Flashtool und die letzte Firmware wieder flashen mit den aktuellen Einstellungen. Wenn es dann immer noch nicht hoch fährt bin ich mit meinem Latein komplett am Ende!
Gruß,
snoopy-1
Reaktionen: KitsuneSnow
habe die img datei und hab sie in das verzeichnis gepackt.. wie mache ich das hier "flashe die mal bitte über Fastboot mit dem Flashtool" ? hab im Flashtool zwar den Flashboot modus gefunden aber danach weiss ich nicht was ich machen soll :(
Der ursprüngliche Beitrag von 20:59 Uhr wurde um 21:20 Uhr ergänzt:
Update:
Habe per Flashtool folgendes gemacht:
Flashtool ==> Fastmode ==> Select Kernel to flash ==> die .img datei genommen
danach:
Flashtool ==> Fastmode ==> Select System to Flash ==> die .img datei genommen
Als ich es dann angemacht habe habe ich es für ca 10 sekunden bis auf die oberfläche geschafft (spachauswahl und meldung dass ich keine sim karte drin habe) und dann hat es wieder rebootet und ich bin wieder da wo ich angefangen habe :(
Zum Wipen komme ich gar nicht erst weil ich es nicht ins cwm schaffe :(
Der ursprüngliche Beitrag von 21:20 Uhr wurde um 21:31 Uhr ergänzt:
Nochmal update:
Ich habe es in den "Abgesicherten Modus" geschafft und konnte mich ein wenig im handy umschauen. Habe da auch einige apps gesehen aber nach 2 minuten ging das handy aus und startete sich neu
Der ursprüngliche Beitrag von 21:31 Uhr wurde um 21:32 Uhr ergänzt:
das mit dem abgesicherten modus hat geklappt nachdem ich wie viel auf lauter + und lauter - rumgedrückt habe während des bootens
Der ursprüngliche Beitrag von 21:32 Uhr wurde um 21:39 Uhr ergänzt:
und nochmal edit:
ich habs bis in die entwickleroptionen geschafft und sie aktiviert
update:
TWRP will root rechte haben die ich aber (noch) nicht habe. Soll ich Rooten?
Ja, irgendwie machst du gar nicht das was ich eigentlich wollte, aber gut versuchen wir halt mal was ganz anderes wenn du da schon mal ein paar Schritte weiter kommst.
Erst mal, welche Boot.img hast denn nun überhaupt geflasht? Dann kannst mir ja sicher jetzt auch sagen, was unter Systeminfo im Gerät steht, insbesondere Version und Kernel.
Nur mal so zur Info, nach dem flashen der Boot.img kommt man durch kurzen drücken der Lautstärke + oder - Taste in das Recovery. Nach dem flashen der Boot.img das Gerät neu starten und wenn die lila LED leuchtet, dann eben kurz die Lautstärketasten drücken.
Geflasht wird das ganze eben im Fastbootmode mit "Select Kernel to flash" ganz rechts im Menü.
Gruß,
snoopy-1
"Erst mal, welche Boot.img hast denn nun überhaupt geflasht? Dann kannst mir ja sicher jetzt auch sagen, was unter Systeminfo im Gerät steht, insbesondere Version und Kernel."
die img datei von pa_nozomi-4.6-BETA4-20141009
Build Nummer: 6.2.81.96
Android Version: 4.1.2
Kernel: 3.4.0+ 1.0.21100-313065-g1ccebb5-00193 gcbc50lc
BuildUser@BuildHost))
#1 SMP Preempt tue Jul 23 15:55:38 2013
Hoffe ich habe mich nicht vertippt
edit: bei mir leuchtet nichts lila
Nun gut, das hat ja soweit geklappt, nur eben läuft das System nicht rund, was ja auch klar ist weil Kernel und ROM nicht zusammen passen!
Dann kopiere dir jetzt mal die komplette Zip auf die SD Karte, boote in das Recovery und flashe damit mal diese Zip Datei. Aber wipe bitte vorher das System mit TWRP
Gruß,
snoopy-1
zunächst: Sorry dass ich so schwierig bin xD bin absolut neu in der szene
welche zip und welche sd karte? Soweit ich weiss hat mein handy keinen sd slot :( . Für TWRP muss ich erst Rooten.. ich finde aber gerade kein tutorial dafür
Der ursprüngliche Beitrag von 23:05 Uhr wurde um 23:17 Uhr ergänzt:
so hab gerootet... und gewiped
Der ursprüngliche Beitrag 22.11.2014 von 23:17 Uhr wurde 23.11.2014 um 00:01 Uhr ergänzt:
kann ich es dir nicht einfach per post senden und du reparierst mir das? :D
Also ins CWM komme ich jetzt probemlos.. was genau muss ichnach dem wipe flashen? SD Karte geht nicht... allerdings habe ich da eine "update.zip" gefunden die mit dabei war...
Also nochmal langsam damit ich auch mit komme, das alles ist schon sehr Mysteriös...
Flashtool läuft scheinbar komplett einwandfrei durch und trotzdem die Reboots...
Hast du sicher alle Haken bei den Wipes drin gelassen? (Manchmal sind die nicht automatisch gesetzt)
Hast du mal bei "Misc" den haken bei "no final verification" und "reset customizations" gesetzt?
Was für eine .img hast du per "Select System to flash" genommen??
Zum Rest:
Wenn du in CWM reinkommst (ohne das es irgendwann wieder abstürzt) dann versuch per USB-Mount (Mounts & Storage) die interne SD (alle "festplatten" werden als SD bezeichnet) deines Handys am PC zu mounten damit du drauf zugreifen kannst und schieb mal die PA...zip drauf und wipe danach system, data, cache, dalvik cache (advanced) sowie (falls vorhanden) boot
danach installierst du einfach die pa zip und rebootest danach. Sollte doch funktionieren...
pa.zip?
Der ursprüngliche Beitrag von 14:12 Uhr wurde um 14:17 Uhr ergänzt:
Ich kanns gern nochmal machen aber soweit ich weiss ja
Die aus dem weiter oben gennanten Packet:
Ich habs gerade mal an pc angeschlossen aber ich kriege eine "Das Gerät konnte nicht installiert werden" Meldung von Windows 7
Welchen Pa ... zip ordner? Wo finde ich den?
pa_nozomi-4.6-BETA4-20141009.zip (Die Custom-Rom)
Und die boot.img als System.img zu flashen könnte ein Fehler gewesen sein, der deinem Handy das Leben kostet. Die boot.img wird nur als Kernel geflasht und als nichts anderes.
Ergebnis?
Wenn ich versuche CWM usb zu mounten kommt das hier:
Wo finde ich die treiber
Der ursprüngliche Beitrag von 14:43 Uhr wurde um 14:44 Uhr ergänzt:
Aaskereija schrieb:
Bootloop mit diesem Schild und dem Ladebalken
Treiber hat das Flashtool
Taucht das Handy nicht als Festplatte auf?
nope ich hör nur das "dün dün dün" von windows wenn es ein usb gerät nicht mag o:
Der ursprüngliche Beitrag von 14:52 Uhr wurde um 15:11 Uhr ergänzt:
kann ich des setup von flashtool drivers nochmal machen und nochmal alle treiber auswählen?
Kla, danach hald pc neu starten
die treiber dafür hat flashtool scheinbar nicht
Die direkten geraetetreiber hat nur das Handy selbst
und wie isntalliere ich den nu? :o
Aaskereija
Aaskereija
Hangwire
  • Hangwire
Hangwire
Hangwire
Gonzales70
