HowTo: GAOSP Public Beta 2
  • 5 Antworten
Klodeckel
Da die Public-Beta 2 von GAOSP erschienen ist, hier mal ein kleines HowTo wie diese zu installieren ist.
Code:
Features
[LIST]
[*]LiveWallpaper (only some of them)
[*]GPS
[*]Sensors
[*]Bluetooth
[*]Wifi
[*]3D
[*]AWD Launcher with native settings
[*]Spare Part
[*]Modified core from cyanogenmod (with all associated features)
[*]RC scripts
[*]Galaxo’s app
[*]Overclocking from 19Mhz to 710Mhz with any overclock widget or  application
[*]Video playback (youtube, gallery)
[*]Gallery3D
[/LIST]
 Other :
[LIST]
[*]Custom Kernel 2.6.29
[*]Clean shutdown/startup system by Cyanogen
[*]Tools included
[*]Lof of tweaks
[*]FLAC audio support from [URL="http://the-b.org/"]Kenny  Root[/URL] (from CyanogenMod[URL="http://code.google.com/p/gaosp/w/edit/CyanogenMod"]?[/URL])
[*]Perform zipalign-on-install of applications  (merge with CyanogenMod[URL="http://code.google.com/p/gaosp/w/edit/CyanogenMod"]?[/URL])
[*]Lot of locations
[*]360-degree auto-orientation by [URL="http://mpsb.info/"]Optedoblivion[/URL] and Elanthis (from  CyanogenMod[URL="http://code.google.com/p/gaosp/w/edit/CyanogenMod"]?[/URL])
[*]OpenVPN integration thanks to James Bottomley (from CyanogenMod[URL="http://code.google.com/p/gaosp/w/edit/CyanogenMod"]?[/URL])
[*]Full ssh server with real authentication (dropbear)
[*]Custom bootanimation from Bioden (frandroid)
[*]Custom android logo on boot by Epervier (frandroid)
[*]Custom logo.rle by Alexandre (frandroid)
[*]Root & Superuser
[*]Reboot & Reboot recovery now included in shutdown menu
[*]Full busybox with symlink
[*]Lot of features from cyanogenmod
[/LIST]
Zunächst muss wie schon bei dem Galaxo-Projekt eine Custom-Recovery geflasht werden. Hierfür benötigen wir Version 5.0 (Download)
Diese wird nun wie folgt auf das Gerät übertragen.
Falls nicht bekannt ist wie das geht:
Code:
1. ADB Treiber installieren ([URL="http://files.androidwiki.de/pub/7500/tools/SDK1.6_USB_Galaxy.rar"]Download)[/URL]
2. Android SDK herunterladen ([URL="http://developer.android.com/sdk/index.html"]Download[/URL])
3.Das Recovery Archiv wird dekomprimiert. Das “recovery.img” wird im   “tools” Verzeichniss des “android-sdk-windows” Ordner platziert.
4.Die RECTOOLS.tar.gz wird auf die SD-Karte kopiert und verbleibt da. (Nicht löschen!)
5. Kommandozeile öffnen und ins SDK Verzeichnis wechseln. (cd X:/ANDROIDSDKDIR/tools )
6. “fastboot flash recovery recovery.img” eingeben und bestätigen.
7. Telefon mit der [URL="http://www.androidwiki.de/galaxy-i7500-essentials.html"]Tastenkombination[/URL]:  “Annehmen + Powertaste” im   “Fastboot” Modus starten.  (Tasten gedrückt halten)
8. Nach bestätigung durch die Meldung:  ” writing ‘recovery’ …OKAY” kann   das Telefon nun ausgeschaltet werden.
TuT by [URL="https://www.android-hilfe.de/members/infect-10111.html"]inFECT[/URL]
Wenn die Recovery geflasht ist folgende Dateien herunterladen:
GAOSP 2.1 Update (Download)
GAOSP Addons (Download) !!!: Die Datei welche bei Google Code angegeben ist funktioniert nicht
Diese beiden Dateien auf die SD Karte kopieren.
Sollt dann wie folgt aussehen:
SDROOT/update.zip
SDROOT/GAOSP_Addons.zip
Nun starten wir das Handy im Recovery Mode neu (Lautstärke leiser+Auflegen+Abnehmen gedrückt halten)
Im Recovery Menü zuerst ein Nandroid Backup machen.
Dann einen Wipe durchführen.
Anschließend wird mit "Apply any Zip on SD" die update.zip (GAOSP 2.1) installiert.
Nach erfolgreicher Installation einmal komplett booten lassen, da es sonst zu Komplikationen mit den Addons kommen kann.
Nachdem booten wieder ins Recovery-Menü.
Zunächst "Fix Permissons" ganz unten ausführen und danach wieder "Apply any Zip on SD" die GAOSP_Addons.zip installieren.
Reboot und fertig!
So sollte alles funktionieren und ausgetestet werden können!
Wenn ihr ein Fehler entdeckt immer schön melden!
Reaktionen: rayd, pootney, kreko und 5 andere
Hey ich habe mal ne Frage was bewirk "Fix Permission" eigentlich?
Damit werden die Schreibrechte in den APK´s so gesetzt, dass diese den Systemeigenen Dateien gerecht sind. Ansonsten würden die Google Apps nicht starten
Ok vielen Dank für die Info.
Die RECTOOLS.tar.gz muss vor dem fastboot Befehl mit auf die SD Karte für den Recovery-Mode.
Fehlt oben in der Anleitung.
Ups, vergessen.
Danke für den Hinweis
ludibubi
cometa
Stöpsel
Marcel1983
