[Theme] Dark Sense for Galaxo 1.6.3.x
  • 469 Antworten
inFECT
inFECT
Stamm-User
242
1. (Blue) Version: Dark Sense 2.1
*** FOR A CHANGELOG CLICK HERE *** FOR A DOWNLOAD LINK CLICK HERE ***
(25.08.2010) - DarkSense 2.1 Final
100% Compatible with Galaxo 1.6.3.4
Fixed the Notification Text Bug.
Compatible with the optimized libdvm by jakax for Galaxo 1.6.3.4
Added the Super Circle Battery
Added ADW 1.1.3 System Version as Standard Launcher with "Sense" Theme
Added Wysie Contacts.apk 2.8 with Dark Sense Theme - Compiled from drakaz
Added new images in the settings for Wifi Connect
Changed Lock Buttons again
Tweaked some images which did not fit properly.
Thanks for testing: Obihoernchen, Casper Span, sgx100, maurinet, Marjun and all others.
Special thanks to: Aglar and Drakaz
DOWNLOAD HERE DARK SENSE 2.1
How to install: (Use at your own risk!)
Dark Sense 2.1 is compatible with Galaxo 1.6.3.4 - It is not tested on other ROMs or Galaxo versions.
- Copy the theme to your root directory on the internal SDCard.
- Perform a nanodroid backup.
- Boot in Recovery Mode and fix the permissions.
- Use the "apply any zip" option and choose the Theme.
- Finished!
Sidenote: If you dont like the ADW Sense Theme, go to Android Codex and download the latest flashable Donut System Version.
How to remove:
Download: http://www.androidcodex.com/files/index.php?dir=darksense/Back2Galaxo/&file=Back2Galaxo1.6.3.4.zip
and proceed with the steps above. Done!
2. (Blue) Version: Dark Sense 2.0
How to install:
The Dark Sense Theme is compatible with Galaxo 1.6.3.2 / 1.6.3.3.
Choose a theme version:
DarkSense2.0_ADW-Sense.zip (HTC Hero Sense Style ADW Launcher)
DarkSense2.0_ADW-Standard.zip (Standard ADW Launcher 0.8.2)
DarkSense2.0_Advanced-Sense.zip (Advanced Launcher with HTC Hero Sense Style)
DarkSense2.0_Advanced-Standard.zip (Advanced Launcher with DarkSense Style)
- Finished!
3. (Grey) Version: Dark Sense 1.6
DarkSense1.6_ADW.zip (Standard ADW Launcher 0.9.0)
DarkSense1.6_Advanced.zip (Advanced Launcher with DarkSense 1.6 Style)
- Finished!
How to remove:
Download: http://box23.org/pub/7500/custom_roms/galaxo/themes/inFECT/Back2Galaxo.zip
Sidenote: If you upgraded from 1.6.3.2 to 1.6.3.3 via patch, the theme wont probably work.
You have to make a full install of either Galaxo 1.6.3.2 or 1.6.3.3
For older releases go to www.androidcodex.com/files/
HOWTO: Dark Sense 1.6 und Dark Sense 2.0 unter Galaxo 1.6.3.2/3 mit JIT
Marjun schrieb:
Hier nochmal der richtige Code, hab alles so in einem Rutsch in der DOS Eingabeaufforderung eingegeben.
Die service.odex aus dem JIT Hack hab ich im Tools Ordner von android-sdk-windows kopiert und
der android-sdk-windows Ordner muß auf C: sein und das Handy per USB Debugging verbunden sein:
Code:
cd c:\android-sdk-windows\tools
adb remount
adb devices
adb shell
rm /system/framework/services.odex
rm /system/app/Contacts.odex
sync
exit
adb push services.odex /system/framework/
adb shell reboot
Danach normal das Dark Sence installiert und es wird Sonne
Reaktionen: backylasek, pumpin, kazwo und 24 andere
ums kurz zu machen:
geil, geil, geil ! :)
wäre es möglich eine version zu erstellen mit weißen logos oben für netz wlan etc und die battery anzeige im sense style zu halten?
sieht sehr schick aus aber mir gefällt das bunte oben nit .. :)
Ist in Planung :) Ich find die grünen GSM Balken zwar geil, aber irgendwie mag die mehrheit sie nicht..
Wie bekommt man die Symbole neben dem Menü bunt? bei mir sind sie nur grau/weiß.
dann bin ich wohl in der minderheit...
mir gefällt es auch so wie es ist mit dem balken :D
im ADW Settings Menü gibt es den Punkt: "Tint AB Buttons" oder so. Haken weg und da hast du sie in Farbe.
ich find ihn genauso gut wie in weiß auch. Ist mir also wurscht.
is sicher ne blöde frage: Aber ich trau mich ;) ! Verbraucht die mehr Akku als std?
Hätt da auch ne Frage zusätzlich zu der von gluf.
Wie sieht die Performance und der RAM-Verbrauch aus?
Verbraucht der ADW mehr? läuft es flüssiger ?
bekomme andauernd forced close von acore :( Hab zuvor extra 1.6.3.3 fresh installt und Fixed Premissions auch gemacht. Restore Gapps natürlich auch :p
€: Muss wohl doch wipen das nochmalige flashen von 1.6.3.3 (Updated) auf 1.6.3.3 hat es nicht verkraftet^^
Wenn du es richtig installiert hast, sollten sie automatisch "bunt" sein.
Gut zu wissen :)
Nein.
Also bei mir merke ich keinen Unterschied. Aber andere Setups, andere Erfahrungen.
Es gibt ja auch die version ohne adw mit dem standard launcher. (DarkSense1.4.zip)
Logfiles please :)
Was für ein ADW Launcher ist da drinnen?
Der 0.6.999999.2 schätze ich.
kurze erfahrung(adw):
Ram: kein unterschied festgestellt
performance: läuft gefühlt flüssiger als der advanced launcher.
Galaxo: wipe>1633
Sooo: Hatte vorher die JC6 Base dann 1.6.3.2 mit patch auf 1.6.3.3
Dann habe ich mir die FULL 1.6.3.3 drauf gemacht fix permissions (OHNE WIPE) läuft alles TOP. Gefühlt flüssiger. ALle programme und einstellungen erhalten!!!
Da kann ich nur sagen DANKE an das Forum die Entwickler u immer tolle Anleitungen =)
kleine anmerkung: wäre top, wenn du die google-suchleiste noch entsprechend anpassen könntest (farblich!). die ist momentan noch weiß.
lg
Habe die 1.6.3.3 nochmal drüber installiert ohne Wipe, dann restore Gaps gemacht, check filesystem gemacht, dann fix package permissions gemacht und dann das theme installiert...
JEDOCH: Sind die Buttons neben dem Menü-Button auch weis !:( Was tun?
Oh man! :D
ADW-Settings->UI-Settings->Tint AB
Hab gerade versucht mir das DarkSense Theme zu installieren, musste aber feststellen das ich anscheinend die Recovery Datei um in den Wiederherstellungsmodus zu gelangen von meinem internen Speicher gelöscht habe.
Hab schon versucht mir das Recovery(4.6.3) runter zu laden und wieder auf meinen Speicher zu packen und meiner meinung nach müsste jetzt auch wieder alles okay sein denn jetzt startet er auch wieder im Recover Modus aber wenn ich dann auf: apply any zip from sd gehe zeigt er mir zwar die DarkSense zip datei an aber beim instalieren geht dann irgendwie alles schief.
Kann mir jemand sagen wie ich das Problem behebe denn ich bin da jetzt leider ein bissel überfragt:p
jo, nen modifizierter
Nicht ohne Fehlermeldung.. Fix Permission haste gemacht denk ich mal?!
Chrissss
Chrissss
lev17
  • lev17
Bodo
Bodo
  • lordpa
lordpa
