Kernel [FW:4.0.A.2.368]
  • 9 Antworten
Computerbastler
Hier Verbersterte kernel der eine neue funktione biete !
Werde immer wieder aktualiesieren wenn update kommt also guckt ahl hin und wieder auf die page !
Download :
https://www.base-team-mateorie.org/index.php?site=files&file=29
Flashen geht so :
fastboot flash boot boot.img
Fastboot könnt ihr Dowloaden unter :
https://www.base-team-mateorie.org/index.php?site=files&file=20
[ features ]
DooMKernel (v08) released!
[ features ]
  • [v08 onwards] compiled using toolchain gcc-4.4.3 (might improve kernel performance)
  • [v08 onwards] added new CPU governors:
    • InteractiveX
    • Savaged-Zen
    • SmartAssV2
  • [v07-FIX onwards] fixed sysinit support
  • [v07-FIX onwards] enabled /system/etc/install-recovery.sh execution
  • [v07 onwards] added new bootup CPU thresholding, device will no longer jump to max freq for initial few seconds (might help some device who have booting issues)
  • [v07 onwards] improved init.d support, now scripts in /system/etc/init.d will automatically be given correct permissions and be executed (this will not correct/fix the errors which might be inherently present in the script)
  • [v07 onwards] corrected VDD control to show only those frequencies which are enabled in CPU-freq table
  • [v06 onwards] added new logo!!
  • [v06 onwards] added I/O Schedulers:
    • V(R)
    • BFQ
  • [v06 onwards] addet CPU Governors:
    • Smartass
    • Scary
    • MinMax
  • [v06 onwards] enabled NLS_UTF8
  • [v05 onwards] added user-level/runtime CPU voltage control [VDD control "sysfs interface"] (for more info keep checking this post: http://forum.xda-developers.com/show...&postcount=362)
  • [v05 onwards] added Interactive CPU Governor
  • [v05 onwards] added new Max frequency:
    1.9Ghz
  • [v05 onwards] added lots of intermediate frequencies (from 122Mhz to 1.9Ghz for almost every 100/120Mhz there is a select-able frequency)
  • [v04 onwards] updated recovery related scripts to resolve mounting issue
  • [v04 onwards] added cpu freq thresholds to throttle CPU speeds to stock values when inside recovery
  • [v04 onwards] corrected adb issues (in both OS & recovery)
  • [v04 onwards] added lots of intermediate frequencies
  • [v03 onwards] updated recovery to CWM v4.0.1.4 FreeXperia Team
  • [v03 onwards] {ramdisk tweak} /sd-ext also symlinked to /mnt/sd-ext
  • [v03 onwards] enabled SWAP support
  • [v03 onwards] enabled CDROM filesystem support in kenrel (now u can mount ISO files)
  • [v02 onwards] added under/overclock from 128Mhz to 1.862Ghz [NOT UNDERVOLTED] (for sake of safe booting the device will always boot at min 245Mhz / max 1024Mhz)
  • [v01 onwards] added new LOGO... no more boring SE TEXT logo
  • [v01 onwards] autorooting (prerooted)
    • kernel is insecure (ro.secure=0)
    • su binary & superuser.apk will automatically be installed by kernel
      (thanks to Bin4ry for posting the file RootXperia.zip; i have used the superuser files from his zip)
    • busybox already installed in /sbin/
    • busybox will get copied to /system/xbin/ if its not present there
    • adb server is persistent
    • usb debugging enabled
    • rootfs and /system mounted as rw (thank you Blagus for the tip
  • [v01 onwards] CWM recovery (Thanks to FreeXperia team)
  • [v01 onwards] init.d scripts/binaries execution support
  • [v01 onwards] enabled support (in kernel) for many file systems
    • EXT2
    • EXT3
    • EXT4
    • NTFS (Read & Write)
  • [v01 onwards] enabled a few I/O Schedulers
    • noop
    • Anticipatory
    • Deadline (default)
    • CFQ
  • [v01 onwards] enabled NFS (client & server) support in kernel
  • [v01 onwards] enabled CIFS support in kernel
  • [v01 onwards] enabled access to kernel .config (can be pulled from /proc/config.gz)
  • [v01 onwards] enabled TUN/TAP driver support (integrated in kernel) [VPN support]
  • [v01 onwards] enabled ARM THUMBEE extensions
  • [v01 onwards] USB-OTG support (already enabled in SE FW)
Reaktionen: keeeevin
hallo.
bei mir wir das neo nicht erkannt wenn ich es anschliesse. status: waiting das wars !
Ja lol haste das handy nicht im fasboot modus geht nur wenn du bootloader unlock hast !
led an seite mus blau leuchten !!!! nicht grün !!!!!!!!!
habs schon das handy gerootet und geflascht, aber kA warum es jetzt nicht wieder geht ! arrr
also beim mir gehts kanste ja sehen xD ....
habe nun auf 1,9 ghz laufen da kernel ja übertagtungs unterstützt
LOL...Bestell schon mal 'n neues :-D
Nein, im Ernst, hast du es wirklich dauerhaft auf 1.9? Keine reboots? Undervolted? Wie warm wird es?
Ach geht schon ca 60 crad wenn NFS zocke oder N64 ^_^
Playstation 1 leuft auch ganz gut 60 fps ~
habes Dynamisch eingestelt so mit leuft net immer auf 1,9 ghz nur wenn halt volast hatt games und so ^_^
im stand by habe normale takung von 300mhz runter gesetzt auf 122 mhz erhöt deutlich akku lauf zeit im stand by oder bei Musik hören ^_^
leuft ca 3 tage duch mit eingeschlaten wlan im stanby bis es aus geht
Nur mal zur info den " DooMKernel" gibt es jetzt in v08
    • InteractiveX
    • Savaged-Zen
    • SmartAssV2
    • InteractiveX
    • Savaged-Zen
    • SmartAssV2
Sry wuste schon lange bin nur net dazu gekommen mahl auf den server hoch zu laden und hier rein zu schreiben sry hatte einge privaten stress xD
nun bin wieder da werde jeden tag wieder euch alle auf den laufenden halten.....
wer hat noch den DoomKernel und Probleme mit der MediaLautstärke ?
Die ist bei mit nach jedem Neustart des Neo ganz leise bzw. aus auch wenn vor dem neustart voll aufgedreht wurde.
Akku wurde schon entfernt, mit dem Original Kernel kommt das nicht vor.
