[UTIL] | 2.1 Customizer v0.99.1 (Nov18 Root, Backup, NoJunk, Fonts, ToggleJITv002)
  • 15 Antworten
UKSheep
UKSheep
Dauer-User
569
hier nun eine Anleitung um eurem X10 (mit 2.1 FW) etwas beine zu machen :)
ttxdragon schrieb:
The README File. Important Read:
Code:
#                      x10 After-Root Optimiser                                #
#                          by ttxdragon                                        #
#                          README FIRST!                                       #
Index:
    1. WARNINGS!!
    2. Configuration
        -> Important Info
            a. JITv002
            b. Density Changer
    3. How-To Use This.
    4. Credits
1. WARNINGS!!
    a.  I'm not reponsible for any damage to your device. You should always be
        able to just re-flash your device, but who knows wth can go wrong.
        This is provided as is without any guarantees.
    b.  DO NOT EDIT THE DEFAULT CONFIGURATION FILES MANUALLY UNLESS YOU KNOW
        WHAT YOU'RE DOING! Everything that the config files contain is easily
        edited by using the default-configuration as base in the task-editor.
2. Configuration
    Follow the steps on screen in the task. It'll ask you a lot of stuff, but
    don't worry, it should be extremely clear what you are selecting on.
    Important info:
        JITv002:
            Users of x10a firmware have reported issues with JIT more often than
            those using x10i. x10 SO-01B firmware doesn't work with JIT at all.
            Furthermore, JIT is only useful to be enabled on SE Roms. Custom ROMs
            will have JIT already enabled.
        Density Changer:
            The default configuration changes the Density to 200, down from 240.
            It basically makes everything smaller on screen. Some applications
            might not work properly with the new size (because the developers
            thought it'd be a great idea to not code the program flexibly
            enough to scale nicely)
            You can always just set it back to 240 if you decide that's better
            for you.
3. How-To: Use This
    Requirements: a. Windows or Linux PC,
                     Ubuntu Linux 10.10 Recommended
                     @MAC Folks: Don't have one, can't test. feel free to
                                 submit patches/make own version
    Usage:        1. Enable USB Debuggin in
                      Settings -> Applications -> Development
                  2. Plug in USB Cable
                  3. On Windows: Run RunMeWindows.bat
                     On Linux  : Run RunMeLinux.sh
                  4. Follow On-screen instructions.
4. Credits
    x10dev-team for tirelessly working to free our x10's
    z4mod team for z4root
    Cygwin team for developing this GPL'd port of unix utilities to Windows.
    ( For License and Source-code of Cygwin visit http://www.cygwin.com/ )
CHANGELOG:
Code:
v0.99.1 [2010-11-18]
    - Fix JIT installation/un-installation bug
    - Fix Config Selection bug
    - Add "Install extra System Applications" Option
    - Add "AppWidgetPicker 1.2.1" to extra system apps
    - Add "Wallpaper Set and Save" to replacement apps
v0.99   [2010-11-17]
    - Almost complete Rewrite
    - Better output
    - Add Root-method
    - Allow for custom configurations
    - Allow for multiple configurations
    - More flexible for easy feature-addons
    - Configuration now inside program.
v0.2    [2010-11-10]
    - Fix "Space in Path" Bug
    - Fix "OS Detection" Bug
    - Add "cancel" option before running script on phone
    - Move backup folder from /sdcard/post-root/backup to /sdcard/prbackup
    - Always push fresh configuration to phone (deletes old config on phone)
    - Updated AlarmClock Plus to LCD Density friendly version
v0.1    [2010-11-09]
    - Fix Busybox installation
    - Add LCD Density Changing Option
v0.0    [2010-11-09]
    - Initial Release
To-do List:
- Make Cygwin a Windows-Only Download happening at runtime
- Make useful for Custom Roms -- if possible/wanted.
Download Links:
v0.99.1
Multiupload || DepositFiles
(Please use Multiupload where possible, so that I can have some stats ;) )
Extra Information on what system programs can be removed/replaced from a SE ROM
CHANGELOG:
Code:
v0.99   [2010-11-17]
    - Better output
    - Add Root-method
v0.2    [2010-11-10]
v0.1    [2010-11-09]
v0.0    [2010-11-09]
    - Initial Release
To-do List:
Download Links:
v0.99.1
ttxdragon schrieb:
  • Directly Replaced by Other apps
    • Alarm Clock -> Alarm Clock Plus v2
      apk: AlarmClock
    • Browser -> Dolphin HD
      apk: SemcBrowser
      Drawbacks:
      • Some Applications are hardcoded to use the browser and won't work without it.
        Example: DoCoMo Market
    • Calculator -> RealCalc
      apk: Calculator
    • Email, Gmail -> K-9Mail
      apk: Gmail GmailProvider SemcEmailLargeui
      Drawbacks:
      • Gmail: Some applications don't support K-9Mail for pulling email-info
        Examples are Executive Assistant, Pure Messenger Widget
      • Email: In the Phonebook Email Tab "Write New" doesn't work anymore.
        Workaround -> Clicking mail-address in main-view works.
    • SE Launcher -> ADWLauncher
      apk: SemcHomeL
  • Bloatware
    • Nordic Apps (Only in Generic Nordic ROM)
      /system/etc/customization/applications/Supernytt.apk
      /system/app/Telenor_Wrapper.apk
      /data/app/com.apegroup.aftonbladet.supernytt.zip
      /data/app-private/com.apegroup.aftonbladet.supernytt.apk
    • Backup And Restore
      apk: backupandrestore
    • Documentation
      apk: EManualLauncher EManual usersupport
    • Creatouch (SE)
      apk: creatouch
    • DebugHelper (Service)
      apk: CrashSMS
    • Digital Clock (Widget)
      apk: DigitalClockWidget
    • Facebook (Client)
      apk: facebook
    • Face Recognition (Service for Camera)
      apk: FaceRecognition
      Drawbacks:
      • Face Recognition doesn't work anymore
    • Learning Client (Service)
      apk: LearningClient
      Drawbacks:
      • Word-Learning for the default keyboards is removed.
    • Live Wallpapers (Wallpapers only)
      apk: LiveWallpapers MagicSmokeWallpapers VisualizationWallpapers
      Drawbacks:
      • Only Google Maps Live-wallpaper left
        but market live-wallpapers still work
    • MediaScape
      apk: mediascape MediaScapePluginManager
      Drawbacks:
      • Camera App is hard-coded to use Mediascape for Gallery/Share.
        Vignette Does well but doesn't help in Video mode.
        Means: No easy sharing/viewing for taken videos
      • No easy way to create a wallpaper from taken pictures.
      • No way to set contact picture from phonebook. Need to go through Gallery3D instead.
    • MoxierMail
      apk: moxiermail
    • Music Player (Hidden)
      apk: Music.apk
    • OfficeSuite
      apk: officesuite
    • PC Companion (PC-Sync Service)
      apk: PcCompanion
    • PlayNow
      apk: playnow*
    • Quadrapop (Game)
      apk: quadrapop
    • Recent Calls (Widget)
      apk: RecentCalls
    • Status Switch (Widget)
      apk: StatusSwitch
    • Sony Ericsson Synchronisation
      apk: Sync SyncWizard OmaDatasyncService
    • Search (Widget)
      apk: SearchWidget
    • SetupWizard
      apk: SEMCSetupWizard
    • TimeScape
      apk: Timescape* TimeScape*
    • TrackID
      apk: trackid
    • Voice Dialer
      apk: VoiceDialer
    • Wallpaper Chooser (Selector in Titanium)
      apk: Wallpaper Chooser
      standard wallpapers: /etc/customization/content/com/sonyericsson/android/wallpaperchooser/wallpaper/
      Drawbacks:
      • No Standard Wallpapers available anymore
        Workaround: Get "Wallpaper Set and Save" from Market
    • Wisepilot
      apk: wisepilot
    • YouTube
      apk: YouTube
  • Excess Keyboards
    Note: Keep one of these around, so you can type
    Or install some Keyboard from the Market before you remove these.
    • SE Default English
      apk: textinput-tng
    • Chinese
      apk: chinesetextinput
    • Danish
      apk: Danish_Keyboard
    • English
      apk: LatinIME
    • Korean
      apk: SEMCTouchPalKoreanQWERTY
    • Japanese
      apk: JapaneseIME
Quelle: [UTIL] | 2.1 Customizer v0.99.1 (Nov18 Root, Backup, NoJunk, Fonts, ToggleJITv002) - xda-developers
THX @ ttxdragon 4 great work :)
MfG
UKSheep
Reaktionen: marcel-usedom und oli x10i
Hat das schon wer getestet? Weil klingt ja eig sehr gut :)
//EDiT:
habe es gestestet..
Fazit:
1. Versuch schlug fehl weil ich danach Root nicht mehr hinbekommen hab.
2. hat es dann doch geklappt & als gut befunden :)
es läuft auch alles sehr flüssig... bisher keine zicken.
Mfg
Trollizas
Hier mein Bench.
Läuft sehr gut und bis jetzt keine Probleme (nur einen ungewollten reboot)
Sent from my X10i using Tapatalk
Kann es vll mal jemand schritt für schritt erklären und mit was ihr rootet und so?
Hab es auch schon versucht gehabt doch absolut keine Chance auf Root gehabt danach...
Bitte Detailiert :D
Mfg Crazy
Niemand??? Hab mein x10 gerootet und nach nem Neustart die RunMeWindos.bat ausgeführt.....nach einem reboot häng ich nach dem bootlogo fest! Was mache ich falsch???
Ok läuft nun scheinbar :D Allerdings ist meine Tastatur irgendwie weg....wie kann ich die wieder reinbringen????Kann in ein schreibfeld klicken aber nichts passiert.....
Ok erledigt :D Musste ne App wiederherstellen .
Sry Crazyschranz, hätte dir gern geholfen, war aber die letzten Tage wenig hier :)
Aber hast es ja nun hinbekommen.
P.S. um nächstemal dem entfernen der Tastatur oder Apps die du behalten willst (in meinem Fall Facebook und GoogleMail) entgegen zu wirken :)' empfehle ich dir... schau dir nochmal den Beitrag genau an...
Dort wird erklärt das man einfach die Dateien die man nicht gelöscht oder ersetzt haben will... einfach aus dem optimizer löschen muss...
zB im Ordner "config" findest du "clean_junk" "clean_keyboards" usw... die Dateien die sich in den Ordnern befinden werden vom X10 entfernt...
Ich habe also alle Ordner mal durchgeklickt... und alle sachen entfernt die ich nicht gelöscht haben will... (wie schon erwähnt... facebook Googlemail... dann zB noch K9Mail... und Youtube :)
Vllt. konnte ich dir damit noch ein paar nützliche Tipps für das nächstemal geben....
MfG
UKSheep
mein benchmark ist nur 558, was habt ihr gemacht das es bei euch so höher ist...habe auch JIT/Optimization installiert ??
gruss
558?? Hmm soviel hatte ich ja vorher schon.
Hab eigentlich nur ganz normal das Tool durchlaufen lassen.
Hast du evtl. Timescape und Mediascape von der Optimierung ausgeschlossen?
wie meinst du das??
habe einfach die batch datei ausgeführt und mehr nicht?!
Ja ok, dachte du hast vielleicht in den config Dateien Time- und Mediascape rausgenommen sodass sie erhalten bleiben.
Ich habe mein Handy vor der Optimierung nochmal neu gebootet, dann den Optimizer drüber laufen lassen und gut wars.
Sehr komisch dass das bei dir nur so wenig ist. Sollte eigentlich deutlich mehr sein!
ok danke.... dann versuche ich es nochmal....hoffe einfach dass ich nicht die root probleme bekomme wie auch schon erwähnt worden ist...
gruss
keine Ahnung was ich falsch mache ich komme nur auf total 570......kann man sonst irgend eine einstellung vornehmen das ich auch einen höheren benchmark erhalte....hilfe...:crying:
das Einzige was ich mir vorstellen könnte wäre irgendeine App dir die die Frequenz irgendwie begrenzt...wüsste jetzt aber auch nicht ob es solche Apps gibt außer setCPU. Aber die nutz man ja eher fürs Gegenteil.
O
Anonym6x6
Anonym6x6
Knubbel
bildmacher
  • Take_Oreo
b3i5i53ibi
b3i5i53ibi
